Are ICON Shocks squeaky?
Discussion in 'Suspension' started by Navar, Feb 6, 2014.
  1. Feb 6, 2014 at 6:09 PM
    Navar
    Navar [OP] Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Anyone with ICON coil over shocks experiencing squeaking? One of my local shops said they have had a lot of installs comeback because the shocks are squeaky after even just a month or two?
  2. Feb 6, 2014 at 6:10 PM
    Large
    Large Red
    You hardly hear of shocks squeaking, it's usually the uniballs in the UCAs but not uncommon.
  3. Feb 6, 2014 at 8:59 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Only time I had a squeak was when the front remote reservoir was rubbing on the rubber fender liner in the wheel well. Just had to move it out 2mm's and no more squeaking. I think my resi bracket got slightly bent during shipping, hence the touching.
  4. Feb 21, 2015 at 1:28 PM
    TEAMSDSU
    TEAMSDSU New Member
    Chula Vista
    15 Tacoma 4x4 TRD Off Road
    I just put some on my 2015 Tacoma 4x4 with only 17 miles on it. It worked fine for about 4 days with no noise, now I get a noise that I thought was one of the sway bar bushings or control arm bushings. It's not, I lubed those up and still heard a noise when i sat in the truck or moved a foot and applied the brake.
    Just read about the O-Ring on the shaft of the shock being the culprit. Many people say to spray the shaft down with motorcycle chain lube and let it tack up. I just now ran to the motorcycle shop and bought some Bel-Ray chain lubricant and sprayed them up.
    15 minutes later, no squeak, all solved.... It WAS the O-Ring on the shaft!!!!
    Hope that helps.
