Are you prepared? Trying to be more self sufficient
Discussion in 'Guns & Hunting' started by Casper66, Apr 29, 2024.
  1. May 12, 2024 at 6:14 AM
    #321
    MagicToolbox
    MagicToolbox Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    This is more or less my setup. Although I plan to put it on a converted cargo trailer. For now it lives on my front porch roof, and I'm using salvage UPS SLA batteries.
    Casper66[OP] likes this.
  2. May 12, 2024 at 8:14 AM
    #322
    Casper66
    Casper66 [OP] grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Good to have you in here. As you said we can all learn from each other.
    Ret CB[QUOTED] and wilcam47 like this.
  3. May 12, 2024 at 8:54 AM
    #323
    MagicToolbox
    I'm taking a semi-deserved rest after a spring service of the rain barrel system after a winter of disuse.
    Three 60 gallon pickle barrels in the crawl space, with a 3 inch PVC shower drain installed in the bottom. Each connected to a ball valve union so they can be isolated from each other. There is a low drain, new rainwater enters from outside, and a 'trap' of sorts outside that keeps the water from overtopping the barrels.
    The pump draws from the same pipe, has a pressure switch and a small accumulator tank. There is a float switch in the middle tank to prevent the pump from running dry. The output of the pump is plumbed to the front of the house with a sill-cock, I would like to add another one closer to the garden area.
    The inline light switch probably needs some insulation, the dangling circuit board is a level sensing hack that is left-over from before the float switch was installed.
    (let's see what this looks like, I'm tapping this out ony phone.)
  4. May 12, 2024 at 10:38 AM
    #324
    Casper66
    Culpeper, Va.
    piddly stuff
    Quite the system kudos to you! Mine is very simple but stores quite a bit. A lot of thought went into yours I can appreciate that
  5. May 12, 2024 at 12:49 PM
    #325
    MagicToolbox
    Thanks.
    Since I had the overalls on to work under the house I rotated some fuel from the stored Jerry can into the Taco and got some fresh E0. 4.59 a gallon - oof. Since I use the old in the truck it's not like it's wasted, I guess I just chalk it up to the cost of insurance. I add a tag that shows when it was filled and use the oldest one first. This one should be good until December. SmartSelect_20240512_152409_Gallery.jpg
  6. May 12, 2024 at 1:34 PM
    #326
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I just keep a 55 gallon drum. Five gallons into the truck once a month and refill five next time I fill up.
  7. May 12, 2024 at 5:35 PM
    #327
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  8. May 12, 2024 at 7:26 PM
    #328
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    Nice. I assume you're using it for garden water?
  9. May 13, 2024 at 4:52 PM
    #329
    Ret CB
    Ret CB Builder Bee
    Anthony
    SC
    2015 AC Pyrite Mica
    De-badged , Grillcraft grill , SCS Stealth 6 , BFG AT KO2
    So let me throw some levity into this discussion. For all you science fiction buffs...In HG Wells "The Time Machine" at the end of the film version with Rod Taylor, when he leaves his friends and returns to the future to build a new civilization, he takes Three books with him. The ultimate question is .... Which three books would YOU take with you ?
    GTGallop, Casper66[OP] and wilcam47 like this.
  10. May 13, 2024 at 5:27 PM
    #330
    MagicToolbox
    Watering the garden, and any pressure washing duties.
    Not potable at the moment. It's runnoff from a 30+ year old asphalt roof.
    wilcam47 likes this.
  11. May 13, 2024 at 6:15 PM
    #331
    Casper66
    Culpeper, Va.
    piddly stuff
    A medical/ first aid book
    A bush craft/ survival book
    A Bible
    Sprig, Toy4me, PinnaclePete and 2 others like this.
  12. May 13, 2024 at 6:19 PM
    #332
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Do you guys use a fuel stabilizer or just rotate it enough for it not to be an issue? I don't have much room to store extra stuff but I keep thinking more and more about fuel being one of the more important things I could do which we're currently not. I think if shit hits the fan in my area fuel is gonna go fast and with the poor mpg of my Tacoma I'm sure not getting far even if I'm lucky enough to have a full tank at the time.
  13. May 13, 2024 at 6:31 PM
    #333
    Travlr
    Middle'a Utah
    Silent Spring, Terminator, and Merchants of Doubt.
  14. May 13, 2024 at 6:39 PM
    #334
    Casper66
    Culpeper, Va.
    piddly stuff
    Rotate with the mower and other equipment it isn’t difficult
    .劉煒 likes this.
  15. May 13, 2024 at 8:45 PM
    #335
    .劉煒
    Tbh, I don't store fuel. Most of the tools are electric, and if fuel is scarce the ebike will be the errand machine.
  16. May 14, 2024 at 4:26 AM
    #336
    Casper66
    Culpeper, Va.
    piddly stuff
    Managed to run the tiller through the garden Sunday so I got a row of beans planted, we planted 20 pepper plants and yesterday did 20 tomato plants. All the peppers and tomatoes from seeds she grew
    Ret CB likes this.
  17. May 14, 2024 at 7:01 AM
    #337
    MagicToolbox
    I have a container of Sta-Bil but I don't usually use it. I rotate my fuel through a vehicle ideally every 3 months, but sometimes up to a year later - never had a problem, but I ALLWAYS buy ethanol free gas for storage.
    Casper66[OP] and Schlappesepple like this.
  18. May 14, 2024 at 11:41 AM
    #338
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Hustler
    Penthouse Forums
    Playboy - That one I read for the articles.
    Evostaco and Casper66[OP] like this.
  19. May 14, 2024 at 6:13 PM
    #339
    Casper66
    Culpeper, Va.
    piddly stuff
    We were planting in the garden last night and I told my wife to just stop and look around, what did she see? Not another person out in their yards doing anything. I told her this is what we could expect if shtf. We will be trying to raise food and support ourselves and our neighbors will most likely try to leach off us. I’m happy to help them but idk about support them
    Travlr likes this.
  20. May 14, 2024 at 6:17 PM
    #340
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I understand the NOT shoot them all camp, but I have been in the camp with the only person in the area for weeks with electricity and you better have a plan. Lesson learned is if no one else has lights at night, you shouldn’t either.
