Are these All-Pro Wheel Spacers??
Discussion in 'Wheels & Tires' started by bassTaco, Nov 15, 2011.
  1. Nov 15, 2011 at 7:45 AM
    bassTaco
    bassTaco [OP] Active Member
    Rick
    Austin, TX
    04 Tacoma D-Cab Prerunner V6
    I found these on craiglist and thinking about getting them for my 2004 D-Cab Tacoma. Do you know how to tell if the wheel spacers are from All-Pro? PN inscribed or logo somewhere on the part? They definetetly look like All-Pro from the picture.
    http://austin.craigslist.org/pts/2703044178.html
  2. Nov 15, 2011 at 7:50 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Looks like it to me.
  3. Nov 15, 2011 at 7:59 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    Lug centric = bad. If you want all pro wheel spacers order some new hub centric directly from them. Just my 2 cents.
  4. Nov 15, 2011 at 8:38 AM
    bassTaco
    Rick
    Austin, TX
    I have lug centric hubs. Will hub centric wheel spacers still work with my hubs?
    By the way, I got the PN from the person selling these. They appear to be Billet Wheel Spacers which are the same wheel spacers All-Pro Offroad carry. [FONT=&quot]Here it is, 6550[/FONT][FONT=&quot]-[/FONT][FONT=&quot]6550C108. Basically its a 6x5.5 bolt pattern with 108mm bore.[/FONT][FONT=&quot]
    [/FONT]
  5. Nov 15, 2011 at 10:58 AM
    woodside783
    woodside783 Well-Known Member
    Casey
    Nashville
    Tacoma 4x4
    how strong are these spacers?
  6. Nov 15, 2011 at 11:07 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    They do look like the AP wheel spacers.
    If your truck is lug centric then keep it that way.
  7. Nov 15, 2011 at 11:38 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What do you mean by you have lug-centric hubs? Like they don't have a hub ring to accept a wheel bore at all?
  8. Nov 15, 2011 at 11:42 AM
    bassTaco
    Rick
    Austin, TX
    I am going to take the wheel off tonight to make certain on the centric design on my truck. By the way, reading previous posts about hub-centric vs lug-centric, it appears most, if not, all aftermarket wheels are lug-centric so why would hub-centric wheel spacers matter for aftermarket wheels. It does appear though that the OEM wheels are hub-centric as I believe I noticed this on mine when I popped the wheel hub cover off. So my hubs may not be lug centric as I first thought, however, from what I read it appears hub-centric wheel spacers are only effective for OEM wheels. Does this sound correct?
  9. Nov 15, 2011 at 11:46 AM
    KPT
    09 Prerunner
    The reasoning is that the more hub-centric connections you have, the less chance for vibes. If you buy hub-centric wheel spacers, then the spacer will be centered on the hub, even if the wheel isn't exactly centered on the spacer.
    If you buy non-hubcrentic spacers, then the spacer won't be centered on the hub, and the wheel also won't be centered on the spacer
  10. Nov 15, 2011 at 11:54 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2014 TRD Off-Road
    TacoAlaMode Custom grill, SCS Gunmetal F5's, Treadwright guard dogs, King extended travel coilovers w/800# springs, OME Dakars. LRUCA's. Allpro off-road plate rear bumper with high clearance hitch, steel breaded extended brake lines front and rear, SOS concepts bolt on rock sliders with top plate, Pelfreybuilt front plate bumper, rci skid plates, Airflow Snorkel, Tom Woods custom one piece drivesahft, Weathertech in channel rain guards, Bushwacker fender flares, custom cab height bedrack, 60" Hi-Lift jack w/Mount, Recon 10,500lb waterproof winch with synthetic line, rear bumper light pods, front bumper light pods and light bar.
    X2
    Go to allpro's website. A set of new hubcentric wheel spacers are not that much more then that guy is asking for his used ones. Either way, get a tube of loctite when you install them.
  11. Nov 15, 2011 at 12:05 PM
    bassTaco
    Rick
    Austin, TX
    KPT,
    I see what you are saying now. I grabbed this pic from the "DIY Front Brake Pad Change" thread to use as an example. The wheel spacer below is lug-centric, plus, you can see how the wheel spacer attaches to the hub has a gap...so not fitting to the hub flange. A wheel spacer that is hub-centric fits to the hub flange (no gap), plus, hub-centric to the wheel if its hub-centric like the OEM stock wheels.
    Thanks guys! Case closed!
