are these good deals for welders torches?
Discussion in 'Garage / Workshop' started by fireturk41, Jul 21, 2010.
  1. Jul 21, 2010 at 9:36 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
  2. Jul 21, 2010 at 9:49 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    well ask yourself this first.. what would you use the torch for?? and is it really needed.... to date i still don't have a torch in my shop, just no need for it.
  3. Jul 21, 2010 at 9:51 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    the only reason i can think of the torch is to cut and weld atleast until i got a welder, but if i buy the welder i always have a sawsall
  4. Jul 21, 2010 at 9:59 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i too want to get into welding and fabrication. stick is messy and ive heard its pretty tough to do. ive also heard its the strongest? personally i want mig. for 700 you could buy a new lincoln powermig 180c
  5. Jul 21, 2010 at 10:00 PM
    Fire931
    VA
    00 4Runner
    i could see using the torch to cut some, although it leaves a really rough cut that will require cleaning up afterwards but you'll be better off using an actual welder to weld versus a torch.. and as far as starting off your best bet for cutting and not having to clean it up afterwards is a grinder with a cut off wheel. that will leave a nice clean cut for you (provided you can keep it going straight)
    i would recommend getting a good welder first. i have a lincoln 180 that has been an awesome machine, very capable
  6. Jul 21, 2010 at 10:02 PM
    Fire931
    VA
    00 4Runner
    mig is plenty strong if done right... the thing with any weld type is it all depends on the capabilities of the operator... you can have the best welder in the world but if you don't know how to work it its just a big paper weight... and remember practice makes... well better alteast :D
  7. Jul 21, 2010 at 10:05 PM
    Yoytoda
    Roland
    completely stock
    as long as you practice right. if you practice shitty youll just pick up bad habbits.
  8. Jul 21, 2010 at 10:05 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    i might save up a few hundred more dollars then, ive got sawzalls, grinders, and a vise i just need a tubing bender and a welder i think lol
    i need a dang real job first though
  9. Jul 21, 2010 at 10:13 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I used to do some metal fab (unfortunately no truck stuff). I only used a torch for cutting and heating steel for bending. I'd go for a good wire fed welder first. The arc welders are good to learn on, but unless you're going to welding on farm equipment, I'd go with a wire fed welder, chop saw and angle grinder.
  10. Jul 21, 2010 at 11:19 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    What do you plan to weld?
  11. Jul 21, 2010 at 11:21 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    wanna practice and start fabbing sliders bumpers ect
  12. Jul 21, 2010 at 11:28 PM
    Tacorunner87
    Chino Hills Ca
    To much to list!
    I would recommend not getting a stick welder, Save some money and pick up a mig welder. If you can afford a 220v mig go that route if not you can get buy with a 110v welder. Benders can add up really fast. But get yourself a nice grinder,drill, vise. You can make a harborfreight notcher work by shimming it or buy a nice one like a jd2 or something.
