Are Spacer Lifts REALLY that bad?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sammyt38, Nov 8, 2022.
  1. Nov 9, 2022 at 6:08 AM
    sammyt38
    sammyt38 [OP] Well-Known Member
    Sam
    Gulf Coast
    2020 TRD OR MBM
    Title Mod, Eibach Stage 2, Headstrong AAL, Bakflip G2
    I looked up the 5100s and this looks like exactly the kind of solution that I need. Thanks big time
    t2c, disel_V1, Tocamo and 2 others like this.
  2. Nov 9, 2022 at 10:43 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    that is a BIG spacer. On the front a 1" thick spacer, nets you 2" of lift so... Ski
  3. Nov 9, 2022 at 11:11 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    So the reason this happened is because he didnt extend his bump stops accordingly. This caused the articulation to still allow the lower control arm to rise to its stock bump location but because the coilover had been extended 3" it crushed the shock.
  4. Nov 9, 2022 at 3:15 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I highly recommend the 5100s. In your case if you don't want the 1" block in the rear, just set the front @ 1", and you'll be level. Best thing about the 5100's is it's a bigger better shock than the stock OR shocks, and keeps it's awesome ride, without the brake dive.
    Do it, do it.
    P.S. I love my 2/1" lift, and would do it again...
    sammyt38[QUOTED][OP] likes this.
  5. Nov 9, 2022 at 4:01 PM
    Dawelda
    Dawelda Well-Known Member
    West of West Phoenix
    20 Tacoma DCLB TRDOR Desert Sand
    2.5" lift w/33" tires, 10K Winch & bumper, camper shell
    I had the same struggle...having had success with spacers in full-sized trucks in the past.
    But, considering ride quality, off road performance and (very important and) carrying weight in the bed, I decided to pony up the money for all-around suspension lift from Toytec. My truck drives and rides great, off road is excellent (for me), I have the factory rake for an OEM look and the rears springs soak up a load without squatting.
    Sounds like you'll be good with a minor front level kit, but if you off road or carry weight, you know what they say, "spend the money and cry ONCE!" Just my .02 worth.
    Good luck!:cheers:
    sammyt38[OP] likes this.
  6. Nov 9, 2022 at 4:20 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
  7. Nov 9, 2022 at 5:58 PM
    Bunny_thetaco
    Bunny_thetaco Member
    Spacer lifts suck, speaking from experience. If you decide to lift, get proper shocks and don't go above two inches.
  8. Nov 9, 2022 at 6:07 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Buy one and install it on your $40K truck.
    Good luck with that.
    AmateurTaco1313 likes this.
  9. Nov 9, 2022 at 6:09 PM
    Bishop84
    Bishop84 Well-Known Member
    I've seen all of this with proper coil overs. Even the shaft inverting. Heck I've seen a stock non-lifted bilstien invert.
    Abuse is abuse. Spacers aren't perfect, but they certainly aren't fear mongering time bombs like TW makes them to be.
    Dawelda, sammyt38[OP] and BPfishing like this.
  10. Nov 9, 2022 at 6:11 PM
    Kllrbee
    Kllrbee Well-Known Member
    Tim
    Bloomfield, WI
    22 Army Green DCSB Sport
    @Mully, cant really tell what happened there. Did the spacer crack or collapse leading to the arm bending the shock?
    Im stock and have no plans on any spacers, level, or lift in the near future. Just curious how that happened.
  11. Nov 9, 2022 at 6:21 PM
    disel_V1
    disel_V1 I eat cold pizza rolls
    3rd Gen
    few things here and there.
    I had a level spacer / puck on my 2nd Gen. Top of strut spacer. Didn’t change the ride quality at all, but to be fair, my truck was well overdue for struts / shocks anyway. Had they been fresh, it probably would’ve made it a tad bit stiffer.
    I know plenty of people that get them with no issues though.
    I think most just get new struts / springs to get the most out of the level / lift.
    I’m running 5100’s with Eibach Pro Springs. Love it, would never run a spacer again, unless I just needed a more affordable option.
    But no, I don’t think spacers are that bad at all.
  12. Nov 9, 2022 at 6:32 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Do you live in the Carolinas? If no, forget the level. Stick with stock.
  13. Sep 11, 2024 at 10:23 AM
    Vinyl Trooper
    Vinyl Trooper Well-Known Member
    Roy
    Los Angeles
    SuperWhite 2017 DC LB TRD OR
    Bilstein 2" front 1" back. Konig Countersteer Type X. Falken AT4W 265/75/16. Focal IS Toy front & Back doors. JL Audio TW3 10" x2. Match UP 1FX sub amp. Audiofrog A150.4D. Helix Mini MK2 DSP. Helix Conductor controller.
    Thanks for this info, Ghost. I don't plan on off roading a whole lot, but I DO snowboard, and that would be the extent of me being off road. I'm mainly looking for an easy way to get 17" wheels with a high profile tire. And there are more options available in 17"
  14. Sep 11, 2024 at 2:02 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
  15. Sep 11, 2024 at 4:45 PM
    #35
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I don't know why you would want a spacer lift other than price. I have experience with lifting a vehicle not the Tacoma. I lifted my Jeep Liberty CRD years back, Before I decided on the lift I wanted I was off Roading with some guys. One had A Gasser Liberty with a spacer lift, one with the Old man Emu springs and and all. I spacer lift rode hard like a Buck board. The OME was 2" lift and rode better than stock suspension. There are some many quality lifts for the Tacoma that are quality comparable to that. yes they cost more. all I can say is save up and do it right. I did with the Jeep and it was a good thing I enjoyed it and didnt need to spent more to redo it cus it sucked.
