Are V6 manuals depreciating less?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by unclemat, Sep 22, 2016.
  1. Sep 23, 2016 at 8:51 PM
    #41
    unclemat
    unclemat [OP] Well-Known Member
    2012 TX Baja
    Eh, paying cash. $20k is not chump change, but seeing how much $$$ people/dealers are asking (and apparently paying) for older Tacomas in worse shape/higher miles I think it's a decent deal. I know it sounds like I am trying to talk myself into it... did not really plan on buying "damaged goods" indeed, but then I hate overpaying for "worn goods" as well. Here are some pics of the damage (one of these pics really sucks).
  2. Sep 23, 2016 at 8:52 PM
    #42
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    I love my 6 speed. If it does shit the bed eventually it'll be getting a T56.
  3. Sep 23, 2016 at 8:52 PM
    #43
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Sounds like a good deal. How good depends on specific options like V6 or 4-cyl? 4X4 or 2WD? 4- or 5-Spd AT?
  4. Sep 23, 2016 at 8:53 PM
    #44
    unclemat
    2012 TX Baja
    V6 4x4 5AT. Are there 2WD TRD sports? I thought all are 4x4.
  5. Sep 23, 2016 at 9:01 PM
    #45
    unclemat
    2012 TX Baja
    That's a very fair point, thanks. I'll have another look before finalizing the deal.
  6. Sep 23, 2016 at 9:01 PM
    #46
    Norton
    In that case, congrats on what sounds like very good deal!
    I recently learned the TRD Sport package is available on both 4x4s and (2WD) PreRunners, but not (2WD) 5-Lugs.
  7. Sep 23, 2016 at 9:13 PM
    #47
    unclemat
    2012 TX Baja
    Indeed that sucks. At least Sport is available with stick. I plan on DCSB O/R for the future 3rd gen purchase, so I should be ok.
    shakerhood[QUOTED] likes this.
  8. Sep 23, 2016 at 10:53 PM
    #48
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    I got ridiculously lucky with mine, I was just about to close on a 2002 5spd AC TRD and I had to put the purchase off until I got my insurance check. A week went by and I returned and saw my truck sitting in front. 2011 AC TRD OR 6spd with less than 19,000 miles. 45 minutes later I drove it off the lot for 24k
    shakerhood likes this.
  9. Sep 24, 2016 at 7:26 AM
    #49
    Pigpen
    Dan
    Northwest Montana
    You'll like the auto if you drive in technical areas at all. I'm not sure how many times I've seen smoke from my clutch...
  10. Sep 24, 2016 at 2:28 PM
    #50
    FlyinTacoma
    FlyinTacoma Member
    Travis
    W 111' 35' N 33' 26'
    '15 DCSB TRD OR MT Super White
    Toytec 650lb Coils Dakar 3 leaf AAP Bilstein 5100 F&R JBA UCAs Rear axle shim Diff drop Sway Bar Delete Toyo Open Country A/T II Pro Comp Wheels
    After reading this thread I feel like I got super lucky! Last year I bought a new (17 miles on it) 2015 DCSB TRDOR 6MT for $30,500. There happened to be two in my area that were identical I pit the two dealerships against each other for the sale. Both were trying to make room before the '16s showed up.
  11. Sep 24, 2016 at 2:34 PM
    #51
    Duck_Hunter
    Duck_Hunter Well-Known Member
    Tejas
    2014 Tacoma TRD Off Road Manual
    ATC shell
    Well, yeah. I'd feel lucky. Hell, I felt lucky about mine until I read about yours. Congrats.
    FlyinTacoma[QUOTED] likes this.
  12. Sep 24, 2016 at 8:21 PM
    #52
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I got lucky with mine too, I bought mine in August last year and it took them 3 weeks to finally find another Dealer that was willing to give up one.
  13. Sep 25, 2016 at 2:42 PM
    #53
    unclemat
    2012 TX Baja
    So... change of plans last minute. On our way to finalize the deal for the blue TRD Sport... we found and bought this instead.
    2012 T/X Baja (still an auto :goingcrazy:), 50k miles, pristine condition, not a scratch on it - rust free, all stock and clearly a mall crawler. Still under Toyota powertrain warranty till mid next year, but also came with 12k/12month basic, 7k/100k miles powertrain aftermarket warranty. $23,100+tax/reg. Including the difference in the doc fee between the dealers, came to $2.5k more than the somewhat molested 2013 TRD Sport. 2012 but only 6 months longer on the road than the 2013 (and same number of winters). Seems to be worth it. Love the red. Don't love the graphics, it's gaudy somewhat but, cool in some weird way as well. I like the TRD exhaust.
    Actually it's going to be wifey's ride. I love her dearly that she digs driving something like that :)
    I guess I need to start a proper intro thread...
    Duck_Hunter likes this.
  14. Sep 25, 2016 at 5:07 PM
    #54
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I'm sure it looks good in person, but in a pic it looks like spilt black paint all over it. Or some teenage did some body work.
  15. Sep 25, 2016 at 5:09 PM
    #55
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    The red is pretty sweet. The decals do peel off. Get yourself a heat gun.
    Norton likes this.
  16. Sep 25, 2016 at 8:42 PM
    #56
    unclemat
    2012 TX Baja
    I think we'll keep them. One thing it's what it is, the plan is to keep it stock, also I'd be worried that the paint might have faded and the decals would live visible "ghost".
  17. Sep 25, 2016 at 8:42 PM
    #57
    unclemat
    2012 TX Baja
    True. Here is slightly better pic.
    spitdog[QUOTED] likes this.
  18. Sep 25, 2016 at 8:47 PM
    #58
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Test an area in an innocuous location first. If no fade then I'd say send it.
    The Baja suspension is pretty sweet!!! Is your backup cam in the rear view mirror? Self dimming, w/ homelink and compass? Clock in the dash? Lots of folks post MY12/MY13 lost those standard options. Suckers.
    scottalot likes this.
  19. Sep 25, 2016 at 8:49 PM
    #59
    unclemat
    2012 TX Baja
    Yes on all these. I like the radio with VFD display much better than the LCD (touch screen?) business the 2013 TRD had.
  20. Sep 25, 2016 at 8:54 PM
    #60
    Green Jeans
    Oregone
    '13 TRD Off-Road
    I had a MY12 that got smacked by a semi and totaled and replaced it with a MY13.
    In my opinion the stereo in the 13, especially the Bluetooth function and the steering wheel controls were much better than the 12.
    Fewer nanny features in regards to the Bluetooth / paired phone function on the 13 as well.
    Both had the backup camera displays in the rear view...where it should be.
    My $0.02.
