Are Longer Brake Lines Needed?
Discussion in 'Suspension' started by lickskillet, Jan 3, 2015.
  1. Jan 3, 2015 at 4:00 AM
    lickskillet
    lickskillet [OP] Well-Known Member
    Land Of Big Sticks
    2014 Tacoma
    When doing a 3" spacer lift up front and an AAL in the rear, are extended brake lines needed?
  2. Jan 3, 2015 at 4:16 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Depends. If you plan to do offroading...then yes i would be getting extended lines. If its going to stay on roads....its 50/50. I would do it at some point but not something you had to do right this second or risk damage type thing
  3. Jan 3, 2015 at 8:29 AM
    lickskillet
    Land Of Big Sticks
    2014 Tacoma
    Thank You
  4. Jan 3, 2015 at 8:34 AM
    TacomaRobert
    TacomaRobert Well-Known Member
    If off-road could be expected to cause a problem, then couldn't an unexpected problem -- although unusual -- happen on-road?
  5. Jan 3, 2015 at 8:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How often do you fully articulate your suspension on pavement or float a tire over an obstacle?
    If the spacer is one that goes under the top hat and preloads the coil, you won't need extended brake lines since the range of motion is the same as stock. If it's on top of the top hat, you should consider getting them since it will allow your front tires to droop more. In the rear, if you are still using stock length shocks, you won't need new lines since they are still the droop limiter so your lines can't be stretched any more than in stock configuration.
  6. Jan 5, 2015 at 12:28 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    If the OP is going off-roading then I hope a 3" spacer lift isn't his final option.
  7. Jan 5, 2015 at 12:30 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    X2
  8. Jan 5, 2015 at 2:05 PM
    lickskillet
    Land Of Big Sticks
    2014 Tacoma
    Turns out the spacer lift is way back ordered and with all the negative feedback I have seen since I ordered it, I cancelled it. Want to do a toytec billy lift but they too can't be found. Might have to do a OME 3" kit
  9. Jan 5, 2015 at 2:06 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    OME is good. Light years better than spacer lift.
  10. Jan 5, 2015 at 2:09 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  11. Jan 5, 2015 at 2:10 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Why wouldn't you?
    They are inexpensive and offer nothing but benefits, Longer for more suspension flex, Steel braided for better pedal response.
  12. Jan 5, 2015 at 6:00 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    I just got off the phone with wheelers and spoke to Dan. I'm only getting a 1.5in icon progressive AAL in the rear and he said wouldn't need it. Only recommended for major flexing and since I've only been off-roading once and it wasn't major flexing just dirt trails. I decided to not get it yet. But I'll prob be getting them on in the future once I upgrade my brakes.
