Are my leaf springs shot?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJack09, Mar 15, 2010.
  1. Mar 15, 2010 at 4:04 PM
    TacomaJack09
    TacomaJack09 [OP] Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    These are pics with essentially nothing heavy in the back. There is a small roll of carpet, some can soups, qt of oil, tow chain, and some shoes. To me it seems to be sagging?
    What do you guys think? What should I do, I'm on a budget.
    The junkyard around here sells the leaf springs for 14.99 a piece and there is a 1999 tacoma 4x4 base model sitting down there now, I was thinking of getting those but I don't want to run into the same problem months down the road. Is there a way I can combine the two leaf springs and make one stronger one??
    The images should increase in size if you click on them.
  2. Mar 15, 2010 at 5:46 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
  3. Mar 15, 2010 at 5:48 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yes they are. Mine look exactly the same.
  4. Mar 15, 2010 at 6:11 PM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Thanks for the response guys! Any recommendations??
  5. Mar 15, 2010 at 6:14 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    someone shot your leaf spring? you'd better call the police
  6. Mar 15, 2010 at 6:31 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    wheeler's offroad, the sell some nice replacements, with stock, 1.5, and 2.5 worth of lift. pick your poison.
  7. Mar 15, 2010 at 8:04 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    OME springs.
  8. Mar 16, 2010 at 5:40 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    So eventually I would like to buy billy 5100's all around and get that two inch lift, but right now I can't afford them and there are out of stock. Should I go with stock height leaf springs and get shackles when I get the money for the Billy's or go for the Leaf spring that gives me 2" of lift and buy some coil-over spacers?
    What would you guys suggest doing??
  9. Mar 16, 2010 at 6:20 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Its safe to ride on flat leaf springs right? I'm not going to fly around a corner and loose the a$$ end on this thing am i?
  10. Mar 16, 2010 at 6:47 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Can I go with the AAL's or do I need to buy a replacement Leaf Spring Sorry for the NOOB questions... But the AAL's are so much cheaper!
  11. Mar 16, 2010 at 7:28 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i wouldn't try to add a leaf to your already flat pack. ....they tend to work much better on packs that still have life in them.
    your best bet is to save until you have the money to get new leaf packs.
  12. Mar 16, 2010 at 7:30 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    The AAL wont really help your leafs, and they wont give the proper lift bc of the shot leaf pack. So you pretty much need a new leaf pack, It will give you a way better ride also man! Along with the 5100's.
  13. Mar 16, 2010 at 7:32 AM
    ETaco23
    Evan
    PNW
    Hey there JCT!! whats happenin? what ever happened to getting some new photos of your truck..:D
  14. Mar 16, 2010 at 7:37 AM
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    Hey, How did you get pictures of my Taco??? :)Same problem with my 04 TRD DC. I also have "axle wrap" which i believe is from the dead leaf pack as well. I'm saving up for a set of aftermarket stock height leaf packs. 'Correct me if i am wrong. My understanding is as long as i am not hauling heavy loads that no real damage will be done to the truck as i save up. Axle wrap and leaf sprints are connected and it is not going to damage the drive train as i weight.Thanks
  15. Mar 16, 2010 at 7:43 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Sweet, I was just about to ask this. Mine are shot as well. I put 240 pounds of sand bags in the back and the back end was kinda sagging so I thought that this was weird and weak so I checked, and didn't think the leafs should be pointing down more then up.
  16. Mar 16, 2010 at 7:45 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    you are correct.
  17. Mar 16, 2010 at 7:55 AM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    x2 :(
  18. Mar 16, 2010 at 8:01 AM
    only_K
    only_K Future Owner
    Kevin
    Central California
    Currently searching for dream truck...
    TBD
    mine are starting to look like that. i bought a 2" AAL from toytec but i haven't put it on yet. i think im gonna have to get the replacement leaf pack as well.
  19. Mar 16, 2010 at 8:11 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I think its fine. You just have a lot of axle wrap which is annoying.
  20. Mar 16, 2010 at 8:26 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Do you guys know if they are selling the OME leaf packs as individuals or in pairs? For the 98 and above they are individuals but the 95 - 97 they don't specify?? Also, do guys know the cheapest place to buy the OME leaf packs??
    http://www.rocky-road.com/tacoma.html
