Are you getting bad MPG?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JAG, Feb 23, 2009.
Click on all that apply to your Tacoma.
  1. I get good MPG!!
    27.6%
  2. My MPG sucks!
    38.9%
  3. My Tacoma is Stock.
    38.1%
  4. I have a heavy foot on the gas accelerator!
    21.0%
  5. I have the fog light mod running through the ECU relay.
    3.9%
  6. I have added bolt on after market parts.
    15.1%
  7. My Tacoma is lifted?
    19.4%
  8. Who gives a crap????
    14.3%
  1. May 19, 2013 at 6:17 PM
    #961
    FATPUBUS
    FATPUBUS Well-Known Member
    Moulton, Texas
    13 Tx Edition
    Well i only did 321 miles on a full tank today, is that bad? Ran 65, or 75 where the limits were allowable in Texas. The 05 4runner, same engine gets bout 420 per tank, so i guess the tacoma mpg sucks lol! Oh well, not concerned with it...usually dont drive that much in 3 weeks let alone a day!
  2. May 19, 2013 at 10:06 PM
    #962
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    absolutely nothing. It'll put a little more strain on the electrical system, so the alternator will be a tiny bit harder to turn. but this wont affect your mpg at all.
  3. May 20, 2013 at 5:09 AM
    #963
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT
    I wonder why there is such a huge discrepancy between mileage between all our trucks (larger tires, lifts, and towing aside)? I have mud tires and different wheels on mine (albeit stock size), and the added weight of some aftermarket equipment but other than that mine is pretty much still a stock truck. If I only got 321 miles on a tank I would be PISSED. I fill mine up every payday (every 2 weeks) and I get well over 400 miles on a tank. When I say I fill it up I mean I fill it UP. All the way to the neck. I know it isn't recommend but at least I know that my calculations are correct on the MPG. I drive 240 miles in a 2 week period to work (24 miles each way 5 shifts) all country back roads. I never get a chance to get it above 50 going to work. Like I said before, I drive like a grandpaw because of where I have to drive. The rest of my driving that I do are short drives around town to take and pick my daughter up from school, to go to the store, or out to eat. Only about 10% of my driving is freeway and I'm sure that makes a difference. But I still average well into the lower 20's on our vacations and I keep it between 70-75 so I don't know.
    I'll give you and example:
    In March we went to Colorado on vacation. We left on a Fri. evening and drove from Benton Ar. to El Reno Ok. Distance of almost 390 miles. I had the bed full of luggage and 2 other people in the truck. I filled up as soon as I left Benton and made it to El Reno with just below 1/4 tank of fuel left. I drove 70 / 75 the entire way other than through Ok. City.
    Only engine mod I've done is a K&N air filter and I know that doesn't make "that" much difference. I have used a lot of different fuels in the past and all have pretty much the same mileage other than the shit I bought in S.D. But I have noticed a pretty noticeable difference when I switched to Shell V-Power FWIW.
    If the 12-13 models are getting that type of mileage I'll just keep my 11 for a long time.
  4. May 20, 2013 at 5:23 AM
    #964
    grant2335
    grant2335 New Member
    Grant
    2.5 inch leveling kit and back rack
  5. May 20, 2013 at 7:12 AM
    #965
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Saying how far a tank took you isn't very helpful, the only way to really compare at least somewhat equally is how many miles and how much you filled the tank with. Even then it's only going to make sense if you use the same exact pump at the same exact station since different pumps will shut off at different points. Really the only GOOD way to do it would be like on myth busters where you start with an exact known quantity and figure things from there.
    I generally get between 320 and 340 to a tank, roughly 17 to 18 mpgs with a commute every day of about 20 miles of 80 mph. I could see somebody getting 20 mpg's if they keep things under 50 all day every day but I'll never be able to test that as that's just unrealistic for me.
  6. May 20, 2013 at 7:16 AM
    #966
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I have a 6 inch lift and 35's and I got 16.1 on my last tank.
  7. May 20, 2013 at 7:28 AM
    #967
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    How you drive these things has as much to do with your MPG as just about anything. Especially if you have a manual trans. and you do much stop and go driving. Tire size is another biggie, especially if your vehicle has wide or wider than stock tires. Wide tires can dramatically affect your fuel consumption. Another reason I like tall and narrow tires like the 255/80/17's or 255/85/16's
  8. May 20, 2013 at 8:09 AM
    #968
    RearViewMirror
    Craig Christ
    2023 Subaru WRX GT
    Disclaimer: Knowing that I could easily fake this and modify it to match whatever mileage I want.... you guys will just have to trust me on this.
