Are spacers required?
Discussion in 'Wheels & Tires' started by sidus649, Mar 11, 2019.
  1. Mar 11, 2019 at 12:19 PM
    sidus649
    sidus649 [OP] New Member
    Lifted, 1" front, .5" back
    Hey everybody, I’ve got a question for anyone who may have experience with these rims.
    I recently bought Dick Cepek Torques for my 2015 Tacoma, and they look awesome. However, when I got them installed, the people installing them, who I trust, noted that they were having a tough time balancing them, and that there seemed to be a wheel spacer that was required for the wheels that was missing with my order.
    I followed up with Tire Rack, and they informed me that there isn’t any spacer made for those rims for the truck, and that it’s just how they were put on is what is causing issues.
    I find that very hard to believe, as the truck shakes at 50-60 mph, which it obviously didn’t do before, and I personally inspected the rims to see if everything was mounted correctly.
    Does anyone have any experience with these rims, and any insight on this?
    Thanks!
  2. Mar 11, 2019 at 12:20 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Most likely balance issues causing the shaking. I don’t think any company makes a wheel that requires spacers to be ran
  3. Mar 11, 2019 at 12:23 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Sounds like balance issues to me, spacers shouldnt affect that much. If you want an at-home solution and have a way to reinflate the tires, I've had great success with dynabeads as a balancing aid, in fact I'll probably be adding some to my truck in the near future.
  4. Mar 11, 2019 at 12:30 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    https://www.dickcepek.com/wheels/dc-torque/
    The center bore on these wheels are 110 mm. Your hub is 106 mm. You need a 110-106 plastic hubcentric ring to get the wheel to run true on your hub, probably the "spacer" your install shop is referring to. Call up The Tire Rack and ask for hubcentric rings. If they won't ship you any, order a set for cheap on Amazon.
    Note this ring shouldn't be needed to balance the tire, since the balancing machine uses a cone. However, missing the ring can cause vibes on your truck.
    El Duderino and DavesTaco68 like this.
