Are the engines pre-broken in or not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crobran, Jun 17, 2021.
  1. Jun 17, 2021 at 6:10 PM
    Crobran
    Crobran [OP] Well-Known Member
    Texas
    `21 DCSB 2.7L Silver Sky
    Trifecta 2.0, Ionic Nerf Bars, Tailgate anti theft device from @christian06, Husky Weatherbeaters, Bed lights, OEM bed mat, Derped badges and grille bezel
    The Car Care Nut is apparently a Toyota Master Technician and on his YouTube channel he has a video in which he talks about breaking in the engines. He also says that if you plan to drive your new Toyota until the wheels fall off (which I do) then you should consider getting an oil change at 5K miles, even though Toyota suggests waiting until 10K, since they do find small bits of metal in the oil at 5K miles because the engine is still being broken in.
    I just took my taco in for its 5K mile service appointment and was talking to the service guy about whether or not to get an oil change. He told me that he heard that the engines were already broken in before being sent to the dealer. Since I'm about to take two long road trips this summer, I decided to go for the oil change, but all of this got me wondering if the engines are broken in by Toyota or not. Can any Toyota techs confirm or deny this?
  2. Jun 17, 2021 at 6:12 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Just drive your truck and enjoy. Toyota suggests oil and filter change intervals of 10,000 miles
    Pwakchop, CTF, aozer and 9 others like this.
  3. Jun 17, 2021 at 6:13 PM
    Bishop84
    Bishop84 Well-Known Member
    They are broken in, there's rarely metal in the first oil filters when I check.
    The issue with older engine was tollerances, how things seated and wore.
    Toyota is very good with their engine assembling and you have nothing to worry about.
    I personally change my oil every 5k on my Toyotas and most other techs do as well. We have more cold starts where I am and the oil saturates with fuel.
  4. Jun 17, 2021 at 6:16 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Listen to this and enjoy your truck and take the concerns on this forum with a grain of salt.
  5. Jun 17, 2021 at 6:22 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    They are broken in, but with that said and knowing what I know, I still changed the oil at 1k for my own peace of mind. Cost me less than 20 bucks and 30 mins of my time. Done and done. Don't have to worry about it
    BMH, Smokinnuts, JoeTacoma02 and 3 others like this.
  6. Jun 17, 2021 at 6:23 PM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    I’m not a tech but I can say that my truck is running better at 1,500 mi than it was at 100 mi. It seems a little quieter, smoother, and the acceleration is more linear. It also feels more powerful and torquey now when driving in the overdrive gears on moderate grades.
    RedWings44 likes this.
  7. Jun 17, 2021 at 6:26 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Giddy up, another oil thread!
    I don't know anything about it, so I just follow the recommendations in the manual.
  8. Jun 17, 2021 at 6:36 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I'm an engineer who designs things. I change my oil every 10K or so. Every engine is run through a test sequence, drained and refilled before installing in truck. I trust their engineers.
    With that said, do what you wish. Every 500 miles could be a good interval lol.
    oconnor, Lt. Dangle, Malvolio and 3 others like this.
  9. Jun 17, 2021 at 6:53 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I'm guessing by the fines I found at 800 miles NOT broken in
  10. Jun 17, 2021 at 6:59 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Do you think those fines just "broke off" moving parts within the engine? Like big end bearing, crank journals, cam shaft lobes etc?
    Or were they "left overs" from the machining operations? I wonder why the fines didn't get caught in the oil filter. They are supposed to catch that sort of thing.
  11. Jun 17, 2021 at 7:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Alright alright.. OP... the engine is not fucking broken in! It has been run, it has fresh oil but only time and miles break it in. Satisfied @Itchyfeet?
  12. Jun 17, 2021 at 7:09 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The manual says engine break-in happens with the first 1000 miles. Feel free to change the oil at that point if you want the engine to fail after the frame does...
  13. Jun 17, 2021 at 7:11 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    When changing the oil I think the oil filter housing needs to be replaced with a metal one. The one that comes from the factory is plastic.
  14. Jun 17, 2021 at 7:11 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    The manual that is in your glove box has it printed with break in period . Go off that . Personally I do my oil changes every 5k miles . I live in a Arizona and driving conditions are stop and go .cheaper to replace oil than rebuild a engine .
    Barsoom, RedWings44, Pro-Taco and 2 others like this.
  15. Jun 17, 2021 at 7:14 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Manufacturers do not "break in" engines. They don't have the time nor the facility plus the added cost would put them out of the market.
    The truth is in the advanced machining techniques used in modern factories. Machining methods have advanced quite a bit since the 1950s.
    Just follow your Owner's Manual. Enjoy your ride.
  16. Jun 17, 2021 at 7:19 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Filter alone was/is about $10. Which oil did you use for other $10?
  17. Jun 17, 2021 at 7:25 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    X2 What kind of oil + oil filter are you buying for less than $20 and where can I get some?
    nick_b, Junkhead and hiPSI like this.
  18. Jun 17, 2021 at 7:25 PM
    Tacowin1013
    Buy the filters on Amazon in bulk. I forget the cost but I think it breaks down to 6/7 dollars. Mobil 1 is 22 to 24 bucks for 5 quart. Minus Mobil 1 rebates when they have it. All in all, about 20 bucks
    JoeTacoma02 likes this.
  19. Jun 17, 2021 at 7:26 PM
    JoeTacoma02
    Damn I never thought to look on Amazon for oil :cheers:
  20. Jun 17, 2021 at 7:30 PM
    Knute
    He is buying from the used oil recycler.
    My very first car had a serious fluid problem. I would go to gas stations and ask for used oil. Cost me about $2/gal. Never bothered to change the filter. That ol' 63 Buick had many many miles....it eventually tossed a rod, but it ran for another week before my Dad insisted to scrap it.
    Travlr likes this.