    I will take pictures of my miles driven and the fuel gauge to give you an idea of "my" mileage and see if yours is similar to mine. I will fill up at the exact same pump that I filled up at a couple of days ago and show that I top it completely off and then take a picture of the receipt and the miles on the trip odometer. I'm not doing this to brag and in no way is this scientific but at the very least it will be a "baseline" of what my truck is doing.
    I use Shell-V Power 93 octane exclusively, have a K&N air filter (no cold air induction just the filter), and use Mobil 1 Synthetic oil.
    Where my truck sits right now 5/20/13 9:45 am
  9. May 20, 2013 at 8:19 AM
    #969
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    I get 300-330 per tank but Im also not a Prerunner which is another huge difference for some of us. My needle when it looks like that I have about 55 miles on a tank. I might run 93 and see how much it changes my MPG next fill up and if its worth the extra money.
  10. May 20, 2013 at 8:25 AM
    #970
    RearViewMirror
    Craig Christ
    2023 Subaru WRX GT
    Yeah... that is something else i didn't mention. The extra weight on the 4X4 would presumably drop the MPG also.
    Like I said I fill mine up to the neck where you can not put any more fuel in it. I know that you shouldn't do it but I have never had any ill effects other than it pisses the people off behind me if the station is full lol. But this is the only way that I know of accurately determining exactly how many miles you are getting per gallon (assuming the pump is calibrated correctly but that is a uncontrollable aspect).
  11. May 20, 2013 at 8:28 AM
    #971
    Okeetee
    Okeetee I like the Anaheim Ducks
    Kyle
    Huntington Beach, CA
    '11 MGM TRD Sport DCSB 4x4
    OME 887 coil springs, Bilstein 5100s (front/rear), Light Racing UCAs, Wheeler's HD 1.5" AAL, 18x9 Pro Comp series 7032, Toyo Open Country A/T II (LT285/65R18)
    My average MPG dropped from approximately 20 to 18 after I put on 265/75/16 Duratracs. Is that significant? Because it sure feels like it.
  12. May 20, 2013 at 8:37 AM
    #972
    RearViewMirror
    Craig Christ
    2023 Subaru WRX GT
    I don't know... I lost about 1 1/2 MPG when I put my mud tires on also. I have mine aired up to 40psi and as I have put some miles on them the mileage has "slowly" crept back up.
  13. May 20, 2013 at 8:40 AM
    #973
    aubi1414
    Justin
    Pensacola, FL
    Damn you drive a lot!! Feeling up weekly :eek: Gas here is at 3.32 also :D
  14. May 20, 2013 at 8:47 AM
    #974
    Okeetee
    Kyle
    I forgot what it's like to pay $3.32 for gas. :D
    Ever since I moved back to SoCal in January my weekly miles have gone through the roof. When I lived in Denver, I filled up bi-weekly for around $3 per gallon.
    :frusty:
  15. May 22, 2013 at 3:53 AM
    #975
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    why the hell would you move back to that dump (im a nor cal native who left for denver last year)
    Anyhow, decided to check out my spark plugs ... no good .... so i figure ill be able to break 20 again once i get new ones (used to pull 22 - 23 all hwy when i moved here cause the gas doesnt have all the bullshit additives the california stuff has)
    And i bet you guys are probably over $4 / gal by now too cause its jumped into the upper 3's here .
  16. May 30, 2013 at 5:48 AM
    #976
    RearViewMirror
    Craig Christ
    2023 Subaru WRX GT
    Oh shit.... I forgot completely about this thread. I was going to post my next fill up but between fill ups I got this and got busy messing around with it.
    The 26.4MPG that it is showing is driving directly from the Shell Gas Station (Filled up with 93 octane V Power) back to the house on the road that I take to go to work (27 miles). Never got above 45 MPH so that looks pretty accurate for that period.
    I'm in calibration mode with it right now so I need to run the tank back down pretty low and fill up at the same pump so it will be calibrated. But from the looks of it it is running pretty accurate at the moment sitting at 22.5-23.
    I'll post my next fill up and then go from there. For what its worth... Regular unleaded down here is sitting at about $3.20
  17. May 31, 2013 at 7:46 PM
    #977
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I have been towing my Prius with my Tacoma from North Carolina and I am in north Platte Nebraska and I have been getting 13.25 mpg average I am shocked
  18. May 31, 2013 at 7:50 PM
    #978
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    I don't know yet. I just plugged in my Ultra Gauge and all I have learned is that I suck at getting good economy.
  19. May 31, 2013 at 7:57 PM
    #979
    169.254.255.201
    169.254.255.201 Well-Known Member
    Interwebs
    Not even sure what to say to that.. loll
    New headlights would yield signifacnt results. May 15 to 16 MPGs?? And if your really want some more mpgs, try those octane increasers at walmart.
  20. May 31, 2013 at 9:26 PM
    #980
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
