Are stock bump stops okay for a 1 in. lift in the back
Discussion in 'Suspension' started by BloodRunner, May 12, 2024.
  1. May 12, 2024 at 2:29 PM
    BloodRunner
    BloodRunner [OP] Active Member
    2021 AG Tacoma OR
    Hey everybody.
    The Thread title pretty much covers it, but I got a new leaf spring pack and did a U-bolt flip kit. There doesn't seem to be a lot of up travel (~3 in.) and it bottoms out fairly quickly. Would putting the stock bump stops back work? And if you have any other suggestions, as far as bump stops, that would work better I would like to hear them. TIA
  2. May 12, 2024 at 7:07 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    3-3.5" rear gap, frame to bump, is about stock gap. Mind you this is not bump compressed gap, which will vary by manufacturer.
    Nevertheless, I posted about this a couple months ago in a thread. I installed 1.5" lift leaf pack and still cut my flipped bumps down. The flip bracket adds another 1/2" to a sometimes overly long piece of rubber. Knowing rubber compression to full stop before the shock compressed length is reached is the key.
    This ends up being an estimate based on available spec data and/or by measuring compression using high cross axle ramps where full corner weight is bearing down, but I take my own measurements and tests to determine my risk threshold.
    BloodRunner[OP] likes this.
  3. May 14, 2024 at 8:09 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I wouldn't change the bumpstops for a 1" rear lift unless you tow heavy or want a small cushier ride for heavy hits. I like sumo springs though. (Blue)
  4. May 14, 2024 at 9:05 AM
    BloodRunner
    2021 AG Tacoma OR
    Yeah, I think I might put the stock ones back. I also think that since the new leaf springs are much more progressive than the stock ones, with only ~3in. of up travel I'm just not getting the full potential out of them.
    JFriday1[QUOTED] likes this.
