Are LED headlights worth the trouble
Discussion in '3rd Gen. Tacomas (2016-2023)' started by manualtrany, Apr 5, 2021.
  1. Apr 7, 2021 at 1:34 PM
    #121
    Vinegaroon9
    Vinegaroon9 Member
    2020 Tacoma TRD Off Road
    I just wanted to jump on the bandwagon here...
    I do a lot of night driving in remote areas, and I am pretty obsessed with headlight performance. My 2020 OR has the factory LEDs, and they are simply the best factory headlights I have ever encountered on any vehicle, ever. Once you experience them you will never want to drive with dim/yellowish halogen headlights again.
    I supplemented the factory LED headlights with a grill mounted Rigid lightbar wired to go on with the high beams, and for all practical purposes that setup has pretty much the same visibility as driving in the daytime.
  2. Apr 7, 2021 at 4:26 PM
    #122
    pinktaco808
    pinktaco808 Hot Steppa
    Led for trd model only?
  3. Apr 7, 2021 at 4:29 PM
    #123
    CDV
    CDV Well-Known Member
    SD
    2021 TRD Off Road
    Best headlights I've ever drove behind are my 2021 OEMs, I actually kinda enjoy night driving again.
  4. Apr 7, 2021 at 4:32 PM
    #124
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have auxbeam led replacements for stock assembly and fog lights . Plenty bright and going on two + years no issue
  5. Apr 9, 2021 at 5:43 PM
    #125
    ExitCalypsan
    ExitCalypsan Active Member
    2021 AC SR5 4x4 MGM
    Is the LED package available to order with an SR5? Or is it only for the TRDs?
  6. Apr 9, 2021 at 5:55 PM
    #126
    tclavell
    Troy
    Phoenix, AZ
    G70
    You can make it work, PM @Puppypunter
    ...but not available from factory. You’d need to DIY
  7. Apr 9, 2021 at 6:26 PM
    #127
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I enjoy the adventure of guessing where the road is at night with my stock 2018 headlights.... But really, what was toyota thinking with the halogen headlights... my kids have dollar store flashlights that are brighter.
  8. Apr 9, 2021 at 6:29 PM
    #128
    soloz2
    soloz2 Member
    21 TRD Sport Premium
    I have done a couple HID retrofits and purchased a couple vehicles with OEM LED headlights. spending a little bit more for the OEM LED or HID headlights in vehicles is absolutely worth it. Less hassle than doing a retrofit for nearly the same output. I will not have another vehicle without either the better headlights from the factory or a proper retrofit.
  9. Apr 9, 2021 at 6:43 PM
    #129
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    YES for led bulbs
    farmtacoma likes this.
  10. Apr 9, 2021 at 10:04 PM
    #130
    farmtacoma
    farmtacoma Date Farmer
    Julia
    Twentynine Palms, California
    2021 Cement TRD OR DCLB 4x4 & 2018 Silver SR ACLB 4x2
    Well said!!!
  11. Apr 10, 2021 at 6:23 AM
    #131
    Great Dane
    Great Dane Well-Known Member
    Dane
    Georgetown, Ky
    2021 TRD Sport 4x4 Access Cab.
    I ordered mine with the factory L.E.D. headlights, and I couldn't be happier with the light output.
  12. Apr 10, 2021 at 8:03 AM
    #132
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I spent ~$1,600 to retrofit my 2016 with OEM LEDS and I thought it was money well spent. $500 is crazytown cheap. I don't plan to ever purchase another vehicle without the OEM LED option if it's available.
  13. Apr 10, 2021 at 8:05 AM
    #133
    farmtacoma
    Julia
    Agree worth every penny
    and for $487 that I paid on my 2021 - agree with you ! Best money ever
  14. Apr 17, 2021 at 8:55 AM
    #134
    My4thTacoma
    My4thTacoma Pain Don't Hurt
    St Petersburg, FL
    2024 TRD Sport 4x4 (Solar Octane)
    that is a beautiful truck!!!!
  15. Apr 17, 2021 at 9:16 AM
    #135
    stinger86
    stinger86 Well-Known Member
    San Diego, CA
    2016 Double Cab Limited
    If you don’t mind me asking, what parts (other than the OEM headlights) did you need? How painful was the retrofit?
  16. Apr 17, 2021 at 9:17 AM
    #136
    My4thTacoma
    St Petersburg, FL
    I wish I had purchased a truck with the factory LEDs but that never even crossed my mind until after i bought my truck and joined this forum a few months ago. My SR5 came with the halogen projectors that were just horrible. After doing tons of reading here I ended up buying the upgraded Tungsram Nighthawk Xenon halogens. They were MUCH better than the factory bulbs and they put a lot more light on the road for sure. But I still wasnt happy so after reading some others that recommended the new Hikari Acme-X bulbs I bought those and now I am satisfied. They were a breeze to install and they put just as much light on the road as the Tungsram bulbs did, plus the color is white, not yellow. I just ordered another set for the high beams too. So if youre like me and unsatisfied with your projector halogens, I could not recommend the Hikari's more. They are your best option besides upgrading to the factory LED housings.
    Kev250R likes this.
  17. Apr 17, 2021 at 9:31 AM
    #137
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Lamps and the adapter harness. I used he who shall not be named (7 weeks on a promised 2 week delivery time, but the harnesses came and were exceedingly high quality).
    Less painful than you’d thing. The hardest part was releasing the bumper clips where it meets the fender. It took me maybe 2 hours start to finish. Tape every surface for protection. I taped all mine and removed a small bit at the end for fitting and had to reposition a lamp and put a 1/8” mark in a lamp in a location you’d never see and I’m still talking to myself about it.
    stinger86[QUOTED] likes this.
  18. Apr 17, 2021 at 9:31 AM
    #138
    Syncros
    Syncros Well-Known Member
    I've found my halogens do a fine job and won't be messing with them. Couldn't care less about the aesthetics.
  19. Apr 17, 2021 at 9:38 AM
    #139
    5nahalf
    Erik
    Minnesota
    I like that they have put driver in the bulb housing. I never liked having a driver box hanging off the back of the bulb by a wire.
  20. Apr 17, 2021 at 9:40 AM
    #140
    farmtacoma
    Julia
    :rofl:
