Are the upper bearing plates replaced during a frame replacement for a 02 tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mjl, Jun 23, 2010.
  1. Jun 23, 2010 at 8:14 AM
    mjl
    mjl [OP] Active Member
    Kingston, ON
    Just wondering if the upper bearing plates are replaced during a frame replacement? Mine are so rusted that theres no way I can get the strut out without cutting the bolts. When I called last week to get a price Toyota told me they're $120 each. My truck going in for a frame inspection on Monday and will fail. Just wondering if these are included or if toyota's gonna change me for a new set.
  2. Jun 23, 2010 at 2:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Some of the folks that have had their frame replaced have also convinced their dealers to change out items like shocks and springs. As I recall, those dealers did not charge for the labor for those installations since replacing the frame involved having to remove the old stuff anyway.
