Are the spark plug tubes threaded or press fit on 2.7
Discussion in '1st Gen. Tacomas (1995-2004)' started by MainerDave19995VZ, Jun 13, 2017.
  1. Jun 13, 2017 at 8:13 PM
    MainerDave19995VZ
    MainerDave19995VZ [OP] Well-Known Member
    David
    Maine
    1999 Tacoma Extra Cab SR5 TRD 5 Speed 5VZFE
    2nd generation 16" wheels with 1.25" BORA spacers
    Trying to get a tube out of a 2002 2.7. Are these press fit or threaded?
  2. Jun 14, 2017 at 12:00 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    They are pressed in with a protrusion of 47mm. The service manual says to use "Sealant: Part No. 08833 - 00070, Adhesive 1324, THREE BOND 1324 or equivalent"
    This is from the 1996 repair manual. Get a copy of the repair manual to see the procedure.
    I'm not sure if you need to heat it or what to get the old tube out. The repair manual assumes you put new tubes into a new cylinder head, but that you never need to remove them.
    MainerDave19995VZ[OP] likes this.
