Are hid,s blinding people or.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhowell, Oct 20, 2011.
  1. Oct 20, 2011 at 7:35 AM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Is it that they are just not adjusted corrctley. I don't want to be a pain to other drivers so this is why I am asking. I am looking at the retrofit pairs from black flame custom lights.
  2. Oct 20, 2011 at 7:36 AM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    wolfpack shall be here soon... I can feel it.
  3. Oct 20, 2011 at 7:36 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    if you have a pproperly aimed retrofit, you wont blind other drivers..
    if you have HIDs with no retro, your reflector bowl will scatter your light and blind people.
  4. Oct 20, 2011 at 7:37 AM
    AsianAnts
    AnT
    :broccoli::broccoli::broccoli: you gotta do the dance to call him!
  5. Oct 20, 2011 at 7:39 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    just dont go get 55w hids, get 35w hids and aim them lower
  6. Oct 20, 2011 at 7:41 AM
    lowcel
    lowcel Well-Known Member
    Charleston, WV
    09 TRD Sport Access Cab
    Stereo, d-rings, still pretty new
    I cannot run my hid fog lights but my headlights don't seem no bother other drivers. I only get lights flashed at me when I am hauling something.
  7. Oct 20, 2011 at 8:11 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    This; you can't "aim" light scatter away.
  8. Oct 20, 2011 at 8:13 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    yes, thats why i retro'd :)
  9. Oct 20, 2011 at 8:55 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I hate hids. I really wish they were banned. They are blinding and the majority people have no clue how to aim them correctly
  10. Oct 20, 2011 at 9:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I can't stand HID's in stock reflector housings. They're obnoxiously bright and I agree with what was said above, you can't aim 'scattered' light.
  11. Oct 20, 2011 at 9:30 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    You can aim scattered light trust me I do it
  12. Oct 20, 2011 at 9:34 AM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    You must attend Hogwarts School of Witchcraft & Wizardry to be able to do that
  13. Oct 20, 2011 at 9:47 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    An OEM reflector housing (e.g. Escalade) designed to accept D1R or D2R HID bulbs shouldn't cause excess glare. HID upgrade kit glare depends on the individual HID bulb / base design. There's no set standard because they are basically assembling the glass element from a D1R/D2R bulb onto a halogen base (H4 in case of Tacomas). Some "rebased" HID bulbs maintain the original focal point of the halogen bulb, some don't.
    The 2014 Colorado will have projector headlights. :p
  14. Oct 20, 2011 at 9:48 AM
    Pugga
    Massachusetts
    Do you have the HID's with the shroud on the bottom of the bulb? If so, I would agree to an extent that you can aim them out of people's eyes. If you do not, then I 100% disagree. The HID kits that do not have the shroud on the bottom of the bulb are obnoxious and can not be aimed low enough so as not to blind oncoming traffic.
  15. Oct 20, 2011 at 9:56 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Mine are aimed n I have no scattered light anywhere...I have those mentioned above with shroud at the bottom of the bulb causing only the top half of my reflector to reflect light n I have them aim low enough to where I'm behind a dropped Honda my light is at they're trunk area
    Ps: just bought Fxrs for retro so i don't have any problems with people :p
  16. Oct 20, 2011 at 10:13 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    Please read:
    http://www.intellexual.net/hid.html
    It explains and illustrates the failure of 99% of the HID retrofits, including the most common mistakes and misconceptions.
    There are other links to other articles on that page, I advise reading them as well.
    I sold true HID retrofit kits for several years and I can easily say that 99% of the questions and misconceptions people have were answered by this article.
    That is also why it is illegal to place an HID bulb into a non-HID housing. I used to have the link the the ODOT law but it stopped working quite some time ago. If someone can post it up again that would be great. Most other states have similar laws.
  17. Oct 20, 2011 at 10:38 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    When u see them aim they're rear view mirror down n or us they're bass to cover theyre side mirrors...ya I thinks that enough to know :p
  18. Oct 20, 2011 at 10:41 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i have the brightest headlight i have ever seen on anything now and so long as there in a quality projector and they are properly aimed no you will not blind people.
    now if your one of those guy's who puts hid's into a reflector bowl and calls that awesome then chances are unless you have your headlight aiming towards the ground you are either glaring everyone on the borderline of being flashed by other drivers or you are straight gonna wash out their sight at night.
    take a look at any halogen bulb the coting on the end the way it fits in the housing it was intended for everything about it was designed to work for the headlight it is being put into.
    you cannot just swap out that bulb for something that is on average 2 to 3 times brighter and have no side effects the light will glare and scatter everywhere they look like shit.
    it's my firm belief that you should keep a halogen set-up until you have the time/ money / what ever to do a proper retrofit. if you retrofit correctly you will have a great deal of light on the road ahead of you it catches every street sign and marker/ reflector and they are controlled so you don't blind other drivers.
  19. Oct 20, 2011 at 10:50 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol i need to search out some pictures of the output of a run of the mill plug and play kit and compare it to my set-up you will see the difference right away.
    people say i don't have the money to retrofit then don't stay with your halogen bulbs until you do it's that simple. lol yosh another member on here his avatar is a great example of what a plug and play kit looks like on a dark road. especially if your truck is lifted that exacerbates the problem even more!
    check out my cutoff in the pictures that shot was taken from over 90 feet away! thats what you want out in front of your truck not a bunch of scattered light.http://customlightz.com/?p=p_186&sName=blog
    think about hid lighting is a premium up grade on any factory car and they can vary in price from 700 to 2,000 dollars as a factory option. you get what you pay for in this area just saying lol.
  20. Oct 20, 2011 at 10:54 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i'm sorry but, i don't believe you lol.
    hid lights in a stock reflector housing will GLARE like crazy it's not a matter of opinion it's a fact. you may in fact really enjoy your lights and think they are super cool and awesome good for you.
    i'm not trying to take anything away from you or your truck i'm just stating lighting facts that's all. these plug and play kits are illegal as well are they not? i'm positive they are in nj kids get ticketed all the time for this around my way. there is a reason for that.
