Are single electrode spark plugs ok?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Sep 17, 2022.
  1. Sep 17, 2022 at 6:31 AM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    A little confused in the proper spark plug to use. I always heard that the dual electrode is the one to use but sounds like oem they came with either or (or even a mix).
    My local store was out of the dual electrode so I picked up NGK copper single electrode. Will that be ok?
  2. Sep 17, 2022 at 6:40 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Yes, single electrode will perform no different than the duals. The only reason Duals are used is for longer life expectancy with the waste spark ignition. You have twice the surface area to burn off, therefor you get more life. So outside of a shorter life span, There is zero performance difference using singles.
    Wulf, x2468[OP], Nessal and 1 other person like this.
  3. Sep 17, 2022 at 11:35 AM
    Bubba’sTaco
    Bubba’sTaco Virtually-Known Member
    Spencer
    Ogden Utah
    Toyota XJ
    Engineers are really dumb
    TACOTU3, MalinoisDad and 02hilux like this.
  4. Sep 17, 2022 at 11:46 AM
    vern650
    brandon
    hyrum, ut
    Some engineers are actually quite dumb when it comes to reality. That sticker doesn’t change the laws of electricity.
    MadNachos likes this.
  5. Sep 17, 2022 at 1:57 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    LOL. It's fleebay spark plug vs local auto parts spark plugs. They're both NGK on the box.
  6. Sep 17, 2022 at 2:07 PM
    v5ensx
    Factory never came with single. They sometimes have NGK dual on one side and Denso dual on the other side.
  7. Sep 17, 2022 at 2:22 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    This is correct.
  8. Sep 18, 2022 at 3:16 PM
    x2468
    LOL! I'm 99% sure I dont have that sticker on mine
    BTW I just moved to northern Utah.:thumbsup:
    Bubba’sTaco[QUOTED] likes this.
  9. Sep 18, 2022 at 3:26 PM
    x2468
    My bad I must have misread the thread I was reading.
  10. Sep 20, 2022 at 12:37 PM
    Bubba’sTaco
    Spencer
    Ogden Utah
    Toyota XJ
    Hell ya, that’s awesome. What area did you move to?
