Are Iridium spark plugs worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by devin.d88, Oct 8, 2021.
  1. Mar 23, 2025 at 7:23 PM
    #41
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I had them in mine for about 50,000 miles and had no problem and didn't see any performance benefit. I did go back to copper, but more because of the fear based on this forum. Will I go back, will see when the time comes to change. It is my opinion the longer you leave plugs in without changing them, you increase risk of having trouble removing them and sometimes damaging the cylinder heads threads.
  2. Mar 23, 2025 at 7:57 PM
    #42
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Jimmyh likes this.
  3. Mar 23, 2025 at 8:24 PM
    #43
    rockothetaco08
    rockothetaco08 Well-Known Member
    Unleaded gas really helped plug life.
    Jimmyh and crazytacoman like this.
  4. Mar 23, 2025 at 8:25 PM
    #44
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    AND our overall health! Imagine sitting in traffic in a city during gridlock in the mornings/afternoon commute with leaded gas? Terrible..
  5. Mar 24, 2025 at 6:33 AM
    #45
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    The other issue with running some plugs way beyond their suggested life is when the tip wears the gap increases, increased gap makes the coils work harder, heat up more and the potential for a coil failure goes up as gap increases. At some point coils will attempt to spark out the side of the coil through it's insulator to the valve cover, once that happens there's a misfire path and the coil is shot. This is a typical coil failure and it doesn't take large gaps to occur but excessive gaps tend to accelerate the process and often expose age related weaknesses in the coils. Once a coil goes bad any economy resulting from one type plug vs another is gone. If one doesn't want to change plugs as often iridium is a better choice since their electrode is much more resistant to electrode wear and gaps are more stable over the long term.
    eherlihy likes this.
  6. Mar 24, 2025 at 10:20 AM
    #46
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    OEM plugs went over 200k for me, so i put in stock oem plugs for the next 200k
