Are there 01-04 Tacos in the Salt Belt that is immune to rusty frames?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Dec 19, 2009.
  1. Dec 19, 2009 at 9:22 AM
    ywen
    ywen [OP] Well-Known Member
    Is it a matter of fact that ALL 01-04 Tacos suffer from the rust issue if it has been primarily driven in the rust belt? Or are some fortunate few less immune from it?
  2. Dec 19, 2009 at 9:48 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    My neighbor has an '02 that got the "treatment"...and the "Exteneded 15 year warranty", My '02 was re-framed....One of our operators has an '01,it got the "treatment" also while another driver ,re-frame on his '01...
    Not sure what the exact % are BUT up here in NH looks about 50/50....
    Can anyone give me the %'s of how many Dodge,Ford and GM frames were done :confused:..;)
    S
  3. Dec 19, 2009 at 10:38 AM
    ywen
    So that leads to another question... is the rust ratio of Tacomas on par with the other trucks? Or are Tacomas significantly more prone to catastrophic rusting?
    See with toyota doing the buybacks and re-framing, it could be that they stand behind their products, but more than that it also makes it seem like something is out of the ordinarily wrong with the frames on these trucks...
  4. Dec 19, 2009 at 10:55 AM
    BG04Taco
    BG04Taco Well-Known Member
    Edmond, OKLA
    04 2.7 SR5 4X4
    ARE Camper, JL Audio, Line-X, Yakima roof rack, odyssey 1500, red line hood struts
    Im not in the salt belt but I gave my dealership my vin and they said my vin was not one of concern. But I have very little rust on my frame anyway but I checked because I could move into a salt belt area.
  5. Dec 21, 2009 at 7:04 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    i have a 04 tacoma and the frame was really clean when i picked it up, i sprayed her down with some 30 weight oil ( non detergant ) and its good to go!
  6. Dec 21, 2009 at 7:10 PM
    BG04Taco
    Edmond, OKLA
    04 2.7 SR5 4X4
    I heard wd 40 from someone. I would use any solution for the problem. I really dont like the undercoating all over everything.
  7. Dec 21, 2009 at 7:14 PM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    not real sure what the "salt belt" is but my truck came from VT before i bought it, and theres not a spec of rust of the whole truck....well there is a small spec on the rear bumper about the size of a pea :rolleyes:
  8. Dec 21, 2009 at 7:16 PM
    ywen
    What do you mean when you picked it up? You mean you bought it recently used? Has the trucked lived in Ohio its whole life?
  9. Jan 12, 2010 at 5:59 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    yup been in ohio all of its life it was used. i mean some surface rust like everything else. nothing bad at all. powerwashed it really good with hot water let it dry for two days and coated it in every nook and cranny.
  10. Jan 12, 2010 at 6:20 PM
    ywen
    how do you tell something is surface rust? Should it come off with a rag? or do you need to use wire brush to remove surface rust?
  11. Jan 13, 2010 at 7:55 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    surface rust is like when you leave a piece of steel outside when it is not painted. Just the surface rusted.
    surface rust.... [​IMG]
    really rusted out..... Spaar_Rf_inner_frame_rail_cd34c8ab5cefa5eee78a90ed2aae56b69d67c655.jpg
    the difference is in the second picture the steel is so rusty it will start to flake off. In the first it is just on the surface not weaking the steel or flaking off. someone please correct me if i am wrong
  12. Jan 13, 2010 at 10:25 PM
    ywen
    so there is no way in the first pic that the rust is thru the steel? In other words, if the rust is thru the steel, it will start to look like pic 2?
  13. Jan 14, 2010 at 4:45 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    correct!!
  14. Jan 15, 2010 at 2:14 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Someone correct me if I'm wrong, but DANA manufactured the frames for our trucks. They came from 2 plants and the frames from one of the plants didn't get the proper rust proofing applied and now they're rusting out.
    The 01-04s get new frames because they still make the frame used on those trucks.
    For the older trucks, the frames are no longer being manufactured, so Toyota just pays you to crush it.
    As for the domestic trucks getting reframed... There's no way any of the big 3 would ever stand behind their vehicles as far as to put new frames on them.
  15. Jan 17, 2010 at 8:17 PM
    ywen
    I looked at the driver side frame which is visible when looking down from the engine bay. It looks like the weld point of the engine mount to the frame is all rusted and flaking off. I was able to push pieces off with my flash light...
