Are kings/Icon/Fox really worth it?
Discussion in 'Suspension' started by Humboldt_Homie, Mar 2, 2017.
What Front Shocks Do You Like/use Best?
  1. Bilstein 6112's
    54 vote(s)
    12.7%
  2. Kings
    164 vote(s)
    38.5%
  3. Icon
    64 vote(s)
    15.0%
  4. Fox
    84 vote(s)
    19.7%
  5. Bilstein 5100
    60 vote(s)
    14.1%
  1. Mar 3, 2017 at 4:36 PM
    #41
    Cougars
    Cougars Well-Known Member
    Pre loading the spring does not appreciably create a rougher ride. All coilovers lift the truck by preloading the spring the same way.
    You cannot say the king is a smoother ride than anything else without having ridden both of them.
  2. Mar 3, 2017 at 4:45 PM
    #42
    Sethhm0106
    Sethhm0106 Active Member
    Seth
    South Carolina
    2006 Spdwy Blue ACLB Tacoma TRD OR 4x4
    A Polaris Rzr or a Can Am Maverick?
    P8trit likes this.
  3. Mar 3, 2017 at 4:50 PM
    #43
    Cougars
    you cant compare a purpose built off road vehicle to an off the shelf truck. The UTV's have far more suspension travel than a tacoma.
    jq1604, Midknight and Sethhm0106 like this.
  4. Mar 3, 2017 at 4:53 PM
    #44
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Wow, you're an ass.
    "Springs store and release energy. They have no way to appreciably dissipate any energy. Thats where a shock absorber comes in. Shock absorbers, no matter the construction, dissipate energy in the form of heat."
    - Yeah, that's what I said
    "Emulsion shocks refer to a shock that has no separation between the gas and oil. There is no dividing piston between the gas and oil, like in a monotube."
    "DeCarbon is a brand name and thats it."
    - Yeah, I initially stated DeCarbon style shocks, but didn't say style everytime I typed it, because I was just giving a brief explanation not writing a patent application. v
    "Cartridge shocks" are not a type of shock
    - Yeah, they are. Listen carefully, a motorcycle fork is a the same thing as a coil over shock. If it makes you feel better you can call it a Coil Inside Shock.
    "Bypass shocks. These are either twin-tube or monotube shocks where fluid flow is allowed to "bypass" the piston. Fluid that bypasses the piston does not have to go through the damping circuit."
    - Yeah, check valves bypass fluid
    "The price difference comes down completely to aesthetics, you can have bland looking shocks, or shiny anodized shocks."
    -Ummm, you're just an idiot
    I stand by the simple description I offered to forum in the thread in the spirit of sharing and helpfulness, the basic information is correct it wasn't meant to be the end all discussion to everything ever known about suspension.
  5. Mar 3, 2017 at 5:37 PM
    #45
    Cougars
    You also said that 5100s are emulsion shocks. Which is wrong.
    Your brief explanation of decarbon style shocks is also largely wrong regarding damping style.
    Check valves do not bypass fluid. They simply decide what direction fluid is allowed to flow.
    Cartridge shocks are still not a type of shock.
    Lol go tear apart a shock from bilstein and a shock from king. You will find pretty much the exact same materials in the damping circuit. You have been so blinded by marketing, lies, and stupidity.
  6. Mar 3, 2017 at 7:23 PM
    #46
    ckblum
    ckblum Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    Didn't sound like an ass to me. Just a hell of a lot more right! Don't take it personally, I was gonna state the same corrections after reading your drawn out post but glad Cougar did first.
    P8trit, Sh0wst0pp3r, RH408RN and 3 others like this.
  7. Mar 3, 2017 at 7:47 PM
    #47
    desmodue
    2016 TRD OR AC
    I haven't torn a 5100 apart, typically OEM shocks are emulsion type. Minor technicality in that the effort was describing different shock types and maybe picked a wrong example, but whatever.
