Are Sport Coils the same as OffRoad coils?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tombiosis, May 30, 2023.
  1. May 30, 2023 at 2:23 PM
    tombiosis
    tombiosis [OP] Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Asking for a friend...(kidding)
    I need some coils fast and was wondering if the trd sport coils are identical to the trd offroad coil springs?
  2. May 30, 2023 at 2:39 PM
    AMMO461
    AMMO461 TACO/FJ/FJ
    SoCal Hi-Desert
    2021 TRD Off Road DCSB OD
    The Sports have a Stiffer spring rate than the Off-Roads. They are an exact dimensional swap over.
    e6400ultra likes this.
  3. May 30, 2023 at 2:43 PM
    tombiosis
    T
    Ottawa Canada
    thanks!,,,New coils are back ordered from Toyota but I can likely buy sport coils used
  4. May 30, 2023 at 2:48 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    You can get offroad take offs on facebook marketplace for dirt cheap as suspension go some with almost no miles on them.
  5. May 30, 2023 at 3:57 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    The Sport springs are as stiff as the SR springs. They are so stiff, they will eliminate body roll.
  6. May 30, 2023 at 4:17 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    So if one wanted less body roll with an SR, upgrading to Sport springs would be pointless?
  7. May 30, 2023 at 4:21 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Do you have info to support that? I’ve heard the opposite which was the reason folks said the off-road got the smaller sway bar.
    Junkhead likes this.
  8. May 30, 2023 at 4:23 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I’m pretty sure all 3rd gen Tacoma springs are rated at 714#. It’s the shocks and sway bar that make a difference in handling.
    JFriday1, na8rboy and BLtheP[QUOTED] like this.
  9. May 30, 2023 at 4:25 PM
    BLtheP
    Plano, TX
    That’s what I would say too, (I did hear the offroad had heavier rate springs but I have no proof of that, just words of others), but I too would suggest the shocks make the difference in ride quality, and sway bar to some extent.
    I want to say on the Toyota parts sites, the springs between OR and Sport part #s were different though.
    Junkhead[QUOTED] likes this.
  10. May 30, 2023 at 4:25 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    This is the impression that I was under as well. Not confident enough that I’d dig my heels in though.
  11. May 30, 2023 at 4:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Time around here has led me to believe the springs are all the same, with the shocks and sways making the difference between models.
    OP you need to replace your springs now, along with the botched install being corrected, right?
    If sport springs are available to you local, cheap and fast, do it. The worst that happens is you find a better spring and take the time to learn DIY later on. Right now you are in a risky safety delima.
    na8rboy likes this.
  12. May 30, 2023 at 4:59 PM
    e6400ultra
    NorCal
    Pretty much, I can take corners like a Civic in my SR. lol
    Puppypunter[QUOTED] likes this.
  13. May 30, 2023 at 5:12 PM
    tombiosis
    T
    Ottawa Canada
    Yep
    Found a set of take offs from a trd sport that I can get right away...
