Are most people running load range C tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dss8653, Mar 29, 2023.
  1. Mar 29, 2023 at 8:00 PM
    #41
    AmateurTaco1313
    AmateurTaco1313 Dreaming of the next build
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Mickey Thompson Baja boss AT in load E. Ride great, makes me question and laugh at all the guys claiming “e load is too rough”
    dss8653[OP] likes this.
  2. Mar 29, 2023 at 8:11 PM
    #42
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Unfortunately most tires I'm after aren't available in anything but an e load if they are available in a c they are damn well hard to find. So I stuck e's on but shopped around to find lighter options. Also easier to replace if you damage one.
    Another thing to point out is tread depths are not always equal when co paring an sl/p to an E of equivalent size. The wildpeak at3w specifically has alot more tread in an E load.
  3. Mar 29, 2023 at 8:13 PM
    #43
    DuffyBank
    DuffyBank Well-Known Member
    Where you are driving will be the determining factor.
    I work in the bush on unmaintained roads and overgrown trails and carry a lot of weight. 235/85/16 E Duratracs.
    If you won't be encountering sticks and rocks that will attack your side walls and you aren't carrying heavier loads, then a C or passenger tire may be fine for you.
  4. Mar 29, 2023 at 8:29 PM
    #44
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I got rid of Es and now run Ps. Much happier with mostly road driving.
  5. Mar 29, 2023 at 8:33 PM
    #45
    Bishop84
    Bishop84 Well-Known Member
    I run SL winters and E summers. It's noticeable every swap.
    It's not uncomfortable, but you feel potholes and bumps a lot more.
    Especially at 40psi which they are supposed to be at for load rating.
  6. Mar 29, 2023 at 8:46 PM
    #46
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I have to run E rated KO2's due to weight. The suspension makes up for a lot of it but you still feel some potholes and of course road noise.
    Slick Taco, CGPickup and andthen like this.
  7. Mar 29, 2023 at 9:08 PM
    #47
    johnnytwotimes
    johnnytwotimes Well-Known Member
    SoCAL
    2021 TRD OR DCSB
    Running 265/75/16 ko2s on a stock TRD OR. I drive mostly on pavement, definitely took a hit on mpgs and truck feels sluggish because of the weight on these tires should have went with wildpeaks SL but I got a decent price for the set.
  8. Mar 29, 2023 at 9:57 PM
    #48
    MGMDesertTaco
    How much off roading vs street driving do you actually do?
    I'm in this same dilemma right now looking at 16" and 17" wheels comparing weights, offsets, colors, ect with 285/75/16 vs. 285/70/17.
    The factory TRD OR wheel and tire weight is roughly 60lbs.
    If I do 285/75/16 I've got to pick E rated:
    Toyo AT3 55lbs LT 285/75/16
    Toyo RT Trail 61lbs LT 285/75/16
    BFG K02 59.6lbs LT285/75/16
    If I do 285/70/17 I can do SL, C, or E rated at various weights...
    BFG K02 50-51lbs LT285/70/17 C
    Toyo RT Trail 56lbs LT285/70/17 C / Toyo RT Trail 58lbs LT285/70/17 E
    Toyo AT3 47lbs SL, C 56lbs, E 54-56lbs LT285/70/17
    I prefer the Toyo RT Trails and Toyo Open Country AT3's. I've driven a new Tacoma with the AT3's on black SEMA wheels and they were buttery smooth and quiet. I suppose you could throw 275/70/17 in the mix too.
    Pick a wheel (TRD beadlocks, OEM SEMA wheels, Factory Style Wheels, Method, SCS, KMC, ect) and add the weights together. Most of the wheels I like are pig heavy unless I go 16", but then the E rated weight adds back up. :annoyed:
    MPG and stopping performance doesn't matter; it's all about how she looks rolling down the road right? :cool::rofl::mudding:
    Oskie_78 likes this.
