Are steel wheel lug nuts same as alloy lugs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mbtech208, Jun 23, 2009.
  1. Jun 23, 2009 at 9:30 PM
    mbtech208
    mbtech208 [OP] Well-Known Member
    Peoria, Illinois
    1997 Base 4WD regular cab
    I bought some 15" SR5 alloys to replace the steelies on my '97, and I want to know if it uses the same lug nuts?
  2. Jun 23, 2009 at 11:36 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Look at the wheel and see what the mounting surface looks like.
  3. Jun 24, 2009 at 1:15 AM
    jeeters79
    jeeters79 Active Member
    Stanwood, WA
    '99 4X4 SR5
    Hmmmm... Do the lug nuts you have now taper down at the bottom, or do they have a flange/ washer around the middle of them? Toyota alloys need the ones with the washer. (I just went through this a month ago when I bought some stock 15" alloys to replace my bent up aftermarket wheels)
    Toyota wheel lugnuts
    Regular acorn style lug nut
    Hope this helps.:cool:
  4. Jun 26, 2009 at 4:59 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Same goes for the pre-2005 5-lug factory alloys ... They have a flat mate-up area for the lug nuts, and you need to use the OEM 'shank-style' ones.
