ARE MX Long Bed Cap
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by youngsurfrat, Jul 1, 2019.
  1. Jul 1, 2019 at 5:53 AM
    youngsurfrat
    youngsurfrat [OP] Well-Known Member
    Sullivan Ny
    2017 Tacoma TRD Sport
    The cap is located in Middletown 10940 NY at the moment.
    time to go bigger. Selling a 1year old ARE Mx cap. Carpet interior. 2 hockey puck touch lights inside.
    Are roof rack. (I keep the kayak/ski accessories) you get the bars.
    There is 1 imperfection. (Where the hockey puck lights were installed, the paint (on the outside) is slightly raised. No leaking issues what so ever.
    I also have a bed liner carpet and a platform with a memory foam
    Mattress we can talk about if your interested.
    Looking to get $1600 for the cap. Can deliver within tri-state area and help mount (minus electrical wiring)
    Looking to get another 200for carpet and 100 for platform.
    Obviously not selling carpet if i still havent sold the cap or platform. Everythings gotta go!
  2. Jul 2, 2019 at 3:15 AM
    youngsurfrat
    Sullivan Ny
  3. Jul 2, 2019 at 7:15 AM
    Bannock-pt.
    Bannock-pt. Member
    Thanks man. That is right around the corner from my house. However my truck is silver or I would snatch that up in a heartbeat.
  4. Jul 8, 2019 at 3:23 AM
    youngsurfrat
    Sullivan Ny
  5. Jul 8, 2019 at 4:58 AM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Do you have a good pic of the raised paint in top?
  6. Jul 8, 2019 at 9:24 PM
    youngsurfrat
    Sullivan Ny
    As of now, i do not. Have another double shift tomorrow, can post it up Wednesday morning
  7. Jul 14, 2019 at 3:06 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Still available?
  8. Jul 14, 2019 at 9:28 PM
    youngsurfrat
    Sullivan Ny
    Yup
  9. Jul 20, 2019 at 3:07 AM
    youngsurfrat
    Sullivan Ny
    Bump 1100$ for everything
  10. Jul 26, 2019 at 6:01 PM
    TacoTony430
    TacoTony430 Member
    2016 Quicksand DCLB TRD Sport
    Ammo can bed storage Derped emblems and grill
  11. Jul 26, 2019 at 8:11 PM
    crazyfingers
    Chuck
    Annapolis, MD.
    So do you have a pic of the top with the bad paint spots on top?
  12. Jul 27, 2019 at 9:38 PM
    youngsurfrat
    Sullivan Ny
    I apologize... totally forgot! I’ll get them up tomorrow morning
    crazyfingers[QUOTED] likes this.
  13. Sep 25, 2019 at 8:09 AM
    crazyfingers
    Chuck
    Annapolis, MD.
    PMed you.
  14. Nov 8, 2019 at 5:17 PM
    youngsurfrat
    Sullivan Ny
    Hey TW! I apologize for the lack of responses as of lately... unfortunately things didnt go as planned back when i first posted this. And i was forced to keep the cap.
    Earlier in the week the truck was totaled. (Water damage)... the cap is back up for sale, pics are limited. Here’s another 2 pictures of the cap. You’ll see on the roof theres a paint buldge from the lights installed on the inside. Zero leaking issues. You can probably throw a touch of epoxy on it so the paint doesnt eventually chip away. There’s also a small rub mark from just moving it. Other than that, its in fantastic condition.
    Cap has carpet. Factory light, 2 additional hockey puck touch lights (battery operated)
    And an ARE roof rack with the tear drop bars.
    $1100 for everything.
    cap is located in sullivan county NY. Cochecton
  15. Nov 8, 2019 at 5:18 PM
    youngsurfrat
    Sullivan Ny
  16. Nov 9, 2019 at 4:14 AM
    TacoTony430
    TacoTony430 Member
