Are these too good to be true? Will they cause problems on my truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nicky4x4, Nov 25, 2024.
  1. Nov 25, 2024 at 8:48 PM
    Nicky4x4
    Nicky4x4 [OP] Member
    2023 TRD OR DCSB AUTO
  2. Nov 26, 2024 at 7:24 AM
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    I've got the Rough Country steelies in a 17x9 -12 with zero rubbing on a 265/65r17 tire. So far so good for me. Make sure to get some acorn lug nuts as they are not hub centric and will not accept the OEM lugs.
    For steelies they balanced pretty good in my case.
    BoomerGVNG likes this.
  3. Nov 26, 2024 at 8:09 AM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    Should be good buddy
  4. Nov 26, 2024 at 8:12 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    heavier but not too heavy. they will rust as they are steel. but better for wheeling as they will bend and not crack if you hit a rock. classic look too.
  5. Nov 26, 2024 at 8:14 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    CCP steelies are okay. Certain E rated 285 tires can make your wheel/tire combination super heavy though.
    I usually buy the knock offs that look like FJ cruiser steelies. Some of them will even fit the black Toyota center caps, but that’s not always the case.
    Fun fact: the Chinese factories usually paint them better than Toyota does with their OEM wheels.
  6. Nov 26, 2024 at 9:53 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The design may not clear your brake calipers
    4.5" center bore is 114mm. You'll need hubcentric rings to space it down to 106mm.
    -12mm offset will need fender flare trimming to clear 265/75-16 tires.
    jmneill likes this.
  7. Nov 26, 2024 at 2:53 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'd suggest used tacoma aluminum rims over steelies.
