Are you old enough to remember zerk fittings on your car? I am, but forgot...
Discussion in 'Off-Topic Discussion' started by 916carl, Aug 15, 2023.
  1. Aug 15, 2023 at 11:00 AM
    916carl
    916carl [OP] Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    I think they stopped putting zerk fittings on cars in the 80's. I remember crawling under my car with my dad's grease gun when I was younger. There was a feeling of satisfaction when I saw the grease squeezing out of the joint. I hadn't done that in so long, as an adult with modern cars, that I never gave it any thought. Even when I bought my 67 Camaro it didn't jar the memory.
    Years have gone by with it and it just hit me the other day that it has zerk fittings and I've never greased them. I was astounded that it never even entered my mind. I wonder how many of you reading this are of the generation that didn't have them on your cars?
    Picked this up and will be taking care of it as soon as the outside temp gets more reasonable.
    For those who don't know
  2. Aug 15, 2023 at 11:11 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m going to be 40 this month.
    You haven’t lived until you gotten the fitting stuck on a zerk.
    Work a puzzle trying to figure out how to get on the fitting, then it won’t come off.
    :rofl:
  3. Aug 15, 2023 at 11:13 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I mean my first gen has them on the drive lines still and most of my aftermarket parts do too.
    Snowman and 916carl[OP] like this.
  4. Aug 15, 2023 at 12:59 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    regularly greased the driveshaft and u-joints on my 1st gen
  5. Aug 15, 2023 at 1:22 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Worked at an actual 'service station' in HS (71-73), so yea. FWIW I bought a new '86 S-10. Had 9 or so zerks on the front end IIRC. Sold it in 2018 with 220k+ on it. All original steering, etc, components and still tight. Grease works. :D
  6. Aug 15, 2023 at 5:20 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    A few things in my garage have zerks (scag etc). Sadly my Tacoma does not.
  7. Aug 15, 2023 at 7:51 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Chevy had them all over the suspension until recently and it didn't stop them from falling apart
    Toyota still has them on drivelines
    In my opinion, greasing suspension ball joints on stock vehicles is a little outdated. If the grease is squirting out the boot then you're looking at a path for dirt and contamination to get in.. A good ball joint will be (should be) sealed up completely so the grease never leaks out and nothing ever gets in
  8. Aug 17, 2023 at 8:51 AM
    My Name is Rahl
    It was later than the 80's, my 1992 Dodge Dynasty had zerks on the suspension components. And the MOOG replacement ball joints I put on my Crown Vic had them too.
