Are you prepared? Trying to be more self sufficient
Discussion in 'Guns & Hunting' started by Casper66, Apr 29, 2024.
  1. Jul 28, 2025 at 11:32 AM
    #1081
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I've put elderberries in my beer secondary a few times. Pretty astringent.
    I think you meant diuretic, not diabetic.
    wilcam47 likes this.
  2. Jul 28, 2025 at 11:49 AM
    #1082
    Okiedokie59
    Okiedokie59 Well-Known Member
    Diabetic was in regards to the fig leaf tea.
    Google will list it's said benefits.
  3. Jul 28, 2025 at 12:10 PM
    #1083
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Purple tomatoes make the best pasta sauces and salsas, lower acidity than red tomatoes. We plant Cherokee purple.
  4. Jul 31, 2025 at 5:31 PM
    #1084
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Not complaining, but this heat has really put our okra in overdrive. Have to pick it twice a day. Good thing I love okra.
  5. Jul 31, 2025 at 5:59 PM
    #1085
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I only got my first blossom. I think I've used bad dirt. I happened on a sale to get rid of summer stock in the fall, and it's garbage.
  6. Jul 31, 2025 at 8:33 PM
    #1086
    Barsoom
    NW GA OTP
    I usually buy dirt on sale once a year, 60-80 bags at a time and use it throught the year. It stays good for a couple of years.
    Water your plants with Miracle grow and sprinkle some Osmokote.
  7. Aug 1, 2025 at 8:11 AM
    #1087
    Travlr
    Middle'a Utah
    I've got in-laws that buy big bags of dirt. They come in those white, nylon bags that are probably 4X4X4. But they are in the big city and I doubt delivery to where I am would be affordable. I had some raised beds with rough sand in them from a gravel pit and they would grow a garden like mad. The bagged stuff from the local Ace garden shop was a mistake.
    JDAM likes this.
  8. Aug 1, 2025 at 10:07 AM
    #1088
    Barsoom
    NW GA OTP
    My mix for the new raised beds (4 layers of 4x4 high, about 14" tall?):
    0. I line beds with double layer of landscaping fabric to keep soil in, bugs out.
    1' or so gravel, for drainage
    1. Next is leaves, small sticks for carbon, 3" or so.
    2. Then fill dirt to about half way:
    https://www.lowes.com/pd/Evergreen-1-cu-ft-Organic-Top-Soil/999911449
    3. For the top layer a mix of better soil, manure, moss, water pearls:
    a) https://www.lowes.com/pd/Sta-Green-Vegetable-and-Flower-Garden-Soil/5014304477 As many bags as it takes to fill 2" short of the top (Used in steps below).
    b) mix pit moss with water, add soil from a), put in the garden, about 25% moss to 75% soil mix. Make sure it is sphagnum, acidic moss. Most veggies like acidic soil.
    https://www.lowes.com/pd/Sphagnum-Peat-Moss-3-cu-ft-Organic-Peat-Moss-Moisture-Control/50339650
    c) 2 bags of manure for a 4'x8' bed, after 3" of b) mix are put down. Rake the soil mix smooth, empty the manure,rake it smooth,
    https://www.lowes.com/pd/Black-Kow-1-cu-ft-Organic-Compost-and-Manure/1000875388
    d) another 3" of mix from b)
    e) add prepared Soil Moist. I do 3 runs, 2 by the sides and 1 in the middle. 1 measuring cup will absorb 5 gal of water. Mix several days in advance, stir daily, let it sit and absorb the water. Each granule will swell up to a dime or penny size.
    https://www.amazon.com/JRM-Chemical-Soil-Moist-Granular/dp/B00Q3N08TQ
    f) add another 3" of mix from b)
    g) Pine shavings for mulch, to keep moisture in.
    In the fall I turn over the top 3-4 inches. Every spring add Soil Moist (3" from the surface, dig trenches with a gardening shovel) and top off with soil from a).
    Every plant gets a generous shake of Osmokote, after it is planted.
    After a few rains the new soil settles, so it is OK if soil in the new raised bed is close to the top.
    wilcam47, JDAM and Travlr like this.
  9. Aug 1, 2025 at 10:25 AM
    #1089
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    No garden centers that sell dirt by the yard near you?
  10. Aug 1, 2025 at 11:25 AM
    #1090
    Travlr
    Middle'a Utah
    No... I'm a hundred miles from nowhere. I'm just going to go get some of that sand that worked so well in my raised beds before, and work it into this garbage commercial mix for about a foot... and then top it with 6/8 inches of straight sand. Pretty sure it'll work just fine.
  11. Aug 1, 2025 at 1:30 PM
    #1091
    Barsoom
    NW GA OTP
    Sand encourages water drainage. If you have problems with lack of water (seeing you are in UT), be careful with sand.
    wilcam47 and Travlr like this.
  12. Aug 1, 2025 at 4:29 PM
    #1092
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    I don't buy dirt. I just plow up a section in the back for the garden. Try to rotate the spot slightly from year to year and also rotate crops. Compost, manure, and that's about it. The back yard was a pasture for 40+ years and has great dirt. When I do use fertilizer, standard Nitrogen for planting but low Nitrogen once plants start producing. Really don't do much fertilizing though as it grows well. The chickens and ducks add their own fertilizer at will.
    Okiedokie59, POOLGUY and Travlr like this.
  13. Aug 1, 2025 at 5:15 PM
    #1093
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    I'm probably missing the compost and manure. I turned over some of the back lawn, which is more moss than lawn. my test garden is not doing great. and the smaller rabbits are getting through my deer fence.
    wilcam47 and Barsoom like this.
  14. Aug 1, 2025 at 5:20 PM
    #1094
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    We just let the area winter normally and plow it up late spring with whatever is growing on it. Put the compost and manure on before plowing it up. The nice thing is the area was a cow pasture/hay field for a long time and just has good dirt to start with.
    Biggest problem I have is the ducks are infatuated with half ripened tomatoes. Thankfully they mostly concentrate on one Roma plant and leave the others alone.
  15. Aug 1, 2025 at 5:43 PM
    #1095
    Barsoom
    NW GA OTP
    We have solid clay past the top 2", 4" here. Impossible for a good garden, no drainage, plus July thru August it is in high 90's, and we are on the well. Not enough water for inground garden.
  16. Aug 1, 2025 at 9:23 PM
    #1096
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Try raised garden beds.
    .劉煒 and wilcam47 like this.
  17. Aug 2, 2025 at 3:58 PM
    #1097
    Barsoom
    NW GA OTP
    That's what I have, hence my receipe for the raised bed fill above. Have 8 of 4'x10'x14" raised beds and 15 of 20 gal planters.
    wilcam47 and POOLGUY[QUOTED] like this.
