Are fuel line connectors on 2005+ Tacos proprietary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by switch, Oct 28, 2009.
  1. Oct 28, 2009 at 5:35 PM
    switch
    switch [OP] Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    I hope this is not a total noob question but I'm working on an aux fuel tank design and I am planning to use a
    Pollak 6 port fuel selector that will also switch power and fuel level between tanks.
    My guess is that the Toyota fuel line connectors are proprietary since I've found nothing like them available in aftermarket parts.
    If they are not proprietary and you know what the standard is, that would greatly narrow my search for compatible connectors and fuel lines...
    I'd like to connect the Polak selector into the OEM fuel system at the location of the fuel pipe clamp.
  2. Oct 29, 2009 at 12:12 AM
    JKD
    JKD Well-Known Member
    Are you using a second fuel pump in the aux tank?
  3. Oct 29, 2009 at 4:58 AM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    I don't know the answer, but I just gotta say WOW! That's how people on TW sould ask all questions! It's unique, you have a hypothesis, very detailed, and with a diagram! Nice... I've never given rep until now...
  4. Oct 29, 2009 at 5:16 PM
    switch
    Norther California
    Yes, I will have a second fule pump in the aux tank. The pollak is both an electrical and fule switch, so power to the fuel pump and the signal for the fuel level will be switched between the two tanks. This will allow the OEM fuel guage to display fule level in the aux tank.
  5. Oct 29, 2009 at 7:32 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    To answer your question, no.
    The fuel lines are the same type used on all late model Ford and GM cars & trucks. There is a tool that slips over the male end of the connector and releases the barbs that hold the female end on.
    Look at these pics from an F-150 fuel filter.
  6. Oct 29, 2009 at 10:29 PM
    switch
    Norther California
    Thanks, that helps a bunch! Any idea what these fittings are called? Now I just need to source fittings...
  7. Oct 29, 2009 at 10:48 PM
    JKD
    Very interesting. I hope you post a good writeup with pics when you're done (hint, hint).
  8. Oct 30, 2009 at 8:23 PM
    DDD
    Derek
    Santa Clarita, CA
    They are usually just called quick disconnect fittings.
    There is a company called Dorman which makes a kit allowing you to make your own custom fuel lines with quick connect fittings. Look at page 154.
    Watch this video for details. Right click and Save to desktop to watch.
    Summit racing sells the kit and also sells the parts separately, but there not cheap...