  9. Mar 29, 2023 at 10:02 PM
    #49
    Pengowirr
    Pengowirr Well-Known Member
    2018 TRD Off Road Manual Transmission Cement
    265/75/r16 Cooper ST MAXX
    Anyone run C load on 33s with 16” wheels?
  10. Mar 29, 2023 at 10:04 PM
    #50
    Pengowirr
    I got 16s and even though I think they look much better than 17s. And they should perform a bit better off road too, the tire selection is very limited. Any big size and you’re gonna be stuck with LTs = E rating.
    if I could do it over again, I’d go with 17s. Simply for the choices.
    MGMDesertTaco[QUOTED] likes this.
  11. Mar 29, 2023 at 11:10 PM
    #51
    erok81
    erok81 Well-Known Member
    Imposter
    I run C’s. That was one of my primary reasons for getting the tires I did. Went from D’s to C’s and could definitely tell they were squishier. Thought something was loose the first time I drove it. :rofl:
  12. Mar 31, 2023 at 1:18 PM
    #52
    dss8653
    dss8653 [OP] Member
    Dan
    Bartlett, TN
    2017 TRD Pro Tacoma - Cement
    Westcott Design Collar lift/Icon AAL/Toyo 285/70/17 OC RT Trail
    Good info, thanks
  13. Mar 31, 2023 at 1:20 PM
    #53
    dss8653
    dss8653 [OP] Member
    Dan
    Bartlett, TN
    Thanks! Ya, my off-roading is limited and nothing too extreme. I’m leaning towards C but hope it doesn’t turn around to bite me.
    DRAWN and Junkhead[QUOTED] like this.
  14. Mar 31, 2023 at 1:21 PM
    #54
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    IMO C is a great choice. It’s not that much heavier than SL. Plus, with most LT tires you get a bit deeper tread vs SL.
  15. Mar 31, 2023 at 1:26 PM
    #55
    dss8653
    dss8653 [OP] Member
    Dan
    Bartlett, TN
    Right now my off-roading is minimal. However, I’m about to be an empty nester and plan to do some excursions!
  16. Mar 31, 2023 at 1:32 PM
    #56
    Samsquanch
    Samsquanch Member
    Todd
    Minneapolis, MN
    Larson
    I’ve run KO2s in both E and C ratings. I don’t do a lot of off-roading but haven’t had a since issue going to C rated. Definitely prefer them for the mostly on road driving I do.
    dss8653[OP] and johnnytwotimes like this.
  17. Mar 31, 2023 at 1:44 PM
    #57
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    All this tire talk and no love for a stock size tire. I run the Toyo Open Country AT III in 265/65-17 XL in at 38lbs... same weight as the Open Country H/T's they replaced. They are very well mannered and fairly quiet on the highway (90% of my driving) and I was quite surprised to find them very capable off road...My highway mileage stays between 21 & 23 most of the time. They've been on for 2 years and have become my favorite tire.
  18. Mar 31, 2023 at 2:39 PM
    #58
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    No regrets with mine, and I put them through the paces all year round.... :tinfoilhat:
    montijo505 likes this.
  19. Mar 31, 2023 at 3:20 PM
    #59
    DuffyBank
    If we cared about gas mileage we wouldn't be driving Tacomas
  20. Mar 31, 2023 at 3:27 PM
    #60
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    E rated tires are too much IMO, unless your truck is heavily loaded down or primarily a rock crawler. I run c rated dutaracs in 265/75/16. They have been great and I off road frequently in the rockies on trails that are demanding on tires. My previous tires were two sets of e rated ko2s. The ride quality was abysmal, my mileage was worse and they cause more wear and tear on all the suspension components, it’s a lot more rotating mass than c rated tires. I will not go back to E rated tires as long as I use my truck as a DD, off-roader and long distance hauler. Unless your truck is primarily an off-road toy E rated tires are overkill. I have never had a puncture on my duratracs and I’m on my second set, 50k on both. I wish I could find more c rated sizes in 265/75/16 as it is my preferred tire size.
    Featuring_Kev and petethemeat like this.
