Are wheel spacers as terrible as everyone makes them to be??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paczowski123, Oct 18, 2011.
  1. Oct 18, 2011 at 7:32 AM
    Paczowski123
    Paczowski123 [OP] Well-Known Member
    David
    Kennesaw
    05 prerunner trd off road
    OME 3" Lift, Kennesaw Mountain Off Road Wincher Front Bumper w/ 5" Integrated off road lights, Kennesaw Mountain Off Road Multi Carrier Rear Bumper w/ swingout tire carrier, Jerry can, and hi-lift mount, Sof-topper rear cargo cover. Galaxy DX44V CB Radio W/ 4' FireStikII, Rock Sliders
    I have a 05 tacoma with a 3" OME lift and 265/75/16 BFG AT's mounted on stock rims. I get scrubbing on my upper A-arms when turning into parking spaces or backing out. I have always understood wheel spacers to be a bad idea, for safety and wheel bearing longevity. Are they really that bad, b/c i see them run all the time, and would they help with my scrubbing?
  2. Oct 18, 2011 at 7:38 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    they will help with your uca rubbing but may make you rub in our wheel wells, but you can always trim that.
    alot of people run spacers. i have run them on my truck for a while, and i drive the shit out of my truck off road, no problems, just check them every month or so if you off road alot
  3. Oct 18, 2011 at 8:06 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    There is also the matter of getting what you pay for. The Spidertrax spacers are popular and have a good rep. I have them too.
  4. Oct 18, 2011 at 9:45 AM
    Paczowski123
    David
    Kennesaw
    ok, yes i am no person to buy cheap junk, unless they are simple parts, something like this i would not skimp on. Any recommendations on a size to get?
  5. Oct 18, 2011 at 9:46 AM
    97yota4wd
    Eric
    Mesa, AZ
    1.25 hud centric spider trax or 1.5 inch all pro.
    unless you just want to fix the uca rub then im sure you could get like a 8th inch spacer
  6. Oct 18, 2011 at 9:50 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
  7. Oct 18, 2011 at 1:13 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    I run spydertrax no problem. They wear out your bearings just as fast as any other wide wheel and twice the room for error. Anyone with basic common sense about vehicles should have no problem running them. And the 1.25 on each side may seem subtle but it looks 10 times better.
  8. Oct 18, 2011 at 2:05 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i am surprised that size will even rub. i met a lady with a stocker running that size. rancher lady. she said she gets zero contact.
  9. Oct 19, 2011 at 1:05 AM
    Meeocky
    Meeocky GEAUX TIGERS!
    Louisiana
    Black '05 Tacoma
    I wonder how bad would i rub with the spidertrax on 265/75/16 at stock height??
  10. Oct 19, 2011 at 9:19 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    here my opinion, "wheel spacers" got a bad name in the old days b/c people were using them improperly. to properly use wheel spacers, it is recommended that you add longer studs to make up for the lost depth of thread that the spacer is taking up. imagine people using 1/2" spacers, that's a lot of thread lost for the lugs. plus, now the wheels aren't mounted flush like they should be which can cause all kinds of vibrations and balancing issues.
    "wheel adapters" on the other hand has a pretty good reputation given that you go with hub-centric adapters. the hub-centric adapters allow you to have the wheel centered on the hub as well as carry the load like it was engineered to. you don't lose any threads on the studs and you gain the clearance needed or achieve that aggressive look.
  11. Oct 20, 2011 at 1:44 AM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    i run this size with no rub. im at 1.75 up front though
  12. Oct 21, 2011 at 9:46 AM
    Paczowski123
    David
    Kennesaw
    Thanks for te info guys, yeah I think just getting the tires outta the wheel wells will make it look better as well and stopping the runnbing. Also will I need ones for front and rear or just front? Never used spacers before so don't know much about em.
  13. Oct 21, 2011 at 10:04 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    i would do all four to get a balanced look. just remember to buy hub-centric wheel adapters only. it's a little more expensive, but it's the right way to do it.
  14. Oct 23, 2011 at 10:58 AM
    Paczowski123
    David
    Kennesaw
    Yes, I will buy hub centric. I will prob go w/ spidertrax
  15. Oct 23, 2011 at 11:16 AM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    Been running spider tax for 2 years with no problems other then no1 but 4wheel parts will work on my tires now. Discount tire won't even get near my truck. That's the only really frustrating part.
  16. Oct 23, 2011 at 11:28 AM
    RedWingsSuck
    RedWingsSuck Member
    I have had a set of the spidertrax on the front of my Jeep for 3+ years w/o any problems. Check 'em every once in a while to make sure they are tight, but they have yet to be loose at all. Good stuff.
  17. Oct 30, 2011 at 9:09 PM
    squamish VFR
    squamish VFR Well-Known Member
    Squamish B.C. Canada
    '06 tacoma 4door shortbox
    Bilsteins set at 2.5" OME Dakar rear leaf packs, FJ manual TC conversion, basket winch front and rear, hidden hitch in the front behind licence plate. Spyder headlights, tailgate seals.
    Spidertrax with no issues. HUB CENTRIC as everyone stated use the right part in the right way and there are no problems. If you rub the inner fenderwells, heat the offending area with a heat gun and the plastic will shrink out of the way.
