Are the engines pre-broken in or not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crobran, Jun 17, 2021.
  1. Jun 17, 2021 at 10:04 PM
    #41
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Recreational oil changes are a "thing"
    Good intentions fucking it up for everyone , as far as the EPA sees it.
    Let's not let emotions and "feelies" control our use of automobiles. There is enough pressure from those that don't know or care.
    CrufflerJJ and Malvolio like this.
  2. Jun 17, 2021 at 10:17 PM
    #42
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Still don't see how you can change oil for
    $20 for 1st time. Our truck takes more than 6 quarters. So you need 2 jags or very expensive two 1 quart bottles.
    Walmart sells oil in 5 qtrs jags for 22-25 (+-tax). Walmart oem filters $6-7+tax.
    Your 2nd, 3rd may cost less, but not 1st.
    Don't forget a wrench and washer ..
    1st oil change is north of $50
  3. Jun 17, 2021 at 10:26 PM
    #43
    MGMDesertTaco
    I'm hoping this summer won't be another record breaker like last summer. It was 115 in Phoenix where I'm at, but other sources say we hit a new record of 118. https://www.azcentral.com/story/new...ugh-weekend-smoke-and-haze-remain/7734621002/
    If this summer is a repeat of last, I'm strongly considering moving. :bananadead::threadjacked:
  4. Jun 18, 2021 at 12:09 AM
    #44
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    I think we hit 118 here in Phx today. That high pressure system just planted its ass over us and sat down. I'm glad i don't work outdoors anymore, tolerating that level of discomfort gets old. To stay on topic..I change my oil everytime i shut my truck off, it gives me peace of mind to start it up with fresh quarts.
  5. Jun 18, 2021 at 12:12 AM
    #45
    Phlogiston
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    They usually go off of Sky Harbors readings which tends to get a few degrees hotter i'm assuming because of the tarmac??
  6. Jun 18, 2021 at 1:00 AM
    #46
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
  7. Jun 18, 2021 at 1:12 AM
    #47
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
  8. Jun 18, 2021 at 1:44 AM
    #48
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Definitely not. Function checked, sure. But there are many threads here talking about how bad the mpg of the vehicle is only for it to have improved by the end of the 1000 mile break in as mentioned in the owner's manual.
  9. Jun 18, 2021 at 5:59 AM
    #49
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    Rings are seated, good to go. Can’t think of anything else that would need a “break in” and/or that would affect mpg. If it takes 1,000 miles to break-in the rings, something is seriously wrong. It is NOT normal for any surfaces or bearings to wear down (I.e., metal shavings) during the first 1,000 miles. Any shavings found in the oil are most likely from the manufacturing process (drilling; tapping; threading; etc).
    I believe auto manufacturers still call for the x,xxx break-in for two reasons:
    1) a possible way out of liability.
    2) so if something was assembled wrong/faulty parts, the engine won’t grenade which lowers the price of the repair.
  10. Jun 18, 2021 at 6:13 AM
    #50
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    You forgot about the mobil 1 rebates twice a year... Usually its about $10-12 dollars back for every 5qt, so i stock up with a limit of 2 each time, so it costs me approx $10 / 5 quarts. Been doing this with mobil oil for over 5 years
  11. Jun 18, 2021 at 6:21 AM
    #51
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    It's your vehicle, change your oil sooner than recommended (and if you plan on keeping it forever...use the best synthetic engine and gear oil you can!), Toyota like other manufacturers would love to sell you another vehicle ASAP!
    I change mine every 6000 kilometers or around there give or take 500 kilometers :thumbsup:!
    Junkhead likes this.
  12. Jun 18, 2021 at 6:24 AM
    #52
    johnarebalo
    johnarebalo Well-Known Member
    Oklahoma City, OK
    2019 MGM DCSB SR5 and 1996 Desert Dune T4R Limited
    Tacoma - not enough T4R - too much
    just buy used and you wont have to worry
    usmc2msu likes this.
  13. Jun 18, 2021 at 6:29 AM
    #53
    prefersdirt
    prefersdirt Well-Known Member
    2019 tacoma Sport
    Wow. the longer I work around the building of engineered stuff, the LESS I trust stuff
  14. Jun 18, 2021 at 6:43 AM
    #54
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    I used to agree with this and preformed 3,500 mile oil changes. However, the longitivtiy of oil has gotten significantly better in the past 10 or so years. Various oil analysis’ (owners, private research studies, etc.) have proven that 10k oil changes are fine (heck, technically 12-15k is just fine). I would, however, change the oil at the prescribed timings (6 months, year, etc,) as water contamination does occur which breaks down the oil faster. You usually won’t notice the water contamination either, as it usually gets blown out the crank as steam.
    At the end of the day, it’s your truck. No one else can tell you how to treat it. I just don’t believe that we should make statements such as “your engine will not last as long” if you follow the manufacturer’s guidelines. This is simply not true. Heck, look at fleet vehicles. Do you think they change the oil before the recommended intervals?
    Not trying to start an argument, but oil has come a long way. And if Toyota purposefully set high intervals to cause premature engine failure, do you really think someone would buy another car from them? Probably not.
    usmc2msu and betrayus like this.
  15. Jun 18, 2021 at 6:58 AM
    #55
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    lol engineers design everything from the screen you are reading to the toilet you sat on to the truck that got you there to the seat... you get the pitcher...
  16. Jun 18, 2021 at 7:01 AM
    #56
    Tacowin1013
    One of my coworkers has a f150 and hasn't changed the oil in 22k miles. is that the kind of used car you want? lol no thanks for me!
  17. Jun 18, 2021 at 7:02 AM
    #57
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    While i was grocery shopping a 2016 tacoma owner pulled in parking next to me, and we chatted for awhile how with him asking how i like my truck. Well the oil change interval came up. He's had toyota do all his service at their recommended 10k mile oil changes. Right now his truck has nearly 90k and doesn't burn a drop of oil. Sounds good enough for me.
  18. Jun 18, 2021 at 7:03 AM
    #58
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Buy it? I just stick my hand in the tank behind my local AutoZone. Free oil! It's also a good place to get free hydraulic, gear oil and tranny fluid. Luckily they keep it all in the same tank.
    I find it really saves time and money to get it all mixed together.
  19. Jun 18, 2021 at 7:04 AM
    #59
    Itchyfeet
    Itchyfeet Well-Known Member
    I don't see a recreational oil change as environmentally damaging as DINKs living in a 3800 sq foot house where they only sleep in one room at a comfortable 68 degrees in Tucson AZ as a TV the size of a sheet of plywood needs to be installed in every room as the pool pumps hums out their favorite song to keep the pool clean that they use four times a year as the kitschy t-shirt they bought for Cinco De Mayo lays in the trash on this hot summer day.
    I can recycle the oil
    blu92in99 likes this.
  20. Jun 18, 2021 at 7:07 AM
    #60
    zoo truck
    None
    Its even better here at the towns local recycling containers used oil, atf, and coolant tank combined. Its an all in one stop shopping.
    Junkhead and Lt. Dangle[QUOTED] like this.
