Are rear blocks a 1:1 thickness to lift ratio
Discussion in 'Suspension' started by PapaGrizz, Jul 18, 2019.
  1. Jul 18, 2019 at 2:37 PM
    PapaGrizz
    PapaGrizz [OP] Active Member
    2010 DCSB 4X2 On Road
    3" front 1" rear. Method NV 17s
    Does a 1 inch block under the leafs equal a 1 inch lift in the rear?
  2. Jul 19, 2019 at 3:15 AM
    ky_miles99
    ky_miles99 New Member
    Ky
    2017 black Tacoma sr5
    Most trucks come with a block from factory and stacking blocks is very dangerous and illegal in many places. But Toyota’s do not have blocks from factory (to my understanding) so a 1” block would equal 1” lift.
  3. Jul 19, 2019 at 7:13 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
  4. Jul 19, 2019 at 7:17 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Is this a trick question...?
  5. Jul 20, 2019 at 5:17 AM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    If you look at where the block goes it’s very easy to see that there is zero linkage/mechanical advantage involved and that the block is inline with the axle, so yes a 1” block will lift 1”.
    Contrary on the front end, we modify the shock but the wheel is offset 8-10” and connected via A-arms (linkage), so it’s more of a 2:1, 1” block = 2” lift up front.
    apy_camper likes this.
