Are hid,s blinding people or.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhowell, Oct 20, 2011.
  1. Oct 20, 2011 at 10:57 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    btw what temp bulb is that? those look very nice lol.. where is the salt in the center? plug and play is shit imo thats just my feeling on the matter idk dude i don't want to offend you i'm just saying.
  2. Oct 20, 2011 at 11:01 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    what is the brand of that bulb who made it ddm etc?
  3. Oct 20, 2011 at 11:02 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Nice link, hadn't seen that one before. Daniel Stern has one on his website as well.
    Ambient light in cities mitigates the glare substantially. Try it driving through a canyon in the middle of nowhere, when you come around a corner and blind another driver for several seconds.
  4. Oct 20, 2011 at 11:03 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    where is wolfpack?????
  5. Oct 20, 2011 at 11:08 AM
    pudge151
    Sean
    Connecticut
    i have HID in stock housing and have tried 2 housings OEM and Aftermarket. I have to say they do scatter light all over, i have had to aim them so far down to avoid blinding people and getting flashed that its really not even worth having them. the only safe and worth while way to have HID's for ON ROAD use is to do a retrofit.
  6. Oct 20, 2011 at 11:11 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    exactly, ambient light down plays the glaring significantly but on a dark road they make you truck seem like an airplane is landing in the lane next to you lol.
    my retro fit was done proper. i have had more than a few high dollar and lesser cost retrofits on my truck in the last year i can say that nothing compares to bjorns work over at customlightz.com the dude is a genius with hid's.
    he modded my projectors to perfection they are aligned perfectly and well you need to take a ride with me is all i can really say you have to see it to believe it i guess.
  7. Oct 20, 2011 at 11:14 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    what!!! the phillips bulbs most certainly will not color shift with a 35 watt ballast. they are the highest quality bulbs money can buy and the standard by which all other bulbs are measured.
    are you familiar with what the term color shift means?
    when you run a higher wattage through some lesser quality bulbs the color temp will change meaning you 4300k will look as if it is a 5 or 6k color that is what will be represented on the road ahead of you.
  8. Oct 20, 2011 at 11:15 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    your reffering to warm up. this actually has more to do with the ballast than the bul believe it not.
  9. Oct 20, 2011 at 11:16 AM
    pudge151
    Sean
    Connecticut
    yes they have the shroud
  10. Oct 20, 2011 at 11:19 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    search it out here is a link from the top echelon of hid retrofitters in the world clearcorners.com read there fact section. http://www.clearcorners.com/tech/
    btw most if not all sellers of phillips bulbs are or have been either used are knock offs or they have been rebased just an fyi. if i was wanting to buy a set of phillips 85122+ bulbs i would either go to a dealership or trs period. same thing goes for the high dollar and hard to find osrams.
  11. Oct 20, 2011 at 11:22 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol i figured that. i personally like 4300 and 5k nothing anything higher is stupid imo becuase you loose light. 6k is noticeable to the human eye. the difference between 43 and 5 k is not i prefer the pure whit light of the 5k.
    i was wanting to pick up a set of those osrams trs had but they where like 240$ a pair or some shit!
  12. Oct 20, 2011 at 11:30 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Then they should have their headlights properly aimed. I don't care if the bulb has a shield or not, it's downright rude to run an HID setup in a reflector housing designed for a halogen bulb.
  13. Oct 20, 2011 at 11:41 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The "illegal" classification is questionable. It is true the HID-upgraded reflector will not meet the FMVSS regs applicable to the vehicle at the time of vehicle manufacture. However, the same can be said of the fog light anytime mod, or an off-road bumper (since you are invalidating original crash test results). In states that do safety inspections, has anyone here failed a safety inspection due to an HID kit installed?
  14. Oct 20, 2011 at 11:56 AM
    Scummy
    Scummy SCUMBAG CUSTOMS
    Phelan, CA
    hopped up 96 single cab 5 lug 4 banger
    Fabtech uppers and spindles, extended shackles in rear, k&n intake, flowmaster exhaust, and much more to come
    Thats why i love my 96. i can adjust my headlights before and after i got my hids. all i had to do was adjust the mounting screw on the top to angle them down. But i did go with the clear projector lens and the 10k
  15. Oct 20, 2011 at 11:58 AM
    #35
    pudge151
    Sean
    Connecticut
    all tacomas have this feature
  16. Oct 20, 2011 at 12:00 PM
    #36
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    10,000 kelvin? they must be bright.
    you realize that you are losing almost half of the light produced by a 4,300 or 5,000 kelvin
    right?
    also the 2nd gen has adjustment screws as well for 2 dimensions of adjustment both height and inner and outer adjustment. 10 to 12k bulbs are purple or very close to it i bet it looks cool though:rolleyes:
  17. Oct 20, 2011 at 12:01 PM
    #37
    Scummy
    Phelan, CA
    so why does everyone complain about not being able to adjust there lights?
  18. Oct 20, 2011 at 12:03 PM
    #38
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    yearly safety inspections in virginia. i only spend 4 months out of the year in VA now, but 20 minutes from washington dc, and i've never run into any problems with police officers or the inspections.
    i do however, have to put covers on my off road lights, and disable the foglight anytime mod to pass the inspection, but that's all.
  19. Oct 20, 2011 at 12:04 PM
    #39
    Scummy
    Phelan, CA
    ya i wanted a deep blue tone
  20. Oct 20, 2011 at 12:11 PM
    #40
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
    I get flashed all the time and have even been involved in a road rage incident where the driver in front of me got out of his vehicle and threatened me. He would eventually run his truck into mine further down the road...on purpose...because of my 55w 6000!!!!!
