Are these wheels hubcentric?
Discussion in 'Wheels & Tires' started by Sunner, May 15, 2012.
  1. May 15, 2012 at 8:34 PM
    Sunner
    Sunner [OP] Well-Known Member
    Sorry for my lack of knowledge on this, I looked up the definition but I still couldnt make the connection, thanks for your help
  2. May 15, 2012 at 8:52 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    Can't tell from the info given. You'll need to find out the hub bore size. If not, you can still use them just make sure to get adapters and the right lug nuts.
  3. May 15, 2012 at 8:56 PM
    Sunner
    Hmm ok. I think Ill have to call wheeler's tomorrrow and find out, I need to know to see which type of spacer I need, thank you though buddy.
  4. May 15, 2012 at 9:03 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    They are not. I ran these for a few months and had to use those hubcenteric rings.
  5. May 15, 2012 at 9:13 PM
    Sunner
    Where did you get your rings from? Is there any issue with running spacers on the rings?
  6. May 16, 2012 at 6:09 AM
    sandjunkie
    Aaron
    OC
  7. May 16, 2012 at 6:33 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    I just got some new ProComp 16x8 wheels with my stock tires and am experiencing horrible steering wheel shakes. I don't think my wheels are hubcentric and I think I need the spacers. Does this sound like a common problem? Should local tire shops have these available for install?
  8. May 16, 2012 at 10:36 AM
    sandjunkie
    Aaron
    OC
    Don't know about local tire shops having the rings in stock. I would also make sure you get a road force balance. These couple of things should cure your shakes.
  9. May 16, 2012 at 7:05 PM
    Sunner
    Bump
  10. May 16, 2012 at 11:57 PM
    DevL
    DevL Well-Known Member
    Hub centric means the wheel is centered on the hub and tou use flat factory styled lug nuts. Lug centric is flared nut hole with tapered acorn style lugs. The tapered shape means the hub just has to be big enough to fit and does not need to be precise because the lug nut holes will self center the wheel while tightening unless you dont seat the rim all the way. A ring is useless since it does not do anything if you have acorn style nuts.
  11. May 17, 2012 at 12:00 AM
    DevL
    If your wheels are not hub centric you do not need a hub ring... you need your tires balanced.
  12. May 17, 2012 at 12:01 AM
    DevL
    Not hub centric... just use acorn style nuts.
  13. May 17, 2012 at 12:55 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    the Toyota Tacoma's are lug centric...
    the Wheeler's steelies are lug centric...
    I ran them on my '00 Tacoma for years...
    they will balance fine... using a lug centric backing plate...
    Unless something else on the front end is to blame.
    Most tire shops will balance using a cone front and rear on the balance machine...
    unless you ask specifically for use of a lug centric backing plate...
    Some tire shops still act like they don't know... or are lazy about it
    If no lug centric backing plate is used...
    it can be a hit or a miss deal...
    sometimes you get lucky
    The lug centric backing plate is used as well when road force balancing.
    For those running aft. mrkt. alloys...
    sometimes a standard 60* conical lug may not suffice and may be unsafe.
    Primarily because of the thickness of the wheel at the lug opening...
    In this case an ET (extended thread) lug nut will need to be fitted.
    It is still a 60* tapered lug...
    but has an extended crown that seats deeper into the wheel's lug openings
    and offers more thread bite...
    and in addition to that... the crown that extends into the wheels lug holes
    helping to center the wheel on the lug bolts.
    ^ ET lug nuts are not needed when running Wheeler's steelies...
    a standard 60* tapered acorn will suffice...
    I recently changeed out my Wheeler's type "B" steelies for
    ProComp 8069's... and came to realize the standard lugs
    used for the steelies would not suffice to center the wheels at the lug bolts properly...
    as well were unsafe... as they no longer had enough thread bite and balanced poorly.
    just sharing my experience
  14. May 17, 2012 at 7:22 AM
    Sunner
    Well sounds like I'll be fine with the lugcentrics, Ill use lugcentric spacers too. Thanks for the help everyone.
  15. May 17, 2012 at 8:20 AM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    Per johnny at wheelers, Those are lugcentric wheels. use the acorn style lugnuts they sell. You don't need hubcentric rings, in fact he said the hubcentric rings might not even work on the steel wheels.
    I have those wheels and the acorn style lugs on my tacoma, and have no vibes, so you should be all good. Just remember when you torque the lugnuts down, to do it while the tire is off the ground, not on the ground.
  16. May 17, 2012 at 8:31 AM
    Sunner
    Awesome, thanks buddy.
  17. May 17, 2012 at 8:37 AM
    TacomaPrime
    Gregory
    Illinois
    No prob. Trust me, I was worried about it too, but I have yet to have any vibes because of the wheels. I had discount tire mount them. Johnny said they have a couple rigs there running those wheels too and none of them have vibes.
  18. May 17, 2012 at 8:40 AM
    Sunner
    That does reassure me. Saves me additonal headaches, been having some bad luck with these wheels but looks like smooth sailing from here *knock on wood*
