Are there frame differences with the new TX versions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PMK, Dec 25, 2012.
  1. Dec 25, 2012 at 1:25 AM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Does anyone know if the later series TX trucks have a different frame, similar to the braced X Runner street truck?
    I was researching info about installing the "X" brace (which is supposedly why the X Runner is named) and found some press release info in just one article mentioning the TX series were beefed up.
    I have not seen it mentioned on TW any where. Most posts about the TX series or TX Baja slam the truck and say it is overpriced options.
    Anyone ever crawl underneath both an off-road model and a TX Baja side by side and compare?
    Maybe the "X" in TX is for a braced frame similar to the X Runner.
    Thanks
    PK
  2. Dec 25, 2012 at 2:04 AM
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    No brace that I saw.
    Different wheels and some other goodies though.
  3. Dec 25, 2012 at 5:15 PM
    PMK
    Florida
    10 DCLB TRD Sport
    TTT,
    if I can find out for certain I may trade in the 2010 prerunner DCLB with low miles and get the newer truck, just need to make it happen before 2013.
    PK
