ARE truck cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MGM 22, Jan 29, 2023.
  1. Jan 29, 2023 at 12:42 PM
    #41
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    I ordered and bought an ARE Classic back in 2019 (pre Covid) per the recommendation of my local dealer. Only took about a month for it to arrive back then. The dealer who ordered it also sells Leer, Snugtop and a few others, he felt ARE offered the best build quality and price point. I've had other shells but am pleased with ARE. I am running the factory leafs with Wheelers AAL and Bilsteins. No sag issues at all.
  2. Jan 29, 2023 at 2:30 PM
    #42
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    TRD Lift should be good for the cap... if it sags, then you can go ahead and replace. First have them place the cap on your bed and see if it sags or not before you spend any more of money.
    If you plan to have a popup tent on top of the cap, then you may consider to replace lift. popup tent would weight about 200lbs depending on the materials used.
    MGM 22[QUOTED][OP] likes this.
  3. Jan 29, 2023 at 2:37 PM
    #43
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Throw some weight in back. Like 150 to 200 lbs see if it sags. TRD lift is just a block. You may need add a leak of pack.
  4. Jan 29, 2023 at 2:53 PM
    #44
    TAZMINATOR
    2017 Tacoma
    My dealer offered lock on my cap that can be used with my fob.. I rejected the offer but I told him I will come back much later to have it done. I don't trust anyone messing around in my bed if they borrow my truck..
  5. Jan 29, 2023 at 3:01 PM
    #45
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    my dealer is a friend
    TAZMINATOR[QUOTED] likes this.
  6. Jan 29, 2023 at 4:12 PM
    #46
    TAZMINATOR
    2017 Tacoma
    mine too but I meant I have work tools in my bed which I work for house remodeling/construction. Which is why I don’t want anyone to go in there to mess it around.
  7. Jan 29, 2023 at 8:12 PM
    #47
    SARMichael
    SARMichael Member
    Waldport, OR
    2023 LunarRock Tacoma TRD Off-Road
    I'm replacing a Honda CR-V with a Tacoma TRD OR SB MT. I wanted something that would tow more than the CR-V and carry more than the CR-V. Needed a canopy to make everything work.
    Looked at the Century High C, but chose the A.R.E MX model. Added some options: Front window open/tilt down (dogs), pet screens (dogs), headliner and twin rope lights that come on when the hatch is opened.
    I'm convinced that the layers in the construction and the dead air space will reduce heating in the bed area (dogs again). Hope I'm right.
    Prices were comparable between the two (and color matching was included) at just below $3,700.
    I was told that the canopy would take 9 weeks. I ordered it 11/22/22 and it arrived 1/9/23.
    I pick up my Tacoma tomorrow.
    Steves104x4 likes this.
  8. Jan 30, 2023 at 5:25 AM
    #48
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Probably. The TRD lift kit is just a spacer lift in back so no added capacity for the leaf springs. I have seen two longbeds sag with factory suspension. Short bed won't be much lighter, but will sage less than LB so poissibly just 1/8-1/4".
  9. Jan 30, 2023 at 5:42 AM
    #49
    ripplebc
    ripplebc Active Member
    2020 Cement TACO TRD Sport LB
    Topper, Prinsu Racks
    I also have the ARE CX Evolve on my 2020 with key fob lock. Overall I'm very happy and don't regret the decision but my rear window is full glass and it always looks like it isn't shut properly. I've tried to adjust it with no luck. It is water tight so functionally OK but I hate the look. I don't have a picture available right now. Does anyone else have this issue?
    NMBruce[QUOTED] likes this.
  10. Jan 30, 2023 at 6:06 AM
    #50
    TAZMINATOR
    2017 Tacoma
    take it to the topper dealer and they will fix it for you.
  11. Jan 30, 2023 at 7:38 AM
    #51
    ripplebc
    I took it back once and they only made it slightly better. I may need to find a different dealer.
  12. Jan 30, 2023 at 8:02 AM
    #52
    TAZMINATOR
    2017 Tacoma
    find another dealer is good idea. If you are talking about gap around the topper edge then it is designed that way and there is waterproof rubber seal behind the glass to keep water out.
  13. Jan 30, 2023 at 1:12 PM
    #53
    NMBruce
    SW Colorado
    You are correct about the rear window, but ARE website shows the window fitting perfectly but the end product doesn't and you can many pictures and a video that shows the bad fit.
    Mine rear window still has a little more adjustments in the latches, but I will wait for some warmer weather.
    PS; posted a review on ARE website
  14. Jan 30, 2023 at 1:19 PM
    #54
    NMBruce
    SW Colorado
  15. Jan 30, 2023 at 2:30 PM
    #55
    TAZMINATOR
    2017 Tacoma
    That sucks... Mine is similar but no issue which you described.
    Mine is Leer 100XQ:
    This picture was taken before Prinsu top rack is installed.
  16. Jan 30, 2023 at 7:33 PM
    #56
    NMBruce
    SW Colorado
    I am thinking about returning mine and getting a Lear. But first I am going to visit a second dealer and see what they say
  17. Jan 31, 2023 at 4:21 AM
    #57
    TAZMINATOR
    2017 Tacoma
    That’s good idea. Hope things go well for you.
  18. Jan 31, 2023 at 4:50 AM
    #58
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I don’t know if it helps at all but I have the ARE classic and the rear window fits perfectly against the tailgate. No overhang or anything like in your pictures. It looks like something that came with the truck from the factory.
    I say that because ARE should fix that for you; that’s not how it should look.
  19. Jan 31, 2023 at 4:38 PM
    #59
    NMBruce
    SW Colorado
    today I visited a second dealer and he said that is they way they are, so I used the "Contact Us' form on 4ARE.com and complained about the rear glass fitting. About an hour after sending in the form, I got a reply email for pictures. You might want to do the same.
  20. Jan 31, 2023 at 4:43 PM
    #60
    Halloween
    Halloween Well-Known Member
    Toyotas a plenty
    When you get an ARE make sure you remove the ARE logo decal lol
    Looks way cleaner imo
    DougNuts and MGM 22[OP] like this.
