are stubby front winch bumper and winch too heavy for stock 2019 suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TinPA, Feb 23, 2025.
  1. Feb 23, 2025 at 8:34 AM
    TinPA
    TinPA [OP] New Member
    Trace
    2019 Tacoma sr5
    I have a 2019 4wd sr5 V6 extended cab with an ARB rear locker and am adding a stubby winch bumper and winch. The bumper is from rock slider engineering and weighs about 100 pounds(couldn't find specs) and the winch weighs about 70 pounds.
    Will this much weight, which seems like a lot, dramatically affect my ride quality or handling characteristics? Will I have to do any upgrades to the stock suspension? Any help would be appreciated.
  2. Feb 23, 2025 at 8:51 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Take measurement hub center to fender edge before adding 170 lbs so you know how much more the stock springs compress with the added weight.
    Someone on here has surely done it and can say what to expect.
    Tocamo likes this.
  3. Feb 23, 2025 at 8:55 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Brake dive will happen.
    Tocamo and boston23 like this.
  4. Feb 23, 2025 at 9:10 AM
    eurowner
    eurowner Duke Sky
    Scoty
  5. Feb 23, 2025 at 9:11 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    It's not really adding 170#, the stock components you are removing are 35-40#. Still, you will notice it because the weight is way out in front of the suspension.
    Chew likes this.
  6. Feb 23, 2025 at 9:11 AM
    scocar
    scocar Patron of the Farts
    Adding anything out there will have a profound effect.
    boston23 likes this.
  7. Feb 23, 2025 at 9:12 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I saw this at the 2017 Auto Show.
    Tocamo likes this.
  8. Feb 23, 2025 at 9:15 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    x2
  9. Feb 23, 2025 at 9:23 AM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    Yes, adding that bumper and winch will change the way it rides, it'll sag more in the front, dropping the suspension in the front about 3/4-1" and you'll feel every bump harder. This is the reason for heavier spring rates when you add weight. I have a similar bumper and had 600lb springs, and had to go up to 650lb springs.
    Tocamo likes this.
  10. Feb 23, 2025 at 9:39 AM
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
    I'd say 20 lbs max, crash bar aluminum bar and brackets, bolts, and plastic. I removed mine last month and couldn't believe how minimal it was.
    jmneill likes this.
  11. Feb 23, 2025 at 10:06 AM
    TinPA
    Trace
    2019 Tacoma sr5
    Thanks for all of the advice. I'll do the install and see where it leads me, whether it's heavier springs or everything feels fine. I really like my current ride height, so if it drops less than an inch or so and ride quality is still okay, I'll leave it alone.
  12. Feb 23, 2025 at 1:10 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    It'll be a good excuse to Lift and put in some bigger Bilstein 5100's. Hopefully this will reduce the brake dive just a little bit, and not lower your front end too much.
    Good luck @TinPA
  13. Feb 23, 2025 at 2:19 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    all this fretting over 170 pounds?
    leave your riding buddy at the trailhead, or hit the gym and lose a few pounds. problem solved.
    i probably have more than 300 pounds in recovery gear, emergency tools/clothes/food/water in my truck. it's a truck, not a track toy.
  14. Feb 23, 2025 at 3:14 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Such a bad take. It’s hanging off the front end…
    jmneill, kimosabe15 and eerok like this.
  15. Feb 23, 2025 at 4:05 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is a 2" receiver hitch mounted behind the bumper with the receiver in the slot between the upper and lower bumper cover. Between the hitch, the winch and the cradle it's probably 200 lbs. If it made any difference in handling, I can't tell it. The 180 b cap on the back may balance everything.
  16. Feb 23, 2025 at 8:58 PM
    soundman98
    NW Indiana
    Sure, but we're talking inches in front of the front wheels, not miles. There's almost no leverage effect at play here. At best, one can make the argument that 170 pounds in front of the wheels translates to a few 30-100 pounds off the rear axle in a panic stop condition. Which, again, we're talking about a 5,000 pound truck.
  17. Feb 23, 2025 at 9:10 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Check out Greenlane off-road, they make aluminum winch bumpers way lighter - 45lbs but still strong. Exchange rate is good, and they ship. The welds are so nice I hated getting mine powder coated.
    https://greenlaneoffroad.com/products/3rd-gen-tacoma-stump-aluminum-front-bumper
  18. Feb 26, 2025 at 7:54 AM
    934txs
    934txs Member
    Central PA
    2023 Tacoma Access Cab TRD Off-road
    Anyone know what the import fee is on the Greenlane stump bumper? I'm looking to get one but not sure what that fee is going to be or where to even look regarding those costs.
  19. Feb 26, 2025 at 11:01 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Last time I didn’t get one, for the sliders. Bumper was about $70 American.
