Are front diff drops "universal"?
Discussion in '1st Gen. Tacomas (1995-2004)' started by VlineSci09, Apr 29, 2012.
  1. Apr 29, 2012 at 2:28 AM
    VlineSci09
    VlineSci09 [OP] My other truck is a Warthog
    SoDak
    2003 4x4 TRD
    OME sports with 881 and dakar leaf, raider vagabond topper, minor details to exterior, deckplate mod/afe pro dry s, grey wire mod, Trail Gear low profile bumper w/ light bar, lightforce 140mm driving spot lights, blinker light mod
    Well I didnt want to start a thread, but hopefully it can be of use to others and it isnt too burnt out of a subject.
    So I have a 2'' spacer up front and I had a diff drop installed as well. I am going to buy the 3'' OME full lift kit soon. My question is: does it matter what brand or will any diff drop serve the same purpose? Going from the spacers to the coilover set up I would imagine I should keep them unless they arent compatible. In searching the forum I heard alot of 2nd gens werent running them on 3'' lifts. I didnt find much for 1st gens... Remove them? Or keep em (if possible)?
    Thanks
  2. Apr 29, 2012 at 8:27 AM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    Yes, they are all the same. All they are is spacers that drop your differential down in order to reduce the angle.
    A lot of people on here say they are worthless, but the guys at Down South Motorsports recommended to me the I install one with my lift, so I'll listen to them.
  3. Apr 30, 2012 at 9:53 AM
    TacoBran
    TacoBran Your Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    03 Double Cab 4x4 TRD
    Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs
    Dont forget they are salesmen as well. Look at the threads and threads of people saying they are worthless both here and on TTORA. Real world experience is better than a salesman telling you that you need something. lol
  4. Apr 30, 2012 at 10:00 PM
    VlineSci09
    SoDak
    2003 4x4 TRD
    Yeah thats true. Thanks for the input guys. I mean I already have mine so I will prob keep them on worthless or not. It seems like some people dont like them because they cause clearance issues but idk. Mine will stay since they work with whatever set up you run.
  5. May 1, 2012 at 1:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Hi axle angles are an issue. With 3" of lift on the 1st gen IFS, the boot fins on the inner boot get too close together. If the fins touch on a regular basis, you will begin to see a groove worn into the rubber. It will eventually tear at that spot on the boot.
    Diff drops are not a miracle cure but they are an inexpensive option that is more effective on 1st gens when compared to 2nd gens. If your inner boot fins are touching when you are on flat ground, installing a 1" diff drop kit will lower the axle angle enough so the fins don't touch.
