Are these turbos easy to replace.
Discussion in '4th Gen. Tacomas (2024+)' started by JDKred, Jun 22, 2025 at 2:22 PM.
  1. Jun 23, 2025 at 8:34 AM
    #81
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  2. Jun 23, 2025 at 8:35 AM
    #82
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    TCCN says there's an electric pump at 12:00 in the video, so...
  3. Jun 23, 2025 at 8:37 AM
    #83
    JDKred
    JDKred [OP] Well-Known Member
    JD
    16 MT KDMax Tuned
    The turbo is in the front on the tacomas and I thought they had an electronic controlled waste gate as well?
    HondaGM likes this.
  4. Jun 23, 2025 at 8:40 AM
    #84
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That may be for the Highlanders and Lexus SUV's. Parts diagrams are confusing AF, but I've never heard a pump after shutdown on my truck like I did on my MK7 GTI that did have one.
    gpb[QUOTED] and HondaGM like this.
  5. Jun 23, 2025 at 8:40 AM
    #85
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Vacuum operated. Tundra's have the electronic one.
  6. Jun 23, 2025 at 8:43 AM
    #86
    JDKred
    JD
    16 MT KDMax Tuned
    how does does that effect throttle response?
    I thought I saw a video on Engineering explained, where he talks about this being an issue with mechanical waste gates.
  7. Jun 23, 2025 at 8:49 AM
    #87
    Bitflogger
    Bitflogger Well-Known Member
    2024 TRD OR long bed
    The "just heard" can mean a lot of things, and a lot who spread anecdotal stuff about turbochargers in gasoline and smaller engines have old bad info or wrong assumptions. Of course some fail but modern iterations are designed better.
    At this point we've got 5+ years with our turbocharged German car, and I'm near a year and 11-12,000 miles with the 4th gen Tacoma. From that experience I'm happy to take any risks associated with a turbo and especially for my at least annual while I'm at mountain elevations and the way you can operate a turbo in a frugal or powerful way.
    The annual Consumer Reports auto issues are worth considering. They poll owners backwards 10 years. You can see vehicles with problematic drivetrains and gone ones.
    ABA180 and JDKred[QUOTED][OP] like this.
  8. Jun 23, 2025 at 9:01 AM
    #88
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I don't think there's enough difference to really tell. Power is pretty linear with this engine IMO.
    JDKred[QUOTED][OP] likes this.
  9. Jun 23, 2025 at 9:12 AM
    #89
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Looks pretty easy peasy to me according to the manual, wouldn't be hard to make a manifold to adapt it to a different turbo either for those with the need for more power. Doubt under normal usage it would need replacement at any worrisome interval though, 200k easily with this kind of watercooled journal bearing unit.
    dneal, JDKred[OP] and Delta09 like this.
  10. Jun 23, 2025 at 9:44 AM
    #90
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    Would the turbo theoretically have a lighter workload with the detuned 2.4? Or a heavier workload bc it (might be) more likely to boost with the lower hp setup? Forgive my fundamental misunderstanding of how this thing works :anonymous:
  11. Jun 23, 2025 at 9:56 AM
    #91
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    I had 187K On my Subaru WRX when I sold it, I never had to Replace the turbo And I drove the shit out of that car.
    I think the Turbo on the Tacoma isnt somthing you need to worry about.
    ZigSchwartz, JDKred[OP] and Delta09 like this.
  12. Jun 23, 2025 at 10:02 AM
    #92
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Theoretically, if every other part was the same, you’ll probably have lower cylinder pressures on the destined version.
    but boost mapping isn’t always directly correlated like that.
    but probably yes.
  13. Jun 23, 2025 at 10:03 AM
    #93
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    my guess is its all about the boost...
    how do the 2 models compare in boost pressure at a specific speed, load, rpm...
    No idea...
    the sr is made to have less hp "de tuned" so dont see it making more boost...
  14. Jun 23, 2025 at 10:05 AM
    #94
    Speedytech7
    Pretty sure the modern convention Toyota uses is actually based on torque modeling/targeting and it brings the boost up or down to meet desired torque target (with limits of course, it doesn't just let it run past pre determined safe manifold pressures) but its easier to make response more predictable for the driver this way with changing environment variables and such.
  15. Jun 23, 2025 at 10:22 AM
    #95
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    That was the Indy race from yesterday, the Nascar race was a few weeks ago both races were Road America, sponsored by AMR presumably the same crews and same support vehicles. I thought Road America was a track, I don't follow any motorsports that closely. No that Silverado is pulling what looks to be a Chevy in reverse as the crew is walking in that direction I think I saw about two minutes of a wreck yesterday.
  16. Jun 23, 2025 at 10:35 AM
    #96
    batacoma
    batacoma Truck Wars
    I thought the Tacoma was only oil cooled for the turbo as it isn't putting out a lot of pressure compared to Tundra. I'm not sure about Ford but I'd think the 2.7 was water and oil cooled, and the 3.5 I put money on saying it water and oil. I keep an eye on the coolant in the reservoir, as it does not retain the bright yellow color of new coolant. Is it used coolant, is it coolant that got oil in it? Turbos do heat everything up epecially in tripple digit temps with high humidity.
    Edit I think anyone towing with a gas turbo should drain and fill the coolant more than what's recommended.
  17. Jun 23, 2025 at 10:36 AM
    #97
    OpeCity
    Long Beach, CA
    The Tacoma is most definitely water cooled.
    batacoma[QUOTED] likes this.
  18. Jun 23, 2025 at 10:44 AM
    #98
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    the blurb in the owners manual about letting it run for a minute after extended highway driving are bull. just in there to make grandpa happy. ive had my OR Iforce maxx go into auto stop coasting down an on ramp after 3 hours on the highway multiple times.
  19. Jun 23, 2025 at 10:44 AM
    #99
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    Do the hybrids have a sensor that prevents the engine from shutting down when decelerating/at a stop when the turbo is hot or does the electric water cooling take care of that?
  20. Jun 23, 2025 at 10:55 AM
    #100
    batacoma
    batacoma Truck Wars
    I would've thought so being a modern design, maybe that's where the increased cooling comes from on SR5 and, SR probably still gets water cooling for the turbo but not as much. Maybe Tundra got some water cooling to assist with cooling the charged air, and I think that was an advantage on the cooling side that Ford does not have even on the 3.5
