Are our tanks really 21 gallons?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by upnadam, Aug 10, 2011.
  1. Aug 10, 2011 at 9:50 AM
    upnadam
    upnadam [OP] Well-Known Member
    Adam
    Wilmington, NC
    11 PreRunner TRD Sport LB
    5100's up front, TSB, tinted windows, tail gate theft deterrent mod, fog lights anytime, de-badged, 7 pin relocate, AFE dry, Magnaflow
    I've driven mine with the reserve light on for 35 miles and still have yet to put more than 18 and a half gallons in it. Anyone else have this?
  2. Aug 10, 2011 at 9:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You're never going to run it bone dry plus running it down that low needlessly just give the opportunity for sediment to make it's way into your fuel delivery system and cause issues. Should be a 21.1 gallon tank though.
  3. Aug 10, 2011 at 9:56 AM
    Fodder4U
    Fodder4U Well-Known Member
    Mark
    The Colony, TX
    2011 SR5 Access Cab 4x4 Stock for now.
    Running it that low over time can also cause your fuel pump to over heat and fail prematurely. Best advise is to get gas when the light comes on.
  4. Aug 10, 2011 at 9:56 AM
    billwot
    billwot Well-Known Member
    Eastern NC
    '11 Access 4 cyl auto SR5
    Just FYI, the "sediment" (and moisture) is ALWAYS at the bottom of the tank, regardless of fuel level.
  5. Aug 10, 2011 at 9:58 AM
    Pugga
    Massachusetts
    That was kind of my point. When your tank is full the sediment is on the bottom and your pump is pulling from the top so there's less of a chance for it to get sucked in. When you're at the bottom of the tank, there's a higher risk of sucking up sediment and moisture.
  6. Aug 10, 2011 at 9:58 AM
    billwot
    Eastern NC
    When the light comes on, you still have approx 3 gallons remaining.
  7. Aug 10, 2011 at 10:00 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yes, it is an 80 liter tank... so divide 80 by 3.785 and you have 21.136 gallons... Naturally there is some distance up the fill tube to where it can spill out!
    The light comes on when the tank still has 4 gallons in it (+/- 0.5 gallon).
    Your Fuelly.com link says you are getting a fantastic 18.9 MPG... so if that is true: 18.9 x 4 = 75.6 miles until you run out, from when the light comes on.
  8. Aug 10, 2011 at 10:00 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I ran just over 45 miles with the light on.
  9. Aug 10, 2011 at 10:03 AM
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    Even better get gas before the light comes on I see no need to run the tank low
  10. Aug 10, 2011 at 10:05 AM
    David K
    When the gauge needle is on E, there is approx. 3 gallons still in the tank.
    2nd Gen Gas Gauge:
    Full: 21 gallons +
    3/4 Line: 16 gallons
    1/2 Line: 12 gallons
    1/4 Line: 8 gallons
    Light: 4 gallons
    E Line: 3 gallons
  11. Aug 10, 2011 at 10:08 AM
    David K
    Right, and with my truck only getting 16 mpg sometimes, I can go 64 miles to empty from when the light comes on... obviously only in an emergency!
  12. Aug 10, 2011 at 10:09 AM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
  13. Aug 10, 2011 at 10:10 AM
    DWreck
    Derek
    Las Vegas, NV
    I hate it! That's why I can do 90 miles top quarter and drastically less each quarter after.
    I do 90 top quarter and think I'll get 180 to half. Not so. I did 100 miles top quarter one time but only got 280 till light. So deceiving.
  14. Aug 10, 2011 at 10:21 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I go to the light every time because round trip to work every day for me is 75ish miles. Which makes for 375 miles for work and back for the week. I try to fill up on Sunday night or Monday morning and my tank will last me until I get home Fri night. That get's messed up sometimes by weekend driving.
    I don't think it's hurting anything as it almost always takes 18-19 gallons. I think only one fill up went over 19.
  15. Aug 10, 2011 at 10:22 AM
    colder
    MN
    I rarely go below 1/4... especially in the winter, you never know what could happen.
  16. Aug 10, 2011 at 10:24 AM
    David K
    LOL yah, the lines do not represent the true per-centages!
    21 gallon tank would mean:
    3/4 tank = 15.75 (16 actual)
    1/2 tank = 10.5 (12 actual)
    1/4 tank = 5.25 (8 actual)
    Empty = 0 (3 actual)
    But, aren't you glad... I mean, isn't nice to know there is up to 3 gallons 'reserve' in there?
  17. Aug 10, 2011 at 10:27 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    My tank on my 05 is 18 gallons but when going really low I have put alomst 19 in.
  18. Aug 10, 2011 at 10:28 AM
    Pugga
    Massachusetts
    Open air space allows for more condensation and water accumulation in the tank. If you keep your tank full, there's no room for condensation. In the fall and winter months where you have warmer day temps and cold night temps, the moisture in the tank condenses on the sides of the tank and you now have water in the tank. Over time this can accumulate and cause problems.
    Also, your pump pulls from the top of the tank where you have clean gasoline (at least that's the intent). If you drain the tank down, you're now pulling from the bottom where any sediment and moisture would collect and forcing it all through your fuel system. Also, the gas keeps the pump cool so running the tank down makes the pump run hotter which means it'll need to get replaced sooner.
    With all those positive things about keeping your tank full, I personally don't see the point in risking it and running the tank down... :cool:
  19. Aug 10, 2011 at 10:34 AM
    colder
    MN
    It's probably better if everyone assumes E means 0 gallons! ;)
  20. Aug 10, 2011 at 10:36 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    It's 21
