Are their anchor holes underneath plastic rail cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Luidelaparra, May 27, 2011.
  1. May 27, 2011 at 5:40 PM
    Luidelaparra
    Luidelaparra [OP] Member
    Lui
    2011 tacoma SR5
    Hey guys and gals,
    First off, I am new here and want to say hello. Also I am a jeep convert and this is both my first pickup truck and my first Tacoma. So I have a 2011 access cab Tacoma and I am looking to get either the roll n lock or pace edward tonneau cover for my truck. First off, which one would you experts recommend? It needs first and for most to provide locking security. my real question however is so forth: I want to install a light duty contractor rack for my surfboards (I can't have them hanging out the back for security / parking concerns) are the any anchor holes (square holes in four spots on most trucks) under the cap which sits on top of the bed walls? I know I could look but this is my first new truck so I am hesitant to disassemble anything without a purpose. If not, are there any solutions that would allow me to do both. I know any locking tonneau cover disallows use of my bed rails. If it helps I am looking to do go with the Abra contractor racks with the roll and lock tonneau cover. Thanks for the help! And nice to meet you all.
  2. May 27, 2011 at 5:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    There are no stake holes under the rail caps
  3. May 27, 2011 at 5:56 PM
    OZ-T
    Peter North
    British Columbia
    I dug up a pic I had
    The square holes you see do not have pockets beneath them like the traditional type
  4. May 27, 2011 at 5:59 PM
    OZ-T
    Peter North
    British Columbia
    Most Tacoma accesories like headache racks and lumber / ladder racks mount on the bedsides and attach to the factory bed rails with threaded rod or bolts .
  5. May 27, 2011 at 9:33 PM
    OZ-T
    Peter North
    British Columbia
    Mounted using the factory bed rails
  6. May 27, 2011 at 9:35 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    What kind of bolts are you using to attach that?
  7. May 27, 2011 at 9:37 PM
    OZ-T
    Peter North
    British Columbia
    They are just regular bolts with washers on the heads , you slide them into the track from the end .
    The nuts are what is visible on this side .
  8. May 27, 2011 at 9:52 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    OOOooooOoooo!! Hey that's pretty smart, OZ-T!! Looks good too!
  9. May 27, 2011 at 9:56 PM
    Luidelaparra
    Lui
    2011 tacoma SR5
    Yeah, I see what you are saying. Thank you kindly for the pictures. My problem is the tonneau covers that do a good job against theft all require the full use of or replacement of the rail system. Can you think of any way around this? I can't tell from the picture but it looks like the second hole is just behind the rear wheel well. is there a third at the end. I am not looking for anything crazy I only need to hold maybe 2 60 pound surfboards (60 pounds is a exaggeration) and the weight of the rack itself. Would the side walls of the bed (can anyone tell me the name for those walls) hold this weight if i either bolted a plate sandwhich style into those holes? Is this a really stupid idea? can anyone think of a way to get the best of both worlds, maybe a rack that can attach behind the track of tonneau cover that is thin, say, less than a .25 inch? thank you
  10. May 27, 2011 at 10:02 PM
    OZ-T
    Peter North
    British Columbia
    The problem is that there really is only some sheet metal meeting the composite under the bed caps as you see in the pic .
    Would the factory roof rack work or would the boards be too akward up there ?
  11. May 27, 2011 at 10:17 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Not to thread jack but where did you get that Back Rack Oz-T ??
  12. May 27, 2011 at 10:18 PM
    Luidelaparra
    Lui
    2011 tacoma SR5
    grr, sheet metal....I see what you are saying, probably not a good idea. Are the holes that are there used solely for attaching the plastic piece to the wall? The factory roof rack would work I guess but I have 2 9 foot 6" boards and I feel I need more space between the supports to prevent flex and cracking. ok, it is back to the drawing board...any smart ideas?
  13. May 27, 2011 at 10:21 PM
    OZ-T
    Peter North
    British Columbia
    They can be purchased at a local Truck accessory place here in BC .
  14. May 27, 2011 at 10:21 PM
    OZ-T
    Peter North
    British Columbia
    Are you getting a hard or soft tonneau ?
  15. May 27, 2011 at 10:24 PM
    TacomaBuzz
    CT
    Very nice! Never seen one like that around here:mad:
  16. May 27, 2011 at 10:27 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    ive never seen this much oz helpfulness. it must be because of his ice skating team.
  17. May 27, 2011 at 10:28 PM
    Luidelaparra
    Lui
    2011 tacoma SR5
    I am getting a hard tonneau, I need it to keep the thieves at bay for three reasons: 1. I tend to surf in areas which are not altogether safe 2. I tend to haul very expensive equipment 3. due to my job my truck tends to sit in parking garages for 8 - 10 hours at a clip. for clarity I am looking for something like this:
    http://www.agricover.com/index.php/products/category/C204/
    The other option I was thinking of is getting a rack like you pictured and bolting it behind the track for the cover so the cover could roll out. the weight of the boards would be distributed along the rail and again it is not that much. could I get away with this?
  18. May 27, 2011 at 10:29 PM
    TacomaBuzz
    CT
    Meh, he finally found love in farm animals:eek:
  19. May 27, 2011 at 10:34 PM
    jgwheeler17
    NC
    neglect, mostly.
    i'll be honest, i don't completely understand what youre trying to get, specifically the function of it. but i wouldn't pay those prices for something like that. you could likely have somebody build you that exact same type of rig for half the price. just sayin (in a nice way)
  20. May 27, 2011 at 10:34 PM
    OZ-T
    Peter North
    British Columbia
    I was wondering if you could get cross rails atttached to the top of your hard tonneau
