Are my LCA bushings shot? (Video)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by @old.man.adventures, Dec 19, 2017.
  1. Dec 19, 2017 at 11:56 AM
    @old.man.adventures
    @old.man.adventures [OP] Well-Known Member
    2015 DCSB
    Icon Stage 4 Delta Joint
    So Im getting ready to install an Icon Stage 4 kits and am trying to diagnose a clanking sound when I hit dips. I want to make sure any issues are covered under warranty before I put the lift on. I notice the LCA moves in the video. Ive seen this in other videos so just wondering if the lateral/vertical movement at the pivoting point is too excessive or if its normal.
    ChadsPride likes this.
  2. Dec 19, 2017 at 12:00 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Lose cam tabs probably​
  3. Dec 19, 2017 at 12:19 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Looks perfectly normal to me. The LCA cams only tighten the pivot axle and should never cinch down lateral movement of the LCA on the pivot axle. There are many creeks, pops and moans from these IFS front ends. Sway bar is a common culprit since it stores the energy in a torsional fashion and will make noise if the mounts are loose or not replaced on their proper sides. Control arm (LCA and UCA) bushings are also a common culprit (use anti-seize, like it's your trademark when you are in their installing the lift). Brake pads when worn will also made pops and clicks adjusting from forward and reverse (if you back into or out of your driveway and then pull out in the opposite direction, they will click when they get past roughly 10k miles). This will pop in the morning when you leave and first apply the brakes. Some have mentioned on here in reference to body mounts by the radiator, but I think this was only for third gen. Finally, spring seat will pop and creak over time depending upon the environment where you live. Some say fluid film, others use Teflon spray. Whether it is arid high desert or humid southeast, I have plenty of creaks and moans that are a PITA to diagnose where. It seems like I get the time to chase them down only after it rains hard enough that they go away and all is quiet.
    Anywho, LCA looks fine.
  4. Dec 19, 2017 at 12:44 PM
    @old.man.adventures
    2015 DCSB
    Thanks for your insight. Curious as to how one gets an accurate alignment if this much lateral movement at the LCA pivot point is normal? Wouldnt that much play affect the caster readings?
  5. Dec 19, 2017 at 2:23 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I am no expert, but I understand the caster to be adjusted between the upper and lower ball joint. The stock UCA at rest, will not allow for adjustment and keeps caster at 0*. Some aftermarket a built offset or adjustable (SPC LR for me as an example). The caster is "dialed in" with the adjustment of the rectangle washer. The lower ball joint remains stationary and becomes the fulcrum for caster at rest. The play of the LCA where it mounts to the frame and pivots off the cam bolts keeps in from binding and would obviously deviate from a caster reading at rest. However, your alignment is done stationary where your LCA rest and not dynamically taking into account the bump like you videoed. The variable I think you are questioning is "does the LCA always come back to rest at the some point?" My answer is, I believe so.
  6. Dec 19, 2017 at 2:32 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I also just noticed to hit the bump going in different directions. All your alignment adjustments are based off forward movement of the vehicle and different rules of physics apply when the force is applied in the opposite direction. This will cause the LCA to act differently. I have 4* caster on my wheel which would translate to -4* when cycling the suspension in reverse. This could also be the factor of seeing the play in the video.
  7. Dec 19, 2017 at 2:40 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    You're LCA bushings are bad. They should be replaced before you do anything else.
  8. Dec 19, 2017 at 4:15 PM
    @old.man.adventures
    2015 DCSB
    That's what I'm afraid of. Thing is they are rubber and movement is expected. I just don't know how much movement is too much. I'm hoping they aren't shot as I only have 37k on the truck.
  9. Dec 19, 2017 at 5:52 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Any tech during an alignment will tell you if they are shot. I figured a ‘15 wouldn’t have enough abuse with stock suspension to ruin them. Let us know, what you find.
  10. Dec 19, 2017 at 6:02 PM
    @old.man.adventures
    2015 DCSB
    Taking it to the stealership tomorrow. If it's bad then I guess the lift install will have to wait because even if they confirm the part failed pre-modification they won't do the repair once parts come in if I start the install. Stupid I know...
    zippsub9[QUOTED] likes this.
  11. Dec 20, 2017 at 8:47 AM
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    Check your swaybar bushings. I had a clunk when going over bumps and it turned out I had a little play in them.
  12. Dec 20, 2017 at 9:21 AM
    @old.man.adventures
    2015 DCSB
    Yeah those seem fine. Now I'm more or less trying to find out if the Lower arm play near the alignment cams is normal.
  13. Dec 20, 2017 at 9:23 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  14. Dec 20, 2017 at 11:51 AM
    @old.man.adventures
    2015 DCSB
    So just got word from the dealer and apparently that kind of movement is normal. The bushings are supposed to flex. As long as they are not wallowed out or cracked then they are fine.
    zippsub9 likes this.
  15. Dec 20, 2017 at 11:58 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Not to mention, you will get steering vibration and wobble with worn LCAs.
  16. Dec 20, 2017 at 12:02 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Yeah if you have a steering vibration or wobble, and also check if you’re wheel does this:
    https://m.youtube.com/watch?v=83Pw3V8pMeI
    This is all the current symptoms on my truck with bad UCA and LCA bushings
