Are there something wrong with my tires? please help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hockey1chick, Oct 14, 2009.
  1. Oct 14, 2009 at 10:27 PM
    #41
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    this
    is completely wrong
    Tire pressure is EVERYTHING and can make the difference between you rolling your truck and successfully avoiding an obstacle in the roadway
    OP
    try dropping your PSI by a little bit (im not sure what youre running now though) but not too much and switching tires
    this slippage you experienced today was probably a combination of improper tire inflation, first rain slick, and AT tires
    everyone can say what they want to about their tires and this one works great etc etc...but on asphalt and pavement...those tires are not designed to push the water away and contact the rubber with the road. PERIOD
    if you dont want to slip then buy street tires that are designed for wet roads...otherwise...learn to operate around the issue...which the OP seems to have been able to do...
  2. Oct 14, 2009 at 10:27 PM
    #42
    hockey1chick
    hockey1chick [OP] Well-Known Member
    Redondo Beach CA
    Toyota Tacoma PreRunner Sports
    RBP grilles, Flowmaster 40 series muffler, BF Goodrich All Terrain tires, MotoMetal Rims, Smittybuild stepers, tip..debadge-- no chrome for me!, front windows , tailights, fog lights and front headlights tinted!!
    Thank u guys for all ur great advice --it's greatly appreciated --i just want to say (ok mushy)but it's pretty inspiring to see good --the effort put into helping another fellow tacoma lover --it just makes this such an inspiring site --the 1 thing u think of what ur truck starts thinking it has a mind of it's own (down boy or in my case girl!!!) --i can say that that was what i was thinking this evening on my way home!!!!
    I LOVE U MAN!!!!!!! =)
  3. Oct 14, 2009 at 10:31 PM
    #43
    hockey1chick
    Redondo Beach CA
    i totally agree -- i have to 'tame the beast'!!!! =) --thanks will keep this in mind the next time it rains!
  4. Oct 14, 2009 at 10:32 PM
    #44
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Isn't that what I was saying ? Except for the tire inflation part, how can you tell her to lower her psi when you don't know her inflation ?
  5. Oct 14, 2009 at 10:35 PM
    #45
    JimBeam
    JB
    2015 Tundra
    no you said the pressure thing is for offroad...
    tire pressure on road can save your life
    the difference of 2psi can change how a vehicle handles in an emergency maneuver
    ive seen it in a completely controlled environment
    the tread pattern does help...but with proper siping and pressure you can not worry about tread pattern
  6. Oct 14, 2009 at 10:38 PM
    #46
    JimBeam
    JB
    2015 Tundra
    because more than likely her tires are overfilled rather than underfilled
  7. Oct 14, 2009 at 10:41 PM
    #47
    Asgard
    I was thinking if the tire was overinflated, causing a smaller contact patch, she would have that problem on dry pavement also.
  8. Oct 14, 2009 at 10:48 PM
    #48
    JimBeam
    JB
    2015 Tundra
    not necessarily under normal driving conditions...however if she were to make an emergency maneuver its possible she wouldnt be able to retain control of the truck and either skid/slide/roll
    i say she was probably overinflated because theres a "max" printed on most tires etc etc...and sometimes radials will LOOK underinflated...and so people either fill till they LOOK good or hit the max
  9. Oct 14, 2009 at 11:52 PM
    #49
    Asgard
    I was referring to underinflating the tires for better grip.
  10. Oct 15, 2009 at 12:17 AM
    #50
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    That's cause the Diesel has another 1000 pounds on it's weight versus the Tacoma. Helps to push the water out from under the tires.
    Don't take this the wrong way, but how old are you?
  11. Oct 15, 2009 at 12:19 AM
    #51
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    When your truck swerved, did you hit a puddle. My truck swerve when I hit a puddle. Its hydroplaning The tires are not making contact with the pavement instead its floating across it and being resisted by water. thus making it feel like you swerved.
  12. Oct 15, 2009 at 12:23 AM
    #52
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    That's not hydro planing. Hydro planing feels like your driving on ice when it's quite obviously water. The truck will begin to dance side to side a little if you keep it under control and are going in a straight line.
    What you're describing is just the resistance of the water on the vehicle's tires slowing it down. Not hydroplaning at all FYI.
  13. Oct 15, 2009 at 12:32 AM
    #53
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    ^Problem solved. We hashed it out over PM's.
    :anonymous:
  14. Oct 15, 2009 at 12:32 AM
    #54
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    well then it sounds like here tire are being resisted by water. Nothing is defective.
  15. Oct 15, 2009 at 12:33 AM
    #55
    JimBeam
    JB
    2015 Tundra
    correct
    hydroplaning essentially is your tire loses contact with the pavement and sits up on a layer of water and has very little friction or control
    youll know when you hydroplane...your RPMs will jump thru the roof and you may experience swerving or sliding
    remember to ease off the accelerator, stay away from the brake, and turn into the skid as necessary :thumbsup:
  16. Oct 15, 2009 at 12:35 AM
    #56
    JimBeam
    JB
    2015 Tundra
    i dont think what she described is either...i think its just a plain lack of traction on wet pavement
  17. Oct 15, 2009 at 12:39 AM
    #57
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    We got the first rain here today and man were the streets slick. Definately need to get all that crap off the pavement. I could easily spin the tires taking off from any stop light, and on one turn the rear broke loose a tad on my morning commute. I was kinda expecting it at some point during the drive actually, so I was prepared for such occurrence. I think I might wanna air my tires down a tad; i've been running 40 through the summer, time to go back to 30 now maybe.
  18. Oct 15, 2009 at 12:46 AM
    #58
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    You can't drive it like you stole it in the rain. You have to be a little lighter on start offs. And taking curves don't sling it like you do on dry pavement. I have a heavy foot also, but you have to back off a little when it is raining.
    When you are ready for new tires maybe look at getting a better tire. If you have a 4x2 then I would suggest the Nitto NT420's. Best tire I have ever had. Very grippy dry & wet. And great treadwear. I have 40,000 miles on them & they barely look used.
  19. Oct 15, 2009 at 12:53 AM
    #59
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Hmmm, I noticed my 09 w/ stock dunlops truck NOT skidding at starts or even quick turns as much as my gen1 w/ goodyear A/T tires.
    I always thought it was due to the anti-skid stuff.
  20. Oct 15, 2009 at 1:00 AM
    #60
    StandingCow
    NJ
    Yea, I hadn't yet finished the thread when I posted that. Apparently it has to do with the AT vs Street tire, as you said, the contact patch.
    From my experience going from AT to Street, right foot has less to do with it than tread. I accelerate the same as in my old truck (with the A/Ts) as I do in the new (road tires) and do not skid.
    Not a big deal, I just learned in my old truck not to hit the gas hard at all in the rain.