    That is exactly what a Decarbon style shock is. oil and gas in separate reservoirs, unlike emulsion style where the oil and gas are mixed
    definition of Bypass: change direction
    The cartridge fork is the predecessor of bypass shocks, the shim stack solution in a fork serves the same purpose as bypass valving. If you are so dim witted that you really think that a fork leg isn't a suspension component, I can't help you. Any moron can see a fork leg is just a shock with the spring inside.
    But, I'm done with a coward that has to create a new member account to hide his identity
  8. Mar 3, 2017 at 7:54 PM
    #48
    Justinlhc
    Justinlhc Not looking for a relationship
    Can I play?
    My penis is HUGE.
  9. Mar 3, 2017 at 8:03 PM
    #49
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
  10. Mar 3, 2017 at 8:16 PM
    #50
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    What about race Runners?
  11. Mar 3, 2017 at 8:56 PM
    #51
    Cougars
    OEM shocks are typically twin tube shocks as they are cheap to produce. In normal use there is no gas oil mix where the piston is active. Emulsion shocks have huge issues with oil foaming and mixing with the air, even the cost conscious OEMs arent willing to use them.
    Definition of bypass: a secondary channel, pipe, or connection to allow a flow when the main one is closed or blocked. Almost there buddy.
    The shim stack solution in a cartridge fork is no different then what any suspension manufacturer is selling. Bypass shocks add an additional position sensitive component to the shock, most cartridge forks are not position sensitive. When people are talking about bypass shocks on here they are talking about external bypass shocks.
    A fork leg itself isnt a shock or a spring, you got one point right. The shock and spring are inside the fork leg. In some cases the shock is in one fork leg and the spring is in the other leg. This still makes it a cartridge fork. Just because you put a spring inside of a shock doesnt mean you changed the type of shock it is. It still falls under either the monotube or twin-tube category. Hell some of them are even technically emulsion shocks. http://www.racetech.com/articles/CartridgeForks.htm
    The issue isnt that you provided information. Its that you provided wrong information to a member searching for correct information. The correct information can be easily googled and those links were provided in my initial response.
    Whether right or wrong, these forums are an echo chamber. Whoever is the loudest seems to win. Loudest being number of posts.
  12. Mar 3, 2017 at 9:02 PM
    #52
    Cougars
  13. Mar 3, 2017 at 9:20 PM
    #53
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    op just get you some ADS coilovers and all your problems will be solved.
    gillies66 and ckblum like this.
  14. Mar 5, 2017 at 3:06 PM
    #54
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    can am :D
  15. Mar 5, 2017 at 3:14 PM
    #55
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Fuck it! BP51's for the win. Why? Because of the cool green color they used.
    IMG_0042.jpg although you can't really tell the color in photos.
    Midknight and Humboldt_Homie[OP] like this.
  16. Mar 6, 2017 at 11:36 AM
    #56
    Humboldt_Homie
    Humboldt_Homie [OP] If you're not first, you're last.
    16 TRD OR DCLB
    Bilstein 6112 front, 5100's rear with blocks, camburg UCA, 17" XD's with 285/70/17 AT 3's and a blackout front grille.
    I've got those same UCA's. I was a bit worried at how angled they are but yours look to be angled about the same. Keep on Truck'n.
  17. Mar 6, 2017 at 7:35 PM
    #57
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
    How does a emu or dobinson shock nitrocharger shock hold up next to a bilstein shock ?
  18. Mar 27, 2017 at 9:52 PM
    #58
    Daxdagr8t
    Daxdagr8t Well-Known Member
    Socal
    07 prerunner
    None
    I have these, kind of overkill for the 90% of driving i do. But the other 10% its very very fun and well worth it.
    themanbearpig012 likes this.
  19. Mar 27, 2017 at 9:53 PM
    #59
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    yes just yes
  20. Mar 27, 2017 at 10:28 PM
    #60
    Zanone_taco
    Zanone_taco Tacoma bruhhh
    Blane
    Humboldt county
    2010 white access cab Trd off-road
    Need more...
    Honestly I don't know much about the suspension and there is some hostility here, but I did learn a lot reading this so thank you every one for the info!
