Are my bumpstops too close to the frame?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Italia234, Nov 28, 2017.
  1. Dec 6, 2017 at 8:35 PM
    #141
    Italia234
    Italia234 [OP] Well-Known Member
    Nick
    Tucson
    TRD offroad
    Lucky!
  2. Dec 6, 2017 at 8:38 PM
    #142
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    :fingerscrossed::fingerscrossed::fingerscrossed:. I’d happily play the shipping though.rather than buy new springs, or try to make a Frankenstein pack by adding a leaf.
    Italia234[QUOTED][OP] likes this.
  3. Dec 6, 2017 at 8:40 PM
    #143
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    As long as your bed is always loaded down you will love the Expos. I had Expos for a few years when I had my bedrack and RTT. They performed great.
    Dan8906 and Italia234[OP] like this.
  4. Dec 6, 2017 at 8:43 PM
    #144
    Italia234
    Nick
    Tucson
    TRD offroad
    Tent bedbars and sliders might still be over sprung but I’d rather be over then under
  5. Dec 6, 2017 at 8:44 PM
    #145
    Italia234
    Nick
    Tucson
    TRD offroad
    Yeah exactly!
  6. Dec 6, 2017 at 8:58 PM
    #146
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    I have the EXACT setup as you and thought I was the only one with this problem of having no clearance..... I called all pro and they kind of beat me around the bush .. Looking for a shackle flip and trying to unwarranty it.
    And it has been this way since I installed them, I think they forgot to arch the springs.
  7. Dec 8, 2017 at 2:27 PM
    #147
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Is anybody actually having problems with the Expo leaf pack or just the standards? I have a set of Expos on order and now I'm wondering if I need to cancel and go to Dakars. I carry around 300 lbs daily driving and maybe 600-800 lbs when I camp and wheel it.
  8. Dec 8, 2017 at 2:42 PM
    #148
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I got a set of Expo 2.0s for the limited time they sold them. I got them because I carry a little more weight than most and the springs are crap. With just my truck vault and a CBI rear bumper with tire and rotopax they are nearly flat. Honestly, I think they gave me a set of normal expos but they keep telling me they are the 2.0s.
    Mademan925 likes this.
  9. Dec 8, 2017 at 3:01 PM
    #149
    Pigpen
    Dan
    Northwest Montana
    Cancel and get Dakars
    1largemouth and IronPeak like this.
  10. Dec 8, 2017 at 3:05 PM
    #150
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    Op, I love my expo leafs, I've had them loaded down with well over 500 lbs before and still had plenty of up travel. Unloaded they are a bit stiff but I've come to appreciate that. They still flex well unloaded or not. In Tucson too if you ever need a hand
  11. Dec 8, 2017 at 3:23 PM
    #151
    Pigpen
    Dan
    Northwest Montana
    I have Dakars with the AAL. I carry over 500 pounds nearly full time. Much more on trips or when working and/ or towing. I had to add spacers up front because I had too much rake in the rear. I have to REALLY load her down to see any sag. Rides great on road too. I drive a lot of shitty roads and passengers often comment on how nice my truck rides.
    Edit: my measurements are 25" center of hub to fender in rear and 23.5" up front (I have a 1/2" body lift on the cab).
    05tacomabro likes this.
  12. Dec 8, 2017 at 3:47 PM
    #152
    zscott
    Zach
    Utah
    Dakars are a great option if all you care about is load carrying. I had them for over 2 years and carried loads from 100 up to over 1000 lbs with them. They served me well and are a work horse leaf spring. The only downside to Dakars is that due to the fewer number of leafs and the thickness of the leafs and overload leafs they have they do not flex as well as a spring with fewer, thinner leafs does such as all pro, deaver, or atlas type leaf packs. When I first put my all pros on (with the same shocks as my Dakars) I was blown away at the difference in ride quality. It is much better for my type of driving (probably doesn't make a big difference in low speed type crawling).
    If all pro had the weight carrying part of their springs figured out they would have a stellar product.
  13. Dec 11, 2017 at 8:52 PM
    #153
    Dan8906
    Daniel
    Concord, California
    Did they give you a invoice or something when they sent out? They told me Friday but I haven’t heard from them. Emailed Friday and today with no response
  14. Dec 11, 2017 at 9:17 PM
    #154
    Italia234
    Nick
    Tucson
    TRD offroad
    Yeah got an invoice and everything but I also paid 130 for shipping. Mine went out Friday as well tracking says it will be here tomorrrow.
  15. Dec 11, 2017 at 9:28 PM
    #155
    Dan8906
    Daniel
    Concord, California
    Forsure, well hopefully I get a surprise tomorrow and line show up too!
  16. Dec 11, 2017 at 9:28 PM
    #156
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Did you have to send the standards back to them?
  17. Dec 11, 2017 at 9:48 PM
    #157
    Dan8906
    Daniel
    Concord, California
    They told me I would have to send mine back.
  18. Dec 12, 2017 at 6:32 AM
    #158
    Italia234
    Nick
    Tucson
    TRD offroad
    Yeah they asked me to send mine back also.
  19. Dec 12, 2017 at 6:50 AM
    #159
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    So did you pay shipping to send them back as well? That’s really shitty if they sold you a leaf pack and told you it would work, it doesn’t. Then they say oh well you need this pack and have to pay shipping for the new one and to send yours back. Looks like I won’t shop with All Pro.
    Glenn_R likes this.
  20. Dec 12, 2017 at 7:20 AM
    #160
    Italia234
    Nick
    Tucson
    TRD offroad
    No they said they would send me a label for the returned ones... I think I just paid shipping on the replacement ones. It was a wash for me. If I would have bought a new pack somewhere else I would have been out the money. the shipping cost is basicly the price difference from the standards to the expos. They didn’t charge me the price difference.
