Are new UCAs needed on a lift?
Discussion in 'Suspension' started by headhunter247, Jan 17, 2009.
  1. Jan 17, 2009 at 5:52 PM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    Ok, so Im looking at getting a lift. Interested in coilovers. What is the exact reason of getting new UCAs? Do I need to get them? Obviously Im new to this.
    If I didnt get coilovers and went the OME 885 with 5100s, what about the UCAs?
  2. Jan 17, 2009 at 6:02 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    You don't need them but they will help with getting your alinment right. I will be getting some soon. My truck leaks to the right a bit and they told me thats the best they could get it. Also from what i understand the it makes the ride alot better.
  3. Jan 17, 2009 at 6:28 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have 885's and 5100's for my double cab with Total Chaos UCA's. I got them for that exact reason, to get the alignment right. Rides great!!! No complaints at all!!!:D
  4. Jan 17, 2009 at 6:33 PM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    ucs make for increased travel smother movment and the ucs wont bind on the coilover when at full drop and the alignment can be corected
  5. Jan 17, 2009 at 6:37 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
  6. Jan 17, 2009 at 6:41 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Dang you know what, I think my tires rub on my UCA's as well sometimes. I could have sworn this one day when I was washing my truck that there was some black rubber stuck to the UCA's!!! Or am I freaking out?:confused:
  7. Jan 17, 2009 at 6:42 PM
    LonghornTaco
    Minnesota
    What's the backspacing on your rims and what size tires are you running?
  8. Jan 17, 2009 at 6:47 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Not to sure about the backspacing but they are a -12 offset and I'm running 285/65-18's, NDG's.
  9. Jan 17, 2009 at 6:48 PM
    headhunter247
    St. Louis, MO area
    So after looking at UCAs what is the difference between total chaos, icon and like the light upper racing UCAs that toytec sells.
    Im trying to make this right, but not spend a TON of money.
  10. Jan 17, 2009 at 6:51 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I was the same way. Everyone pointed me towards the TC UCA's though. I know their pricey but they are worth it!;)
  11. Jan 17, 2009 at 7:00 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    TC = sex
    New Camburgs = Sex
    You don't NEED new UCAs - but I'd recommend them. I drove for 20k miles with a 3" OME coil lift and the stock UCAs.
  12. Jan 17, 2009 at 7:11 PM
    headhunter247
    St. Louis, MO area
    was that with or without new 5100s?
  13. Jan 17, 2009 at 7:21 PM
    Delmarva
    Tucson, AZ
    actually it was without 5100s -- OME shocks on all 4 corners back then.
  14. Jan 17, 2009 at 7:25 PM
    headhunter247
    St. Louis, MO area
    Ok, so heres what Im thinking for the beginning and then getting 5100s later....OME 885s, AAL, TC UCA, diff drop, and 3 degree axle adjustments...does that sound like a good start, then get the 5100s?
    Oh, by the way..whats the difference between the 885 and 886?
  15. Jan 17, 2009 at 7:32 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    That sounds about right. I have that exact same setup excluding the 3 degree axle adjustments. You don't need the 886's unless you are going to add any more weight to the front of your truck for example, different bumper, wench, bull bars, etc.... The 885's will do just fine. ;)
  16. Jan 17, 2009 at 7:37 PM
    Delmarva
    Tucson, AZ
    What he said and you'll be good :thumbsup:
  17. Jan 17, 2009 at 7:42 PM
    headhunter247
    St. Louis, MO area
    Thanks a lot fellas. I think that I have an understanding about this now...this all stemmed from fiances dad. Has a bad ass jeep (i mean stroker motor, custom axles, air lockers, gears, the whole 9) and we went wheeling on his trails today. Yea, soon to be father in law with his own personal trails hes made...I love it already. +1 to you both
  18. Jan 17, 2009 at 7:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    885's are a 600# spring rate, while the 886's are a 650# spring rate. Unless you are running extra weight in the front, stick with the 885's.
  19. Jan 17, 2009 at 7:45 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Nice!! You have to remember though that if your going to do a lot of off-roading, you will need to get the right wheels/tires or else rubbing issues will be a b---h:eek:!
  20. Jan 17, 2009 at 7:49 PM
    headhunter247
    St. Louis, MO area
    Yep..Ive been looking..the tires will come after what I have will be worn out...which arent bad, but well you know...arent what I will need once I have my lift. Im not sure about getting aftermarket wheels. Im looking into 1.25 spacers and just painting the stocks black. I like their look, but want black ones.
