Are LED headlights worth the trouble
Discussion in '3rd Gen. Tacomas (2016-2023)' started by manualtrany, Apr 5, 2021.
  1. Apr 5, 2021 at 2:28 PM
    #41
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    :bananadead:
  2. Apr 5, 2021 at 2:28 PM
    #42
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    :jerkoff:
  3. Apr 5, 2021 at 2:30 PM
    #43
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    Nor would I. I wouldn't trade in an otherwise perfectly good truck just for a headlight upgrade.
    But if I were in the market for a new/new-to-me Tacoma, I would certainly hold out for one with factory LEDs.
    Kev250R, D500 and TacooSaucee[QUOTED] like this.
  4. Apr 5, 2021 at 2:30 PM
    #44
    farmtacoma
    farmtacoma Date Farmer
    Julia
    Twentynine Palms, California
    2021 Cement TRD OR DCLB 4x4 & 2018 Silver SR ACLB 4x2
    Well dealer vs factory means something to me. Apparently not to you. :)
    Let the haters hate
  5. Apr 5, 2021 at 2:36 PM
    #45
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I love my LEDs, but some people will tell you LEDs are garbage in general. Any LED in a dedicated LED housing will be better than an aftermarket LED in a halogen housing since the housing was literally designed for it. HIDs will produce a lot of glare for oncoming traffic.
    Kev250R, Doc62, Skydvrr and 1 other person like this.
  6. Apr 5, 2021 at 2:45 PM
    #46
    Kairide
    2020 White SR5
    I love my RX-350 HID retrofit. Your generalized statement, "HIDs will produce a lot of glare for oncoming traffic", is not correct. If it were true, all of the car manufacturers OEM HID headlights would not have been approved by NHTSA for use in the U.S..
    LongDistanceTaco likes this.
  7. Apr 5, 2021 at 2:46 PM
    #47
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Come to Texas. All TRD models come standard with the LED headlights.
    farmtacoma likes this.
  8. Apr 5, 2021 at 2:48 PM
    #48
    RedWings44
    Michigan
    You're right, I should specify HIDs put into halogen housings. All LEDs and HIDs placed into halogen housings are illegal for on road use per NHTSA. HIDs and LEDs in dedicated housings, on the other hand, work great.
  9. Apr 5, 2021 at 3:19 PM
    #49
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    unfortunately setf mafia has made this a 5k+ upgrade since you can only get it with the prem tech package
    RCBS likes this.
  10. Apr 5, 2021 at 3:25 PM
    #50
    Unorgnl-V
    Unorgnl-V Well-Known Member
    2017 superwhite TRD OR
    I was in the market for new headlights a few months back and after doing a bunch of research, watching of videos and reading of forums I ended up with the OEM leds from the 2020+ models. They are night and day difference than my 2017 headlights. In the past I have run HID in projector, factory halogen bulbs and DD leds in the projectors. The oem LED overall outperforms all of them.
  11. Apr 5, 2021 at 3:39 PM
    #51
    Kairide
    2020 White SR5
    His comment is correct, adding LED or HIDs in to halogen projectors is not legal. You should not put HIDs or LEDs in the factory halogen projectors. I believe @crashnburn80 has done extensive testing to this affect. Other than the Hikaris, aftermarket LED bulbs in the factory halogen housings are a no-no.
    Kev250R, crashnburn80 and Skydvrr like this.
  12. Apr 5, 2021 at 3:42 PM
    #52
    farmtacoma
    Julia
    Don’t buy from SET or GST mafias!
    Internet is a great invention
    Skydvrr likes this.
  13. Apr 5, 2021 at 3:53 PM
    #53
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2021 Tacoma TRD Off Road, 2019 Sahara
    I love my OEM LED headlights. That was a major selling point when I bought mine back in November. That and the long bed.
  14. Apr 5, 2021 at 3:57 PM
    #54
    farmtacoma
    Julia
    Same here ! LB + LED club !
  15. Apr 5, 2021 at 4:08 PM
    #55
    LongDistanceTaco
    LongDistanceTaco Well-Known Member
    Geoff
    California
    How would a HID produce more glare besides maybe having more light reflecting off surfaces? I would think an LED would produce more glare in the oem projector housings.
  16. Apr 5, 2021 at 4:41 PM
    #56
    wilddawg95
    wilddawg95 Well-Known Member
    Keith
    2017 Tacoma TRD Offroad 4X4
    The light output is an improvement over stock but is it enough to justify the $$$$$$$$. I mainly changed mine for the color. Wanted them to match my Rigid Fogs and light bar. They say they don't work well up north due to not generating enough heat to melt ice and snow on headlights. They work fine in South Alabama!
  17. Apr 5, 2021 at 4:52 PM
    #57
    RedWings44
    Michigan
    I should specify that this is referring to HIDs in halogen housings.
    It depends on the LED. The higher end LEDs do their best to mimic the position of the halogen filament. The reflective surfaces of the housing are optimized for the exact position of the halogen filament. HIDs, on the other hand, have no filament. The entire bulb itself is the filament given that it is a gas and therefore it does not do a good job, at all, of mimicking the position of the filament. The light source is way too close to the reflective surfaces and thus, produce the glare.
    As I said, it depends on the LED. Lower end LEDs don't even attempt to mimic the halogens at all.
  18. Apr 5, 2021 at 5:05 PM
    #58
    LongDistanceTaco
    Geoff
    California
    Ahh makes sense. Would any of the glare be correctable with aiming the headlights further down?
  19. Apr 5, 2021 at 5:23 PM
    #59
    RedWings44
    Michigan
    Not really, to my knowledge. Even with the shade in the projector housings, the proximity of the light source to the reflector would cause light to not be emitted as intended and so the shade would be less effective. Then you'd concentrate your actual beam pattern to the front of your vehicle and not do yourself any favors.
  20. Apr 5, 2021 at 5:54 PM
    #60
    GumShoe
    GumShoe Well-Known Member
    New Mexico
    MGM 2016 Tacoma SR V6 4x4 DCSB
    I compared my stock 2016 projector to my cousin’s oem 2021 sport led headlights, and the 2021 led headlight are leagues above. It’s super bright but not blinding.
