Are skidplates necessary for off-roading?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, May 5, 2021.
  1. May 5, 2021 at 8:50 PM
    Running Board Man
    Running Board Man Well-Known Member
    Get one of them fancy oil drain valves with a hose long enough to drain the oil past the skidplate
    And no you'd have to hit many things very hard before the stock skid would be cause for concern... Even than it would still protect the underside very well
    With a mild lift and 32" tires I have miles of clearance under my truck
  2. May 5, 2021 at 8:58 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Skid plate > snorkel
    Running Board Man and jbrandt like this.
  3. May 5, 2021 at 9:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Every time I slam hard into that obsticle, I give praise to the BudBuilt god...
    Fernando and Jojee117 like this.
  4. May 5, 2021 at 11:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lights before lockers
    Fernando and se7enine[QUOTED] like this.
  5. May 5, 2021 at 11:19 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Better to have it and not need it, than to need it and not have it! :thumbsup:
    To answer your question bluntly, no it is not required. To offroad and enjoy yourself you don't need anything other than a stock vehicle, a full tank of gas and the desire to adventure :bananadance:
    Some driver mod and caution would be a good addition to the above recommendations :cheers:
    joe25rs and jbrandt like this.
  6. May 5, 2021 at 11:33 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    Driving skill ---> suspension (along with tires and gears) ---> armor.
    I've had several well built jeeps in the past. There were a few times I inadvertently used the armor, but not many. Unless I was specifically using the armor to get up and around rocks or obstacles. There were lots of those times as well.
  7. May 6, 2021 at 6:31 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Armor has it's purpose off the trail as well. Helps with careless door openers and other poor driving ass-hats. Mainly though if you've ever hit an animal crossing a highway then you know a heavy bumper and skid deflect some of the damage if not all.
  8. May 6, 2021 at 1:36 PM
    adams9621
    adams9621 Member
    Gregg
    1996 White Tacoma 4x4
    Everyone is going to have an opinion about it one way or the other. Depends on what you're doing.
    Running Board Man likes this.
  9. May 6, 2021 at 2:10 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Define "need".
    Also, define "trails" because there are all levels of difficulty for trails.
    But in the end, no you don't "need" 1/4" thick steel skids do go driving down that fire road.
    That said, they are added protection that prevent you from poking holes in your oil/trans pan.
    Absolutely not. If you design a suspension around the goal of never hitting a skid plate or sliders on obstacles, that is going to be a stupid tall lift and not likely perform very well in just about any condition. Your center of gravity will be super high, making it more likely you'll roll over.
    Look at the comp rock-crawler buggies or trophy trucks. Arguably the best designed suspension for their particular use, and yet they still have skids everywhere and constantly bash into stuff.
    Arctic Taco likes this.
  10. May 6, 2021 at 2:11 PM
    jbrandt
    Justin
    Skid plates aren't designed to make oil changes easy.
    They're designed to prevent you from poking holes in your oil pan.
    WELLSPRING likes this.
