Are Wheel spacers a bad idea?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SPORT, Apr 4, 2011.
Are Wheel Spacers a bad idea?
Poll closed May 4, 2011.
  1. Yes, They are hard on truck.
    13 vote(s)
    22.8%
  2. Yes, you need aftermarket wheels!
    4 vote(s)
    7.0%
  3. No, They run great after thousands of Off Road miles
    21 vote(s)
    36.8%
  4. No, they run great after thousands of mostly On Road miles.
    19 vote(s)
    33.3%
  1. Apr 4, 2011 at 1:39 PM
    SPORT
    SPORT [OP] Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    Getting ready for a 3" lift and want to retain stock TRD OR wheels.
    What are your impressions of installing 1.25" Spidertrax spacers?
    Dealer mentioned that they induce speed wabbles. Any of you here aware of this?
  2. Apr 4, 2011 at 1:40 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    No wabbles. Had mine for almost 2 years and no problems. Just male sure you get the spidertrax ones.
  3. Apr 4, 2011 at 2:02 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    They ware out your wheel barrings faster but not much faster. Just don't go too thick or else you'll need extended studs. Make sure to buy hub centric too.
  4. Apr 4, 2011 at 2:54 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x2 for Spidertrax. They are hubcentric so they will prevent any wobbles or vibrations, and they come with new, longer studs embedded in them so you won't have the problem jdmdcfan noted.
  5. Apr 4, 2011 at 3:02 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Spidertrax are both hub and lug centric. They won't put any more stress on your wheel bearings than an aftermarket wheel with similar offset.
    No vibes or wobbles or issues here, just a happy customer.
  6. Apr 4, 2011 at 3:18 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i put they are hard on the truck because they are, but any mod is. just lock tite them and make sure thery are torqued down, check them everyonce in a while
  7. Apr 4, 2011 at 3:18 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Instagram- venturajuan23
    Spidertrax still have mine for 2 years also and I've had no problems
  8. Apr 4, 2011 at 3:32 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Spidertrax are the only ones to use IMHO
  9. Apr 4, 2011 at 6:05 PM
    Nightfury
    Nightfury Well-Known Member
    Evan
    Bismarck, North Dakota
    Factory running boards, Toyota (DeeZee built) toolbox, Code Alarm 5152 remote starter, Bronze TRD rims, more to come....
    I voted they are hard on a truck, but as mentioned, aftermarket rims can be as well. I'd recommend rims over spacers if you can find a rim you like.
    WARNING: Here comes the factory trained technician in me.
    In either case, they change the stance of the vehicle, the way the wheels articulate during steering and suspension movement, and change the leverage of suspension and steering components. This -could- cause accelerated wear on certain components, but I think that really is nit picking.
    That being said, just like any aftermarket product, get a quality set of spacers. Do your research, don't cheap out, and install them properly. I, personally, don't care for wheel spacers because that's an additional mounting point between your rim and hub that can fail.
    Just my $.02, and as I said, I'm a Toyota mechanic, working at a dealer, and I value simplicity and fewer points of failure. So by all means, take my opinion with a grain of salt.
  10. Apr 5, 2011 at 4:04 AM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Any opinions on the wheelers 1/4" spacers?
  11. Apr 5, 2011 at 4:17 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Spidertrax, lock tite, and check the bolts. 3 years later and running strong.
  12. Apr 5, 2011 at 10:30 AM
    BAMFTACO
    Juan
    those spacers are sketchy they make your wheel stud weaker most of the weight is gunna be at the end of the and that's not good
  13. Apr 5, 2011 at 10:31 AM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    i have spidertrax, love them. The only problem i had was they made my tires rub a little, drives and rides the same though!
  14. Apr 5, 2011 at 10:34 AM
    jackwithcorona
    Eastern Mass
    13 DCSB SR5 4x4
    Yeah I got them because I had a wheel that didn't fit, but even with them it didn't fit, so I'm on stock steelies with no spacers now. Thanks I thought they seemed sketchy
  15. Apr 5, 2011 at 10:34 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
  16. Apr 5, 2011 at 10:35 AM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
  17. Apr 6, 2011 at 2:45 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
  18. Apr 22, 2011 at 10:13 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    x2
  19. Apr 27, 2011 at 8:18 AM
    inlinejohn
    inlinejohn Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    love my Spidertrax. No issues
