Are these drop in led lights any good?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ron197, Feb 8, 2021.
  1. Feb 8, 2021 at 4:14 AM
    ron197
    ron197 [OP] Active Member
  2. Feb 8, 2021 at 4:27 AM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    I’ve modded many of vehicle over the years. I’ve learned lessons, sometimes the hard way, about buying cheap parts from Amazon/eBay... as far as lights go, be prepared to do a little extra work. The best thing that you can do for knockoff lights is to seal them. All around the edge where the outer lens meets the body of the light, there will be a gap. Take your finger and a small tube of clear silicone and fill the entire gap all around the outside edge. This will greatly reduce the risk of your lights filling with water and condensation. As far as the LED’s go... it’s a roll of the dice. They may be great and last a long time as stated, or they may start dropping diodes in the first year. It’s just the nature of the beast. And when mounting them, don’t torque them down too tight. A lot of times the lower end parts will use lower end qualities of plastic. You don’t want to break a mounting tab off before you get to enjoy them. And last but not least... make sure they aren’t shipping from overseas! You can change this in the filter, under item location. If you get them from China, they’ll take forever to get to you. And if there’s a problem, you’ll most likely spend more money waiting and shipping than the lights are even worth. Hope this helps in your decision, and good luck with your build! Keep updated and post pics!
    jnossoff likes this.
  3. Feb 8, 2021 at 4:31 AM
    ron197
    I'm still torn between something like these leds or hellas that others have suggested.
  4. Feb 8, 2021 at 4:34 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    You can’t go wrong with the Hellas. In fact, I’m about to buy six of their 550 series off-road lights. Just gotta save up a bit more change before I can pull the plug. If Hella is an option for you, I would definitely suggest you go that route.
  5. Feb 8, 2021 at 4:37 AM
    ron197
    There seems to be no lumens rating on the Hellas....yes i know it depends on the bulb.
  6. Feb 8, 2021 at 4:44 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Absolutely, most of them are your typical 12v and I believe 55w setups. So you can expect a typical halogen light output. And remember... it’s not as much the bulb your buying... your buying the quality of the lens and housing. You can have the best PIAA bulbs for $200 and shitty housing and lens and you’ll still have a crappy setup. You have a Hella housing and lens, add a PIAA bulb kit later and you’ll have one of the best setups you can ask for. Good things take time, and sometimes that means saving up more $$$ before you get why your looking for. If you just jump on the cheapest thing you find... be prepared for a big let down.
  7. Feb 8, 2021 at 4:54 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    There’s also the other option of BHLM. You can deconstruct your lights completely, separate lens from housing. Take the housing to a local paint shop, have them painted whatever color. Most go black, but I’ve seen some color matched to the truck and looks pretty good! Then carefully seal and reassemble. Add a LED conversion kit or some hi end bulbs (PIAA) and you’ll have some pretty dope OEM lights... just another thought. There’s a guy on here @no vtec 4me that does headlight work. Not sure if he can work his magic on yours but worth dropping him a message!
  8. Feb 8, 2021 at 6:37 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You can't do the BHLM without adding a HID/LED projector to the 95-97 headlights. The only thing to paint is the reflective housing.
  9. Feb 8, 2021 at 7:28 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Right... which would be called a Black HeadLight Mod (BHLM). He wouldn’t have to go full on and spend $1k. You do not need to do all of that to do a BHLM. It’s optional.
  10. Feb 8, 2021 at 10:18 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    But it's not an option unless he gets a retrofit cause the only thing to paint is the actual reflector which is needed in order for the lights to work. There isn't anything else to paint.
  11. Feb 8, 2021 at 11:15 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Judging by the fact it's an Amazon link, I'm going to go ahead and assume the answer is no.
  12. Feb 8, 2021 at 4:48 PM
    ron197
  13. Feb 8, 2021 at 5:15 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    looks like to much foreground light to be DOT compliant to me
    also looked a little high on the garage door, but that might be do to slope
  14. Feb 8, 2021 at 7:02 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Only difference is the sharpness of the cutoff.
    Hella ECE E-codes
    Hella Vision Plus E-codes
  15. Apr 15, 2023 at 2:26 PM
    Tacoma1289
    Tacoma1289 New Member
    95 Tacoma
    Hey guys so I bought the 5x7” 7x6 led lights for my 95 Tacoma sr5 and the housing bracket doesn’t allow the lights to sit flush inside them. But it says they should fit my 95.. do y’all have any idea why it’s not fitting?
  16. Apr 16, 2023 at 6:08 AM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    I got these and installed them several years ago. Great so far. No issues with fitment. Have to have the additional harness with relays. No issues running that from side to side, didn't follow the vid exactly for that install. Mounted relays to existing holes near battery.
    Tacoma1289 likes this.
