Are Shackle Kits only for Extended Travel?
Discussion in '4x Innovations' started by zerotimeouts, Dec 15, 2016.
  1. Dec 15, 2016 at 7:51 PM
    zerotimeouts
    zerotimeouts [OP] Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
  2. Dec 17, 2016 at 1:01 PM
    traxman25
    traxman25 4x Innovations Vendor
    Adam
    Platteville Wi
    Too Many!
    The HD replacement shackles do not affect suspension travel. They are only intended to be a strength upgrade over the stock shackles. So if you've bent a stock shackle, or are worried about doing so this would be a great item for you to upgrade. The stock length shackle will work in the stock shackle mounting brackets or a flip bracket. The extended length shackles will only work with a shackle flip kit and provide some lift to the rear as well. The amount of lift gained is listed for each length available.
    zerotimeouts[OP] likes this.
