Are OME Dakar springs made for 4x4?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Nov 18, 2020.
  1. Nov 28, 2020 at 2:48 PM
    #61
    eon_blue
    Azusa, CA
    It's so weird I've never had that issue when installing my Kings or my old 881s/5100s but I read about it a lot on here. They've always just lined right up and bolted in.
    I've read some people use a bottle jack and others just loosen the cams so the LCA drops more, but make sure you mark them if you do that.
    High Noon likes this.
  2. Nov 28, 2020 at 3:02 PM
    #62
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tacoma and 4Runner both required that I use a bottle jack.
    Only difference is, the Fox 2.5s easily turned at the bottom with a screw driver through the eyelet.
    The King 2.5s holy shit...had to run a rod through that damn thing just to turn it.
    eon_blue[QUOTED] likes this.
  3. Nov 28, 2020 at 3:06 PM
    #63
    eon_blue
    Azusa, CA
    I wonder if having the SPCs makes the difference on mine, allowing for more droop. Sounds like stock arms are the common thing here for needing to do the bottle jack/pry bar method
  4. Nov 28, 2020 at 3:11 PM
    #64
    Kwikvette
    Fresno County
    4 run, 2 don't
    Could very well be it.
    Remember how little mine drooped when we were at HH?
  5. Nov 28, 2020 at 3:17 PM
    #65
    medic2230
    Murph
    Bama! Roll Tide
    ^^this
  6. Nov 28, 2020 at 3:35 PM
    #66
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    Aren't the kings adjustable?
  7. Nov 28, 2020 at 3:37 PM
    #67
    Kwikvette
    Fresno County
    4 run, 2 don't
    That doesn't change whether or not the UCA has extra articulation.
    The stock UCA sucks, and just getting the right alignment alone is an issue when lifting.
  8. Nov 28, 2020 at 3:40 PM
    #68
    SellyKlater
    Ponce Inlet, Fl
    No. But when I used to be into Hondas the adjustable coilovers were way easier to install then non. I'm sure you don't install the kings all the way up fully extended. The omes are fully extended per say.
  9. Nov 28, 2020 at 3:42 PM
    #69
    Kwikvette
    Fresno County
    4 run, 2 don't
    Kings are adjustable, yes.
    But no one removes the preload, just to install them, and apply preload for the lift they are looking to obtain.
    They're installed, by most, with 2.5" of lift already set by the factory. Though some people do remove 1/4" of preload which means 1/2" less of lift. Still quite a bit of preload on them afterward.
  10. Nov 28, 2020 at 3:48 PM
    #70
    eon_blue
    Azusa, CA
    My old 5100s and 881s bolted right in as well.
    Kings were set to 2.5" of lift out of the box
    The difference has to be stock vs aftermarket ucas
  11. Nov 28, 2020 at 4:33 PM
    #71
    SellyKlater
    Ponce Inlet, Fl
    I don't know. I have 883s which are prob longer then kings or 881s. You only need about 1/2 inch more hard push and the 883s slid right in as well.
  12. Nov 30, 2020 at 6:25 AM
    #72
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    883 are same height as 881, just more spring load
    eon_blue likes this.
  13. Nov 30, 2020 at 10:09 AM
    #73
    Tacoscar-the-grouch
    Tacoscar-the-grouch Well-Known Member
    Josh
    North Idaho
    2001 Reg. Cab Tacoma
    OME kit 4.56's 235/85/16
    Got almost 4" lift over stock on my 4cyl reg cab with 881's. Lol. Swapped for 880. Did Not drive them to "settle" the springs but there you go.
  14. Nov 30, 2020 at 10:12 AM
    #74
    eon_blue
    Azusa, CA
    It is so crazy to me the variety of lift heights people get with OME springs. The weight difference between the 4 and 6cyl engines is only a couple hundred pounds too so it's not like there's a huge difference in weight between our trucks. The difference in the cabs though probably has a big effect on it
  15. Nov 30, 2020 at 10:18 AM
    #75
    Tacoscar-the-grouch
    Josh
    North Idaho
    Yes I have to wonder what the manufacturing tolerances are at OME. Not to talk shit on them, they have a good product as far as I can tell. However, one of my 881's was 0.25" taller than the other - and yes i know some of their springs are supposed to be different for driver/passenger, 881's are not.
    Also lots of differences from stock on our trucks. I read one post a while ago talking about the many different spring options that came stick on these over the years and trims, so that hasto play into it as well.
    Anyway, it's a good thing springs are easy to change if you don't like them, and another TW member will scoop your spares in no time :thumbsup:
  16. Nov 30, 2020 at 10:19 AM
    #76
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm sure driver adds quite a bit of weight; from a horse jockey to Jared before his Subway diet :burp:
  17. Nov 30, 2020 at 10:27 AM
    #77
    ciaman96
    ciaman96 Well-Known Member
    Tucson
    2001 Reg Cab Tacoma 4x4
    OME Lift, E-locker, interior swap
    One difference could also be how high people's trucks are sitting before changing springs. I think my front end was at about stock height but my rear was definitely lower than it should've been. I started out at 3" of lift with 881s and now it's about 2.5" over stock.
  18. Nov 30, 2020 at 10:32 AM
    #78
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    2025 SR5 4x4
    Are the 880's a better ride? My 2.7 double cab with no weight up front feels a little harsh overall with 881's.
  19. Nov 30, 2020 at 10:36 AM
    #79
    eon_blue
    Azusa, CA
    880s have the same spring rating as 881s and 882s (500#), the 880s are just shorter to provide less lift
  20. Nov 30, 2020 at 10:49 AM
    #80
    Tacotruck7
    SoCal
    2025 SR5 4x4
    Good to know. The guy at Low Range told me that 881's were made for more weight up front and had a different spring rate than 880's but I wasn't sure if he was correct.
